Solved MM on Ubuntu
@sdetweil ahhh i think i said yes
@goncalovsc so,
pm2 status
should show the definition
anyhow, if you have copied the confi over, now restart mm again…
https://gyazo.com/14d8c30cc49ba12b849877d0b401a638
Just restarted, all the same… -
@goncalovsc ok, edit the config.js and show me the config for weatherforecast
@sdetweil ```
module: "currentweather", position: "top_right", config: { location: "Matosinhos", locationID: "2737824", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "b1f305ba796f09f236dfa60e45a8a8d8" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "Matosinhos", locationID: "2737824", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "b1f305ba796f09f236dfa60e45a8a8d8" } }, {
@goncalovsc ok, show the output of pm2 logs
[TAILING] Tailing last 15 lines for [all] processes (change the value with --lines option) /home/goncalo/.pm2/pm2.log last 15 lines: PM2 | 2020-04-04T17:04:39: PM2 log: Application log path : /home/goncalo/.pm2/logs PM2 | 2020-04-04T17:04:39: PM2 log: Worker Interval : 30000 PM2 | 2020-04-04T17:04:39: PM2 log: Process dump file : /home/goncalo/.pm2/dump.pm2 PM2 | 2020-04-04T17:04:39: PM2 log: Concurrent actions : 2 PM2 | 2020-04-04T17:04:39: PM2 log: SIGTERM timeout : 1600 PM2 | 2020-04-04T17:04:39: PM2 log: =============================================================================== PM2 | 2020-04-04T17:04:39: PM2 log: [Watch] Start watching MagicMirror PM2 | 2020-04-04T17:04:39: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T17:04:39: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T17:11:20: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T17:11:20: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T17:11:20: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T17:41:37: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T17:41:37: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T17:41:37: PM2 log: App [MagicMirror:0] online /home/goncalo/.pm2/logs/MagicMirror-error.log last 15 lines: 0|MagicMir | npm ERR! errno 1 0|MagicMir | npm ERR! magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js` 0|MagicMir | npm ERR! Exit status 1 0|MagicMir | npm ERR! 0|MagicMir | npm ERR! Failed at the magicmirror@2.11.0 start script. 0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above. 0|MagicMir | 0|MagicMir | npm ERR! A complete log of this run can be found in: 0|MagicMir | npm ERR! /home/goncalo/.npm/_logs/2020-04-04T16_02_55_422Z-debug.log 0|MagicMir | [1328:0404/170500.787870:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [1328:0404/170822.269139:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [1328:0404/171052.817336:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [1910:0404/171123.504386:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [1910:0404/174131.869273:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [2161:0404/174140.096920:ERROR:gles2_cmd_decoder.cc(2813)] [GroupMarkerNotSet(crbug.com/242999)!:B0305C06BA0D0000]GL ERROR :GL_INVALID_OPERATION : BackFramebuffer::Create: <- error from previous GL command /home/goncalo/.pm2/logs/MagicMirror-out.log last 15 lines: 0|MagicMir | [2020-04-04 17:41:39.247] [LOG] No helper found for module: weatherforecast. 0|MagicMir | [2020-04-04 17:41:39.266] [LOG] Initializing new module helper ... 0|MagicMir | [2020-04-04 17:41:39.266] [LOG] Module helper loaded: newsfeed 0|MagicMir | [2020-04-04 17:41:39.267] [LOG] All module helpers loaded. 0|MagicMir | [2020-04-04 17:41:39.350] [LOG] Starting server on port 8080 ... 0|MagicMir | [2020-04-04 17:41:39.361] [LOG] Server started ... 0|MagicMir | [2020-04-04 17:41:39.362] [LOG] Connecting socket for: updatenotification 0|MagicMir | [2020-04-04 17:41:39.363] [LOG] Connecting socket for: calendar 0|MagicMir | [2020-04-04 17:41:39.364] [LOG] Starting node helper for: calendar 0|MagicMir | [2020-04-04 17:41:39.364] [LOG] Connecting socket for: newsfeed 0|MagicMir | [2020-04-04 17:41:39.365] [LOG] Starting module: newsfeed 0|MagicMir | [2020-04-04 17:41:39.366] [LOG] Sockets connected & modules started ... 0|MagicMir | [2020-04-04 17:41:39.467] [LOG] Launching application. 0|MagicMir | [2020-04-04 17:41:40.947] [LOG] Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000 0|MagicMir | [2020-04-04 17:41:40.979] [LOG] Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
@goncalovsc sorry, not enough…
pm2 logs --lines=100
@sdetweil ```
[TAILING] Tailing last 100 lines for [all] processes (change the value with --lines option) /home/goncalo/.pm2/pm2.log last 100 lines: PM2 | 2020-04-04T14:28:57: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T14:28:57: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T14:28:57: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T14:29:01: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T14:29:01: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T14:29:01: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T14:29:04: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T14:29:04: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T14:29:04: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T14:29:08: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T14:29:08: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T14:29:08: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T14:29:12: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T14:29:12: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T14:29:12: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T14:29:15: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T14:29:15: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T14:29:15: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T14:29:20: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T14:29:20: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T14:29:20: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T14:29:23: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T14:29:23: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T14:29:23: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T14:29:27: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T14:29:27: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T14:29:27: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T14:29:30: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T14:29:30: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T14:29:30: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T14:29:35: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T14:29:35: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T14:29:35: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T15:12:19: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T15:12:19: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T15:12:19: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T15:13:12: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T15:13:12: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T15:13:12: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T15:14:55: PM2 log: =============================================================================== PM2 | 2020-04-04T15:14:55: PM2 log: --- New PM2 Daemon started ---------------------------------------------------- PM2 | 2020-04-04T15:14:55: PM2 log: Time : Sat Apr 04 2020 15:14:55 GMT+0100 (GMT+01:00) PM2 | 2020-04-04T15:14:55: PM2 log: PM2 version : 4.2.3 PM2 | 2020-04-04T15:14:55: PM2 log: Node.js version : 10.19.0 PM2 | 2020-04-04T15:14:55: PM2 log: Current arch : x64 PM2 | 2020-04-04T15:14:55: PM2 log: PM2 home : /home/goncalo/.pm2 PM2 | 2020-04-04T15:14:55: PM2 log: PM2 PID file : /home/goncalo/.pm2/pm2.pid PM2 | 2020-04-04T15:14:55: PM2 log: RPC socket file : /home/goncalo/.pm2/rpc.sock PM2 | 2020-04-04T15:14:55: PM2 log: BUS socket file : /home/goncalo/.pm2/pub.sock PM2 | 2020-04-04T15:14:55: PM2 log: Application log path : /home/goncalo/.pm2/logs PM2 | 2020-04-04T15:14:55: PM2 log: Worker Interval : 30000 PM2 | 2020-04-04T15:14:55: PM2 log: Process dump file : /home/goncalo/.pm2/dump.pm2 PM2 | 2020-04-04T15:14:55: PM2 log: Concurrent actions : 2 PM2 | 2020-04-04T15:14:55: PM2 log: SIGTERM timeout : 1600 PM2 | 2020-04-04T15:14:55: PM2 log: =============================================================================== PM2 | 2020-04-04T15:14:56: PM2 log: [Watch] Start watching MagicMirror PM2 | 2020-04-04T15:14:56: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T15:14:56: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T16:19:04: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T16:19:04: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T16:19:04: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T16:19:09: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T16:19:09: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T16:19:09: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T16:19:13: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T16:19:13: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T16:19:13: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T17:02:56: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT] PM2 | 2020-04-04T17:02:56: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T17:02:56: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T17:02:56: PM2 log: [Watch] Stop watching MagicMirror PM2 | 2020-04-04T17:02:56: PM2 log: Stopping app:MagicMirror id:0 PM2 | 2020-04-04T17:02:57: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T17:02:57: PM2 log: pid=3455 msg=process killed PM2 | 2020-04-04T17:02:57: PM2 log: PM2 successfully stopped PM2 | 2020-04-04T17:04:39: PM2 log: =============================================================================== PM2 | 2020-04-04T17:04:39: PM2 log: --- New PM2 Daemon started ---------------------------------------------------- PM2 | 2020-04-04T17:04:39: PM2 log: Time : Sat Apr 04 2020 17:04:39 GMT+0100 (GMT+01:00) PM2 | 2020-04-04T17:04:39: PM2 log: PM2 version : 4.2.3 PM2 | 2020-04-04T17:04:39: PM2 log: Node.js version : 10.19.0 PM2 | 2020-04-04T17:04:39: PM2 log: Current arch : x64 PM2 | 2020-04-04T17:04:39: PM2 log: PM2 home : /home/goncalo/.pm2 PM2 | 2020-04-04T17:04:39: PM2 log: PM2 PID file : /home/goncalo/.pm2/pm2.pid PM2 | 2020-04-04T17:04:39: PM2 log: RPC socket file : /home/goncalo/.pm2/rpc.sock PM2 | 2020-04-04T17:04:39: PM2 log: BUS socket file : /home/goncalo/.pm2/pub.sock PM2 | 2020-04-04T17:04:39: PM2 log: Application log path : /home/goncalo/.pm2/logs PM2 | 2020-04-04T17:04:39: PM2 log: Worker Interval : 30000 PM2 | 2020-04-04T17:04:39: PM2 log: Process dump file : /home/goncalo/.pm2/dump.pm2 PM2 | 2020-04-04T17:04:39: PM2 log: Concurrent actions : 2 PM2 | 2020-04-04T17:04:39: PM2 log: SIGTERM timeout : 1600 PM2 | 2020-04-04T17:04:39: PM2 log: =============================================================================== PM2 | 2020-04-04T17:04:39: PM2 log: [Watch] Start watching MagicMirror PM2 | 2020-04-04T17:04:39: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T17:04:39: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T17:11:20: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T17:11:20: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T17:11:20: PM2 log: App [MagicMirror:0] online PM2 | 2020-04-04T17:41:37: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2020-04-04T17:41:37: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2020-04-04T17:41:37: PM2 log: App [MagicMirror:0] online /home/goncalo/.pm2/logs/MagicMirror-error.log last 100 lines: 0|MagicMir | [6612:0404/142721.585053:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [6709:0404/142737.139705:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [6826:0404/142742.338033:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [6934:0404/142747.014390:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [7026:0404/142750.888066:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [7122:0404/142801.263869:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [7209:0404/142804.576839:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [7297:0404/142807.886502:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [7382:0404/142811.310855:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [7478:0404/142816.381604:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [7564:0404/142819.609241:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [7651:0404/142823.135608:ERROR:gles2_cmd_decoder.cc(2813)] [GroupMarkerNotSet(crbug.com/242999)!:B0300CD32B0B0000]GL ERROR :GL_INVALID_OPERATION : BackFramebuffer::Create: <- error from previous GL command 0|MagicMir | [7743:0404/142826.795105:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [7831:0404/142830.161364:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [7917:0404/142833.479148:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [8004:0404/142836.957122:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [8092:0404/142840.509743:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [8181:0404/142844.083279:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [8278:0404/142850.688290:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | events.js:177 0|MagicMir | throw er; // Unhandled 'error' event 0|MagicMir | ^ 0|MagicMir | 0|MagicMir | Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed 0|MagicMir | at doWrite (_stream_writable.js:413:19) 0|MagicMir | at writeOrBuffer (_stream_writable.js:401:5) 0|MagicMir | at Socket.Writable.write (_stream_writable.js:301:11) 0|MagicMir | at Object.con.<computed> [as error] (/home/goncalo/MagicMirror/node_modules/console-stamp/main.js:148:46) 0|MagicMir | at process.<anonymous> (/home/goncalo/MagicMirror/js/app.js:40:10) 0|MagicMir | at process.emit (events.js:205:15) 0|MagicMir | at process._fatalException (internal/process/execution.js:146:25) 0|MagicMir | npm ERR! code ELIFECYCLE 0|MagicMir | npm ERR! errno 7 0|MagicMir | npm ERR! magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js` 0|MagicMir | npm ERR! Exit status 7 0|MagicMir | npm ERR! 0|MagicMir | npm ERR! Failed at the magicmirror@2.11.0 start script. 0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above. 0|MagicMir | 0|MagicMir | npm ERR! A complete log of this run can be found in: 0|MagicMir | npm ERR! /home/goncalo/.npm/_logs/2020-04-04T13_28_52_135Z-debug.log 0|MagicMir | [8379:0404/142855.184640:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [8476:0404/142900.211922:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [8564:0404/142903.912353:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [8650:0404/142907.871859:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [8740:0404/142911.465724:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [8826:0404/142914.900168:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [8917:0404/142918.841951:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [9014:0404/142923.006450:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [9102:0404/142926.382507:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [9189:0404/142930.169180:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [9276:0404/142933.813284:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [9370:0404/142938.151378:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [9370:0404/151211.343083:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [21570:0404/151222.561248:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [1515:0404/151559.657406:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [1515:0404/161859.482017:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [2367:0404/161906.800560:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [2469:0404/161912.424475:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [2560:0404/161916.150005:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [2560:0404/163709.854468:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [2560:0404/170052.977585:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | npm ERR! code ELIFECYCLE 0|MagicMir | npm ERR! errno 1 0|MagicMir | npm ERR! magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js` 0|MagicMir | npm ERR! Exit status 1 0|MagicMir | npm ERR! 0|MagicMir | npm ERR! Failed at the magicmirror@2.11.0 start script. 0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above. 0|MagicMir | 0|MagicMir | npm ERR! A complete log of this run can be found in: 0|MagicMir | npm ERR! /home/goncalo/.npm/_logs/2020-04-04T16_02_55_422Z-debug.log 0|MagicMir | [1328:0404/170500.787870:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [1328:0404/170822.269139:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [1328:0404/171052.817336:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [1910:0404/171123.504386:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [1910:0404/174131.869273:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command 0|MagicMir | [2161:0404/174140.096920:ERROR:gles2_cmd_decoder.cc(2813)] [GroupMarkerNotSet(crbug.com/242999)!:B0305C06BA0D0000]GL ERROR :GL_INVALID_OPERATION : BackFramebuffer::Create: <- error from previous GL command /home/goncalo/.pm2/logs/MagicMirror-out.log last 100 lines: 0|MagicMir | > magicmirror@2.11.0 start /home/goncalo/MagicMirror 0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js 0|MagicMir | 0|MagicMir | [2020-04-04 17:04:45.945] [LOG] Starting MagicMirror: v2.11.0 0|MagicMir | [2020-04-04 17:04:45.953] [LOG] Loading config ... 0|MagicMir | [2020-04-04 17:04:45.958] [LOG] Loading module helpers ... 0|MagicMir | [2020-04-04 17:04:45.960] [LOG] No helper found for module: alert. 0|MagicMir | [2020-04-04 17:04:46.004] [LOG] Initializing new module helper ... 0|MagicMir | [2020-04-04 17:04:46.005] [LOG] Module helper loaded: updatenotification 0|MagicMir | [2020-04-04 17:04:46.006] [LOG] No helper found for module: clock. 0|MagicMir | [2020-04-04 17:04:49.767] [LOG] Initializing new module helper ... 0|MagicMir | [2020-04-04 17:04:49.767] [LOG] Module helper loaded: calendar 0|MagicMir | [2020-04-04 17:04:49.768] [LOG] No helper found for module: compliments. 0|MagicMir | [2020-04-04 17:04:49.768] [LOG] No helper found for module: currentweather. 0|MagicMir | [2020-04-04 17:04:49.769] [LOG] No helper found for module: weatherforecast. 0|MagicMir | [2020-04-04 17:04:50.305] [LOG] Initializing new module helper ... 0|MagicMir | [2020-04-04 17:04:50.306] [LOG] Module helper loaded: newsfeed 0|MagicMir | [2020-04-04 17:04:50.306] [LOG] All module helpers loaded. 0|MagicMir | [2020-04-04 17:04:52.640] [LOG] Starting server on port 8080 ... 0|MagicMir | [2020-04-04 17:04:52.791] [LOG] Server started ... 0|MagicMir | [2020-04-04 17:04:52.791] [LOG] Connecting socket for: updatenotification 0|MagicMir | [2020-04-04 17:04:52.792] [LOG] Connecting socket for: calendar 0|MagicMir | [2020-04-04 17:04:52.793] [LOG] Starting node helper for: calendar 0|MagicMir | [2020-04-04 17:04:52.794] [LOG] Connecting socket for: newsfeed 0|MagicMir | [2020-04-04 17:04:52.794] [LOG] Starting module: newsfeed 0|MagicMir | [2020-04-04 17:04:52.795] [LOG] Sockets connected & modules started ... 0|MagicMir | [2020-04-04 17:04:57.477] [LOG] Launching application. 0|MagicMir | [2020-04-04 17:05:13.853] [LOG] Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000 0|MagicMir | [2020-04-04 17:05:13.877] [LOG] Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000 0|MagicMir | [2020-04-04 17:08:23.461] [LOG] Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml 0|MagicMir | [2020-04-04 17:10:54.065] [LOG] Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml 0|MagicMir | [2020-04-04 17:11:20.441] [LOG] Shutting down server... 0|MagicMir | [2020-04-04 17:11:20.442] [LOG] Stopping module helper: updatenotification 0|MagicMir | [2020-04-04 17:11:20.442] [LOG] Stopping module helper: calendar 0|MagicMir | [2020-04-04 17:11:20.443] [LOG] Stopping module helper: newsfeed 0|MagicMir | 0|MagicMir | > magicmirror@2.11.0 start /home/goncalo/MagicMirror 0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js 0|MagicMir | 0|MagicMir | [2020-04-04 17:11:22.294] [LOG] Starting MagicMirror: v2.11.0 0|MagicMir | [2020-04-04 17:11:22.301] [LOG] Loading config ... 0|MagicMir | [2020-04-04 17:11:22.306] [LOG] Loading module helpers ... 0|MagicMir | [2020-04-04 17:11:22.308] [LOG] No helper found for module: alert. 0|MagicMir | [2020-04-04 17:11:22.343] [LOG] Initializing new module helper ... 0|MagicMir | [2020-04-04 17:11:22.344] [LOG] Module helper loaded: updatenotification 0|MagicMir | [2020-04-04 17:11:22.345] [LOG] No helper found for module: clock. 0|MagicMir | [2020-04-04 17:11:22.632] [LOG] Initializing new module helper ... 0|MagicMir | [2020-04-04 17:11:22.632] [LOG] Module helper loaded: calendar 0|MagicMir | [2020-04-04 17:11:22.633] [LOG] No helper found for module: compliments. 0|MagicMir | [2020-04-04 17:11:22.633] [LOG] No helper found for module: currentweather. 0|MagicMir | [2020-04-04 17:11:22.634] [LOG] No helper found for module: weatherforecast. 0|MagicMir | [2020-04-04 17:11:22.654] [LOG] Initializing new module helper ... 0|MagicMir | [2020-04-04 17:11:22.655] [LOG] Module helper loaded: newsfeed 0|MagicMir | [2020-04-04 17:11:22.655] [LOG] All module helpers loaded. 0|MagicMir | [2020-04-04 17:11:22.742] [LOG] Starting server on port 8080 ... 0|MagicMir | [2020-04-04 17:11:22.754] [LOG] Server started ... 0|MagicMir | [2020-04-04 17:11:22.754] [LOG] Connecting socket for: updatenotification 0|MagicMir | [2020-04-04 17:11:22.755] [LOG] Connecting socket for: calendar 0|MagicMir | [2020-04-04 17:11:22.756] [LOG] Starting node helper for: calendar 0|MagicMir | [2020-04-04 17:11:22.757] [LOG] Connecting socket for: newsfeed 0|MagicMir | [2020-04-04 17:11:22.757] [LOG] Starting module: newsfeed 0|MagicMir | [2020-04-04 17:11:22.758] [LOG] Sockets connected & modules started ... 0|MagicMir | [2020-04-04 17:11:22.879] [LOG] Launching application. 0|MagicMir | [2020-04-04 17:11:24.374] [LOG] Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000 0|MagicMir | [2020-04-04 17:11:24.480] [LOG] Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000 0|MagicMir | [2020-04-04 17:41:33.168] [LOG] Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml 0|MagicMir | [2020-04-04 17:41:37.073] [LOG] Shutting down server... 0|MagicMir | [2020-04-04 17:41:37.074] [LOG] Stopping module helper: updatenotification 0|MagicMir | [2020-04-04 17:41:37.075] [LOG] Stopping module helper: calendar 0|MagicMir | [2020-04-04 17:41:37.075] [LOG] Stopping module helper: newsfeed 0|MagicMir | 0|MagicMir | > magicmirror@2.11.0 start /home/goncalo/MagicMirror 0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js 0|MagicMir | 0|MagicMir | [2020-04-04 17:41:38.908] [LOG] Starting MagicMirror: v2.11.0 0|MagicMir | [2020-04-04 17:41:38.915] [LOG] Loading config ... 0|MagicMir | [2020-04-04 17:41:38.920] [LOG] Loading module helpers ... 0|MagicMir | [2020-04-04 17:41:38.922] [LOG] No helper found for module: alert. 0|MagicMir | [2020-04-04 17:41:38.956] [LOG] Initializing new module helper ... 0|MagicMir | [2020-04-04 17:41:38.956] [LOG] Module helper loaded: updatenotification 0|MagicMir | [2020-04-04 17:41:38.957] [LOG] No helper found for module: clock. 0|MagicMir | [2020-04-04 17:41:39.244] [LOG] Initializing new module helper ... 0|MagicMir | [2020-04-04 17:41:39.245] [LOG] Module helper loaded: calendar 0|MagicMir | [2020-04-04 17:41:39.245] [LOG] No helper found for module: compliments. 0|MagicMir | [2020-04-04 17:41:39.246] [LOG] No helper found for module: currentweather. 0|MagicMir | [2020-04-04 17:41:39.247] [LOG] No helper found for module: weatherforecast. 0|MagicMir | [2020-04-04 17:41:39.266] [LOG] Initializing new module helper ... 0|MagicMir | [2020-04-04 17:41:39.266] [LOG] Module helper loaded: newsfeed 0|MagicMir | [2020-04-04 17:41:39.267] [LOG] All module helpers loaded. 0|MagicMir | [2020-04-04 17:41:39.350] [LOG] Starting server on port 8080 ... 0|MagicMir | [2020-04-04 17:41:39.361] [LOG] Server started ... 0|MagicMir | [2020-04-04 17:41:39.362] [LOG] Connecting socket for: updatenotification 0|MagicMir | [2020-04-04 17:41:39.363] [LOG] Connecting socket for: calendar 0|MagicMir | [2020-04-04 17:41:39.364] [LOG] Starting node helper for: calendar 0|MagicMir | [2020-04-04 17:41:39.364] [LOG] Connecting socket for: newsfeed 0|MagicMir | [2020-04-04 17:41:39.365] [LOG] Starting module: newsfeed 0|MagicMir | [2020-04-04 17:41:39.366] [LOG] Sockets connected & modules started ... 0|MagicMir | [2020-04-04 17:41:39.467] [LOG] Launching application. 0|MagicMir | [2020-04-04 17:41:40.947] [LOG] Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000 0|MagicMir | [2020-04-04 17:41:40.979] [LOG] Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
@goncalovsc said in MM on Ubuntu:
0|MagicMir | [2020-04-04 17:41:39.247] [LOG] No helper found for module: weatherforecast.ok, the modules were started
i don’t understand why you are not seeing the output
