    MM on Ubuntu
    90 Posts 4 Posters 64.6k Views 4 Watching
    • G
      goncalovsc @sdetweil
      @sdetweil Should i reinstall? If its the easiest way i dont mind
        sdetweil @goncalovsc
        @goncalovsno…
        how do you start MM? pm2 or some other script?
        G 1 Reply Last reply
        • G
          @sdetweil Its with auto start activated
            @goncalovsc sorry, don’t understand that…
            if you used my script, it would have asked if you wanted to use pm2 to start on boot… (default answer is no)
            so, what script is executed on ‘autostart’?
            • G
              @sdetweil ahhh i think i said yes
                @goncalovsc so,
                pm2 status
                should show the definition
                anyhow, if you have copied the confi over, now restart mm again…
                • G
                  goncalovsc
                  https://gyazo.com/14d8c30cc49ba12b849877d0b401a638
                  Just restarted, all the same…
                    @goncalovsc ok, edit the config.js and show me the config for weatherforecast
                    • G
                      @sdetweil ```
                      	module: "currentweather",
                      				locationID: "2737824", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                      				appid: "b1f305ba796f09f236dfa60e45a8a8d8"
                      			module: "weatherforecast",
                      			header: "Weather Forecast",
                        @goncalovsc ok, show the output of pm2 logs
                        • G
                          /home/goncalo/.pm2/pm2.log last 15 lines:
                          PM2        | 2020-04-04T17:04:39: PM2 log: Application log path : /home/goncalo/.pm2/logs
                          PM2        | 2020-04-04T17:04:39: PM2 log: Worker Interval      : 30000
                          PM2        | 2020-04-04T17:04:39: PM2 log: Process dump file    : /home/goncalo/.pm2/dump.pm2
                          PM2        | 2020-04-04T17:04:39: PM2 log: Concurrent actions   : 2
                          PM2        | 2020-04-04T17:04:39: PM2 log: SIGTERM timeout      : 1600
                          PM2        | 2020-04-04T17:04:39: PM2 log: ===============================================================================
                          PM2        | 2020-04-04T17:04:39: PM2 log: [Watch] Start watching MagicMirror
                          PM2        | 2020-04-04T17:04:39: PM2 log: App [MagicMirror:0] starting in -fork mode-
                          PM2        | 2020-04-04T17:04:39: PM2 log: App [MagicMirror:0] online
                          PM2        | 2020-04-04T17:11:20: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                          PM2        | 2020-04-04T17:11:20: PM2 log: App [MagicMirror:0] starting in -fork mode-
                          PM2        | 2020-04-04T17:11:20: PM2 log: App [MagicMirror:0] online
                          PM2        | 2020-04-04T17:41:37: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                          PM2        | 2020-04-04T17:41:37: PM2 log: App [MagicMirror:0] starting in -fork mode-
                          PM2        | 2020-04-04T17:41:37: PM2 log: App [MagicMirror:0] online
                          /home/goncalo/.pm2/logs/MagicMirror-error.log last 15 lines:
                          0|MagicMir | npm ERR! errno 1
                          0|MagicMir | npm ERR! magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                          0|MagicMir | npm ERR! Exit status 1
                          0|MagicMir | npm ERR! Failed at the magicmirror@2.11.0 start script.
                          0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                          0|MagicMir |
                          0|MagicMir | npm ERR! A complete log of this run can be found in:
                          0|MagicMir | npm ERR!     /home/goncalo/.npm/_logs/2020-04-04T16_02_55_422Z-debug.log
                          0|MagicMir | [1328:0404/170500.787870:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                          0|MagicMir | [1328:0404/170822.269139:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                          0|MagicMir | [1328:0404/171052.817336:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                          0|MagicMir | [1910:0404/171123.504386:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                          0|MagicMir | [1910:0404/174131.869273:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                          0|MagicMir | [2161:0404/174140.096920:ERROR:gles2_cmd_decoder.cc(2813)] [GroupMarkerNotSet(crbug.com/242999)!:B0305C06BA0D0000]GL ERROR :GL_INVALID_OPERATION : BackFramebuffer::Create: <- error from previous GL command
                          /home/goncalo/.pm2/logs/MagicMirror-out.log last 15 lines:
                          0|MagicMir | [2020-04-04 17:41:39.247] [LOG]    No helper found for module: weatherforecast.
                          0|MagicMir | [2020-04-04 17:41:39.266] [LOG]    Initializing new module helper ...
                          0|MagicMir | [2020-04-04 17:41:39.266] [LOG]    Module helper loaded: newsfeed
                          0|MagicMir | [2020-04-04 17:41:39.267] [LOG]    All module helpers loaded.
                          0|MagicMir | [2020-04-04 17:41:39.350] [LOG]    Starting server on port 8080 ...
                          0|MagicMir | [2020-04-04 17:41:39.361] [LOG]    Server started ...
                          0|MagicMir | [2020-04-04 17:41:39.362] [LOG]    Connecting socket for: updatenotification
                          0|MagicMir | [2020-04-04 17:41:39.363] [LOG]    Connecting socket for: calendar
                          0|MagicMir | [2020-04-04 17:41:39.364] [LOG]    Starting node helper for: calendar
                          0|MagicMir | [2020-04-04 17:41:39.364] [LOG]    Connecting socket for: newsfeed
                          0|MagicMir | [2020-04-04 17:41:39.365] [LOG]    Starting module: newsfeed
                          0|MagicMir | [2020-04-04 17:41:39.366] [LOG]    Sockets connected & modules started ...
                          0|MagicMir | [2020-04-04 17:41:39.467] [LOG]    Launching application.
                          0|MagicMir | [2020-04-04 17:41:40.947] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                          0|MagicMir | [2020-04-04 17:41:40.979] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                            @goncalovsc sorry, not enough…
                            pm2 logs --lines=100
                            • G
                              @sdetweil ```
                              /home/goncalo/.pm2/pm2.log last 100 lines:
                              PM2        | 2020-04-04T14:28:57: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-04-04T14:28:57: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-04-04T14:28:57: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-04-04T14:29:01: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-04-04T14:29:01: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-04-04T14:29:01: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-04-04T14:29:04: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-04-04T14:29:04: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-04-04T14:29:04: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-04-04T14:29:08: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-04-04T14:29:08: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-04-04T14:29:08: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-04-04T14:29:12: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-04-04T14:29:12: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-04-04T14:29:12: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-04-04T14:29:15: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-04-04T14:29:15: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-04-04T14:29:15: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-04-04T14:29:20: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-04-04T14:29:20: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-04-04T14:29:20: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-04-04T14:29:23: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-04-04T14:29:23: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-04-04T14:29:23: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-04-04T14:29:27: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-04-04T14:29:27: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-04-04T14:29:27: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-04-04T14:29:30: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-04-04T14:29:30: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-04-04T14:29:30: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-04-04T14:29:35: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-04-04T14:29:35: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-04-04T14:29:35: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-04-04T15:12:19: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-04-04T15:12:19: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-04-04T15:12:19: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-04-04T15:13:12: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-04-04T15:13:12: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-04-04T15:13:12: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-04-04T15:14:55: PM2 log: ===============================================================================
                              PM2        | 2020-04-04T15:14:55: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                              PM2        | 2020-04-04T15:14:55: PM2 log: Time                 : Sat Apr 04 2020 15:14:55 GMT+0100 (GMT+01:00)
                              PM2        | 2020-04-04T15:14:55: PM2 log: PM2 version          : 4.2.3
                              PM2        | 2020-04-04T15:14:55: PM2 log: Node.js version      : 10.19.0
                              PM2        | 2020-04-04T15:14:55: PM2 log: Current arch         : x64
                              PM2        | 2020-04-04T15:14:55: PM2 log: PM2 home             : /home/goncalo/.pm2
                              PM2        | 2020-04-04T15:14:55: PM2 log: PM2 PID file         : /home/goncalo/.pm2/pm2.pid
                              PM2        | 2020-04-04T15:14:55: PM2 log: RPC socket file      : /home/goncalo/.pm2/rpc.sock
                              PM2        | 2020-04-04T15:14:55: PM2 log: BUS socket file      : /home/goncalo/.pm2/pub.sock
                              PM2        | 2020-04-04T15:14:55: PM2 log: Application log path : /home/goncalo/.pm2/logs
                              PM2        | 2020-04-04T15:14:55: PM2 log: Worker Interval      : 30000
                              PM2        | 2020-04-04T15:14:55: PM2 log: Process dump file    : /home/goncalo/.pm2/dump.pm2
                              PM2        | 2020-04-04T15:14:55: PM2 log: Concurrent actions   : 2
                              PM2        | 2020-04-04T15:14:55: PM2 log: SIGTERM timeout      : 1600
                              PM2        | 2020-04-04T15:14:56: PM2 log: [Watch] Start watching MagicMirror
                              PM2        | 2020-04-04T15:14:56: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-04-04T15:14:56: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-04-04T16:19:04: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-04-04T16:19:04: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-04-04T16:19:04: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-04-04T16:19:09: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-04-04T16:19:09: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-04-04T16:19:09: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-04-04T16:19:13: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-04-04T16:19:13: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-04-04T16:19:13: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-04-04T17:02:56: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                              PM2        | 2020-04-04T17:02:56: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-04-04T17:02:56: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-04-04T17:02:56: PM2 log: [Watch] Stop watching MagicMirror
                              PM2        | 2020-04-04T17:02:56: PM2 log: Stopping app:MagicMirror id:0
                              PM2        | 2020-04-04T17:02:57: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-04-04T17:02:57: PM2 log: pid=3455 msg=process killed
                              PM2        | 2020-04-04T17:02:57: PM2 log: PM2 successfully stopped
                              PM2        | 2020-04-04T17:04:39: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                              PM2        | 2020-04-04T17:04:39: PM2 log: Time                 : Sat Apr 04 2020 17:04:39 GMT+0100 (GMT+01:00)
                              PM2        | 2020-04-04T17:04:39: PM2 log: PM2 version          : 4.2.3
                              PM2        | 2020-04-04T17:04:39: PM2 log: Node.js version      : 10.19.0
                              PM2        | 2020-04-04T17:04:39: PM2 log: Current arch         : x64
                              PM2        | 2020-04-04T17:04:39: PM2 log: PM2 home             : /home/goncalo/.pm2
                              PM2        | 2020-04-04T17:04:39: PM2 log: PM2 PID file         : /home/goncalo/.pm2/pm2.pid
                              PM2        | 2020-04-04T17:04:39: PM2 log: RPC socket file      : /home/goncalo/.pm2/rpc.sock
                              PM2        | 2020-04-04T17:04:39: PM2 log: BUS socket file      : /home/goncalo/.pm2/pub.sock
                              /home/goncalo/.pm2/logs/MagicMirror-error.log last 100 lines:
                              0|MagicMir | [6612:0404/142721.585053:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [6709:0404/142737.139705:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [6826:0404/142742.338033:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [6934:0404/142747.014390:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [7026:0404/142750.888066:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [7122:0404/142801.263869:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [7209:0404/142804.576839:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [7297:0404/142807.886502:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [7382:0404/142811.310855:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [7478:0404/142816.381604:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [7564:0404/142819.609241:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [7651:0404/142823.135608:ERROR:gles2_cmd_decoder.cc(2813)] [GroupMarkerNotSet(crbug.com/242999)!:B0300CD32B0B0000]GL ERROR :GL_INVALID_OPERATION : BackFramebuffer::Create: <- error from previous GL command
                              0|MagicMir | [7743:0404/142826.795105:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [7831:0404/142830.161364:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [7917:0404/142833.479148:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [8004:0404/142836.957122:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [8092:0404/142840.509743:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [8181:0404/142844.083279:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [8278:0404/142850.688290:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | events.js:177
                              0|MagicMir |       throw er; // Unhandled 'error' event
                              0|MagicMir |       ^
                              0|MagicMir |
                              0|MagicMir | Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                              0|MagicMir |     at doWrite (_stream_writable.js:413:19)
                              0|MagicMir |     at writeOrBuffer (_stream_writable.js:401:5)
                              0|MagicMir |     at Socket.Writable.write (_stream_writable.js:301:11)
                              0|MagicMir |     at Object.con.<computed> [as error] (/home/goncalo/MagicMirror/node_modules/console-stamp/main.js:148:46)
                              0|MagicMir |     at process.<anonymous> (/home/goncalo/MagicMirror/js/app.js:40:10)
                              0|MagicMir |     at process.emit (events.js:205:15)
                              0|MagicMir |     at process._fatalException (internal/process/execution.js:146:25)
                              0|MagicMir | npm ERR! code ELIFECYCLE
                              0|MagicMir | npm ERR! errno 7
                              0|MagicMir | npm ERR! Exit status 7
                              0|MagicMir |
                              0|MagicMir | npm ERR!     /home/goncalo/.npm/_logs/2020-04-04T13_28_52_135Z-debug.log
                              0|MagicMir | [8379:0404/142855.184640:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [8476:0404/142900.211922:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [8564:0404/142903.912353:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [8650:0404/142907.871859:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [8740:0404/142911.465724:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [8826:0404/142914.900168:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [8917:0404/142918.841951:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [9014:0404/142923.006450:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [9102:0404/142926.382507:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [9189:0404/142930.169180:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [9276:0404/142933.813284:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [9370:0404/142938.151378:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [9370:0404/151211.343083:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [21570:0404/151222.561248:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [1515:0404/151559.657406:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [1515:0404/161859.482017:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [2367:0404/161906.800560:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [2469:0404/161912.424475:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [2560:0404/161916.150005:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [2560:0404/163709.854468:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir | [2560:0404/170052.977585:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
                              0|MagicMir |
                              /home/goncalo/.pm2/logs/MagicMirror-out.log last 100 lines:
                              0|MagicMir | > magicmirror@2.11.0 start /home/goncalo/MagicMirror
                              0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                              0|MagicMir |
                              0|MagicMir | [2020-04-04 17:04:45.945] [LOG]    Starting MagicMirror: v2.11.0
                              0|MagicMir | [2020-04-04 17:04:45.953] [LOG]    Loading config ...
                              0|MagicMir | [2020-04-04 17:04:45.958] [LOG]    Loading module helpers ...
                              0|MagicMir | [2020-04-04 17:04:45.960] [LOG]    No helper found for module: alert.
                              0|MagicMir | [2020-04-04 17:04:46.004] [LOG]    Initializing new module helper ...
                              0|MagicMir | [2020-04-04 17:04:46.005] [LOG]    Module helper loaded: updatenotification
                              0|MagicMir | [2020-04-04 17:04:46.006] [LOG]    No helper found for module: clock.
                              0|MagicMir | [2020-04-04 17:04:49.767] [LOG]    Initializing new module helper ...
                              0|MagicMir | [2020-04-04 17:04:49.767] [LOG]    Module helper loaded: calendar
                              0|MagicMir | [2020-04-04 17:04:49.768] [LOG]    No helper found for module: compliments.
                              0|MagicMir | [2020-04-04 17:04:49.768] [LOG]    No helper found for module: currentweather.
                              0|MagicMir | [2020-04-04 17:04:49.769] [LOG]    No helper found for module: weatherforecast.
                              0|MagicMir | [2020-04-04 17:04:50.305] [LOG]    Initializing new module helper ...
                              0|MagicMir | [2020-04-04 17:04:50.306] [LOG]    Module helper loaded: newsfeed
                              0|MagicMir | [2020-04-04 17:04:50.306] [LOG]    All module helpers loaded.
                              0|MagicMir | [2020-04-04 17:04:52.640] [LOG]    Starting server on port 8080 ...
                              0|MagicMir | [2020-04-04 17:04:52.791] [LOG]    Server started ...
                              0|MagicMir | [2020-04-04 17:04:52.791] [LOG]    Connecting socket for: updatenotification
                              0|MagicMir | [2020-04-04 17:04:52.792] [LOG]    Connecting socket for: calendar
                              0|MagicMir | [2020-04-04 17:04:52.793] [LOG]    Starting node helper for: calendar
                              0|MagicMir | [2020-04-04 17:04:52.794] [LOG]    Connecting socket for: newsfeed
                              0|MagicMir | [2020-04-04 17:04:52.794] [LOG]    Starting module: newsfeed
                              0|MagicMir | [2020-04-04 17:04:52.795] [LOG]    Sockets connected & modules started ...
                              0|MagicMir | [2020-04-04 17:04:57.477] [LOG]    Launching application.
                              0|MagicMir | [2020-04-04 17:05:13.853] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                              0|MagicMir | [2020-04-04 17:05:13.877] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                              0|MagicMir | [2020-04-04 17:08:23.461] [LOG]    Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml
                              0|MagicMir | [2020-04-04 17:10:54.065] [LOG]    Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml
                              0|MagicMir | [2020-04-04 17:11:20.441] [LOG]    Shutting down server...
                              0|MagicMir | [2020-04-04 17:11:20.442] [LOG]    Stopping module helper: updatenotification
                              0|MagicMir | [2020-04-04 17:11:20.442] [LOG]    Stopping module helper: calendar
                              0|MagicMir | [2020-04-04 17:11:20.443] [LOG]    Stopping module helper: newsfeed
                              0|MagicMir |
                              0|MagicMir |
                              0|MagicMir | [2020-04-04 17:11:22.294] [LOG]    Starting MagicMirror: v2.11.0
                              0|MagicMir | [2020-04-04 17:11:22.301] [LOG]    Loading config ...
                              0|MagicMir | [2020-04-04 17:11:22.306] [LOG]    Loading module helpers ...
                              0|MagicMir | [2020-04-04 17:11:22.308] [LOG]    No helper found for module: alert.
                              0|MagicMir | [2020-04-04 17:11:22.343] [LOG]    Initializing new module helper ...
                              0|MagicMir | [2020-04-04 17:11:22.344] [LOG]    Module helper loaded: updatenotification
                              0|MagicMir | [2020-04-04 17:11:22.345] [LOG]    No helper found for module: clock.
                              0|MagicMir | [2020-04-04 17:11:22.632] [LOG]    Initializing new module helper ...
                              0|MagicMir | [2020-04-04 17:11:22.632] [LOG]    Module helper loaded: calendar
                              0|MagicMir | [2020-04-04 17:11:22.633] [LOG]    No helper found for module: compliments.
                              0|MagicMir | [2020-04-04 17:11:22.633] [LOG]    No helper found for module: currentweather.
                              0|MagicMir | [2020-04-04 17:11:22.634] [LOG]    No helper found for module: weatherforecast.
                              0|MagicMir | [2020-04-04 17:11:22.654] [LOG]    Initializing new module helper ...
                              0|MagicMir | [2020-04-04 17:11:22.655] [LOG]    Module helper loaded: newsfeed
                              0|MagicMir | [2020-04-04 17:11:22.655] [LOG]    All module helpers loaded.
                              0|MagicMir | [2020-04-04 17:11:22.742] [LOG]    Starting server on port 8080 ...
                              0|MagicMir | [2020-04-04 17:11:22.754] [LOG]    Server started ...
                              0|MagicMir | [2020-04-04 17:11:22.754] [LOG]    Connecting socket for: updatenotification
                              0|MagicMir | [2020-04-04 17:11:22.755] [LOG]    Connecting socket for: calendar
                              0|MagicMir | [2020-04-04 17:11:22.756] [LOG]    Starting node helper for: calendar
                              0|MagicMir | [2020-04-04 17:11:22.757] [LOG]    Connecting socket for: newsfeed
                              0|MagicMir | [2020-04-04 17:11:22.757] [LOG]    Starting module: newsfeed
                              0|MagicMir | [2020-04-04 17:11:22.758] [LOG]    Sockets connected & modules started ...
                              0|MagicMir | [2020-04-04 17:11:22.879] [LOG]    Launching application.
                              0|MagicMir | [2020-04-04 17:11:24.374] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                              0|MagicMir | [2020-04-04 17:11:24.480] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                              0|MagicMir | [2020-04-04 17:41:33.168] [LOG]    Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml
                              0|MagicMir | [2020-04-04 17:41:37.073] [LOG]    Shutting down server...
                              0|MagicMir | [2020-04-04 17:41:37.074] [LOG]    Stopping module helper: updatenotification
                              0|MagicMir | [2020-04-04 17:41:37.075] [LOG]    Stopping module helper: calendar
                              0|MagicMir | [2020-04-04 17:41:37.075] [LOG]    Stopping module helper: newsfeed
                              0|MagicMir |
                              0|MagicMir |
                              0|MagicMir | [2020-04-04 17:41:38.908] [LOG]    Starting MagicMirror: v2.11.0
                              0|MagicMir | [2020-04-04 17:41:38.915] [LOG]    Loading config ...
                              0|MagicMir | [2020-04-04 17:41:38.920] [LOG]    Loading module helpers ...
                              0|MagicMir | [2020-04-04 17:41:38.922] [LOG]    No helper found for module: alert.
                              0|MagicMir | [2020-04-04 17:41:38.956] [LOG]    Initializing new module helper ...
                              0|MagicMir | [2020-04-04 17:41:38.956] [LOG]    Module helper loaded: updatenotification
                              0|MagicMir | [2020-04-04 17:41:38.957] [LOG]    No helper found for module: clock.
                              0|MagicMir | [2020-04-04 17:41:39.244] [LOG]    Initializing new module helper ...
                              0|MagicMir | [2020-04-04 17:41:39.245] [LOG]    Module helper loaded: calendar
                              0|MagicMir | [2020-04-04 17:41:39.245] [LOG]    No helper found for module: compliments.
                              0|MagicMir | [2020-04-04 17:41:39.246] [LOG]    No helper found for module: currentweather.
                                @goncalovsc said in MM on Ubuntu:
                                ok, the modules were started
                                i don’t understand why you are not seeing the output
                                • G
                                  @sdetweil its better to do a clean install?
                                    @goncalovsc sure, I guess, should be quick
                                    mv ~/MagicMirror ~/MagucMirror.old
                                    bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                    • G
                                      @sdetweil said in MM on Ubuntu:
                                      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
                                      Do you want use pm2 for auto starting of your MagicMirror (y/N)?
                                      Should I say no? last time i said yes
                                        @goncalovsc sure, yes
                                        • G
                                          @sdetweil Wait, sure to say no, or sure to say yes? :smiling_face_with_open_mouth_cold_sweat:
                                            @goncalovsc I said yes above
                                            • 3 / 5
