    MM on Ubuntu
    90 Posts 4 Posters 64.6k Views 4 Watching
    • G
      goncalovsc @sdetweil
      @sdetweil ```
      	module: "currentweather",
      				locationID: "2737824", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "b1f305ba796f09f236dfa60e45a8a8d8"
      			module: "weatherforecast",
      			header: "Weather Forecast",
        sdetweil @goncalovsc
        @goncalovsc ok, show the output of pm2 logs
        G 1 Reply Last reply
        • G
          /home/goncalo/.pm2/pm2.log last 15 lines:
          PM2        | 2020-04-04T17:04:39: PM2 log: Application log path : /home/goncalo/.pm2/logs
          PM2        | 2020-04-04T17:04:39: PM2 log: Worker Interval      : 30000
          PM2        | 2020-04-04T17:04:39: PM2 log: Process dump file    : /home/goncalo/.pm2/dump.pm2
          PM2        | 2020-04-04T17:04:39: PM2 log: Concurrent actions   : 2
          PM2        | 2020-04-04T17:04:39: PM2 log: SIGTERM timeout      : 1600
          PM2        | 2020-04-04T17:04:39: PM2 log: ===============================================================================
          PM2        | 2020-04-04T17:04:39: PM2 log: [Watch] Start watching MagicMirror
          PM2        | 2020-04-04T17:04:39: PM2 log: App [MagicMirror:0] starting in -fork mode-
          PM2        | 2020-04-04T17:04:39: PM2 log: App [MagicMirror:0] online
          PM2        | 2020-04-04T17:11:20: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
          PM2        | 2020-04-04T17:11:20: PM2 log: App [MagicMirror:0] starting in -fork mode-
          PM2        | 2020-04-04T17:11:20: PM2 log: App [MagicMirror:0] online
          PM2        | 2020-04-04T17:41:37: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
          PM2        | 2020-04-04T17:41:37: PM2 log: App [MagicMirror:0] starting in -fork mode-
          PM2        | 2020-04-04T17:41:37: PM2 log: App [MagicMirror:0] online
          /home/goncalo/.pm2/logs/MagicMirror-error.log last 15 lines:
          0|MagicMir | npm ERR! errno 1
          0|MagicMir | npm ERR! magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
          0|MagicMir | npm ERR! Exit status 1
          0|MagicMir | npm ERR! Failed at the magicmirror@2.11.0 start script.
          0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          0|MagicMir |
          0|MagicMir | npm ERR! A complete log of this run can be found in:
          0|MagicMir | npm ERR!     /home/goncalo/.npm/_logs/2020-04-04T16_02_55_422Z-debug.log
          0|MagicMir | [1328:0404/170500.787870:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
          0|MagicMir | [1328:0404/170822.269139:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
          0|MagicMir | [1328:0404/171052.817336:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
          0|MagicMir | [1910:0404/171123.504386:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
          0|MagicMir | [1910:0404/174131.869273:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
          0|MagicMir | [2161:0404/174140.096920:ERROR:gles2_cmd_decoder.cc(2813)] [GroupMarkerNotSet(crbug.com/242999)!:B0305C06BA0D0000]GL ERROR :GL_INVALID_OPERATION : BackFramebuffer::Create: <- error from previous GL command
          /home/goncalo/.pm2/logs/MagicMirror-out.log last 15 lines:
          0|MagicMir | [2020-04-04 17:41:39.247] [LOG]    No helper found for module: weatherforecast.
          0|MagicMir | [2020-04-04 17:41:39.266] [LOG]    Initializing new module helper ...
          0|MagicMir | [2020-04-04 17:41:39.266] [LOG]    Module helper loaded: newsfeed
          0|MagicMir | [2020-04-04 17:41:39.267] [LOG]    All module helpers loaded.
          0|MagicMir | [2020-04-04 17:41:39.350] [LOG]    Starting server on port 8080 ...
          0|MagicMir | [2020-04-04 17:41:39.361] [LOG]    Server started ...
          0|MagicMir | [2020-04-04 17:41:39.362] [LOG]    Connecting socket for: updatenotification
          0|MagicMir | [2020-04-04 17:41:39.363] [LOG]    Connecting socket for: calendar
          0|MagicMir | [2020-04-04 17:41:39.364] [LOG]    Starting node helper for: calendar
          0|MagicMir | [2020-04-04 17:41:39.364] [LOG]    Connecting socket for: newsfeed
          0|MagicMir | [2020-04-04 17:41:39.365] [LOG]    Starting module: newsfeed
          0|MagicMir | [2020-04-04 17:41:39.366] [LOG]    Sockets connected & modules started ...
          0|MagicMir | [2020-04-04 17:41:39.467] [LOG]    Launching application.
          0|MagicMir | [2020-04-04 17:41:40.947] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
          0|MagicMir | [2020-04-04 17:41:40.979] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
            @goncalovsc sorry, not enough…
            pm2 logs --lines=100
            • G
              @sdetweil ```
              /home/goncalo/.pm2/pm2.log last 100 lines:
              PM2        | 2020-04-04T14:28:57: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-04-04T14:28:57: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-04-04T14:28:57: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-04-04T14:29:01: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-04-04T14:29:01: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-04-04T14:29:01: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-04-04T14:29:04: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-04-04T14:29:04: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-04-04T14:29:04: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-04-04T14:29:08: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-04-04T14:29:08: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-04-04T14:29:08: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-04-04T14:29:12: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-04-04T14:29:12: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-04-04T14:29:12: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-04-04T14:29:15: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-04-04T14:29:15: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-04-04T14:29:15: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-04-04T14:29:20: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-04-04T14:29:20: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-04-04T14:29:20: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-04-04T14:29:23: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-04-04T14:29:23: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-04-04T14:29:23: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-04-04T14:29:27: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-04-04T14:29:27: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-04-04T14:29:27: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-04-04T14:29:30: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-04-04T14:29:30: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-04-04T14:29:30: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-04-04T14:29:35: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-04-04T14:29:35: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-04-04T14:29:35: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-04-04T15:12:19: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-04-04T15:12:19: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-04-04T15:12:19: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-04-04T15:13:12: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-04-04T15:13:12: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-04-04T15:13:12: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-04-04T15:14:55: PM2 log: ===============================================================================
              PM2        | 2020-04-04T15:14:55: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
              PM2        | 2020-04-04T15:14:55: PM2 log: Time                 : Sat Apr 04 2020 15:14:55 GMT+0100 (GMT+01:00)
              PM2        | 2020-04-04T15:14:55: PM2 log: PM2 version          : 4.2.3
              PM2        | 2020-04-04T15:14:55: PM2 log: Node.js version      : 10.19.0
              PM2        | 2020-04-04T15:14:55: PM2 log: Current arch         : x64
              PM2        | 2020-04-04T15:14:55: PM2 log: PM2 home             : /home/goncalo/.pm2
              PM2        | 2020-04-04T15:14:55: PM2 log: PM2 PID file         : /home/goncalo/.pm2/pm2.pid
              PM2        | 2020-04-04T15:14:55: PM2 log: RPC socket file      : /home/goncalo/.pm2/rpc.sock
              PM2        | 2020-04-04T15:14:55: PM2 log: BUS socket file      : /home/goncalo/.pm2/pub.sock
              PM2        | 2020-04-04T15:14:55: PM2 log: Application log path : /home/goncalo/.pm2/logs
              PM2        | 2020-04-04T15:14:55: PM2 log: Worker Interval      : 30000
              PM2        | 2020-04-04T15:14:55: PM2 log: Process dump file    : /home/goncalo/.pm2/dump.pm2
              PM2        | 2020-04-04T15:14:55: PM2 log: Concurrent actions   : 2
              PM2        | 2020-04-04T15:14:55: PM2 log: SIGTERM timeout      : 1600
              PM2        | 2020-04-04T15:14:56: PM2 log: [Watch] Start watching MagicMirror
              PM2        | 2020-04-04T15:14:56: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-04-04T15:14:56: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-04-04T16:19:04: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-04-04T16:19:04: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-04-04T16:19:04: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-04-04T16:19:09: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-04-04T16:19:09: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-04-04T16:19:09: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-04-04T16:19:13: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-04-04T16:19:13: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-04-04T16:19:13: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-04-04T17:02:56: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
              PM2        | 2020-04-04T17:02:56: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-04-04T17:02:56: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-04-04T17:02:56: PM2 log: [Watch] Stop watching MagicMirror
              PM2        | 2020-04-04T17:02:56: PM2 log: Stopping app:MagicMirror id:0
              PM2        | 2020-04-04T17:02:57: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-04-04T17:02:57: PM2 log: pid=3455 msg=process killed
              PM2        | 2020-04-04T17:02:57: PM2 log: PM2 successfully stopped
              PM2        | 2020-04-04T17:04:39: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
              PM2        | 2020-04-04T17:04:39: PM2 log: Time                 : Sat Apr 04 2020 17:04:39 GMT+0100 (GMT+01:00)
              PM2        | 2020-04-04T17:04:39: PM2 log: PM2 version          : 4.2.3
              PM2        | 2020-04-04T17:04:39: PM2 log: Node.js version      : 10.19.0
              PM2        | 2020-04-04T17:04:39: PM2 log: Current arch         : x64
              PM2        | 2020-04-04T17:04:39: PM2 log: PM2 home             : /home/goncalo/.pm2
              PM2        | 2020-04-04T17:04:39: PM2 log: PM2 PID file         : /home/goncalo/.pm2/pm2.pid
              PM2        | 2020-04-04T17:04:39: PM2 log: RPC socket file      : /home/goncalo/.pm2/rpc.sock
              PM2        | 2020-04-04T17:04:39: PM2 log: BUS socket file      : /home/goncalo/.pm2/pub.sock
              /home/goncalo/.pm2/logs/MagicMirror-error.log last 100 lines:
              0|MagicMir | [6612:0404/142721.585053:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [6709:0404/142737.139705:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [6826:0404/142742.338033:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [6934:0404/142747.014390:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [7026:0404/142750.888066:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [7122:0404/142801.263869:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [7209:0404/142804.576839:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [7297:0404/142807.886502:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [7382:0404/142811.310855:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [7478:0404/142816.381604:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [7564:0404/142819.609241:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [7651:0404/142823.135608:ERROR:gles2_cmd_decoder.cc(2813)] [GroupMarkerNotSet(crbug.com/242999)!:B0300CD32B0B0000]GL ERROR :GL_INVALID_OPERATION : BackFramebuffer::Create: <- error from previous GL command
              0|MagicMir | [7743:0404/142826.795105:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [7831:0404/142830.161364:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [7917:0404/142833.479148:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [8004:0404/142836.957122:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [8092:0404/142840.509743:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [8181:0404/142844.083279:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [8278:0404/142850.688290:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | events.js:177
              0|MagicMir |       throw er; // Unhandled 'error' event
              0|MagicMir |       ^
              0|MagicMir |
              0|MagicMir | Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
              0|MagicMir |     at doWrite (_stream_writable.js:413:19)
              0|MagicMir |     at writeOrBuffer (_stream_writable.js:401:5)
              0|MagicMir |     at Socket.Writable.write (_stream_writable.js:301:11)
              0|MagicMir |     at Object.con.<computed> [as error] (/home/goncalo/MagicMirror/node_modules/console-stamp/main.js:148:46)
              0|MagicMir |     at process.<anonymous> (/home/goncalo/MagicMirror/js/app.js:40:10)
              0|MagicMir |     at process.emit (events.js:205:15)
              0|MagicMir |     at process._fatalException (internal/process/execution.js:146:25)
              0|MagicMir | npm ERR! code ELIFECYCLE
              0|MagicMir | npm ERR! errno 7
              0|MagicMir | npm ERR! Exit status 7
              0|MagicMir |
              0|MagicMir | npm ERR!     /home/goncalo/.npm/_logs/2020-04-04T13_28_52_135Z-debug.log
              0|MagicMir | [8379:0404/142855.184640:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [8476:0404/142900.211922:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [8564:0404/142903.912353:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [8650:0404/142907.871859:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [8740:0404/142911.465724:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [8826:0404/142914.900168:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [8917:0404/142918.841951:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [9014:0404/142923.006450:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [9102:0404/142926.382507:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [9189:0404/142930.169180:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [9276:0404/142933.813284:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [9370:0404/142938.151378:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [9370:0404/151211.343083:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [21570:0404/151222.561248:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [1515:0404/151559.657406:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [1515:0404/161859.482017:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [2367:0404/161906.800560:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [2469:0404/161912.424475:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [2560:0404/161916.150005:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [2560:0404/163709.854468:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir | [2560:0404/170052.977585:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
              0|MagicMir |
              /home/goncalo/.pm2/logs/MagicMirror-out.log last 100 lines:
              0|MagicMir | > magicmirror@2.11.0 start /home/goncalo/MagicMirror
              0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
              0|MagicMir |
              0|MagicMir | [2020-04-04 17:04:45.945] [LOG]    Starting MagicMirror: v2.11.0
              0|MagicMir | [2020-04-04 17:04:45.953] [LOG]    Loading config ...
              0|MagicMir | [2020-04-04 17:04:45.958] [LOG]    Loading module helpers ...
              0|MagicMir | [2020-04-04 17:04:45.960] [LOG]    No helper found for module: alert.
              0|MagicMir | [2020-04-04 17:04:46.004] [LOG]    Initializing new module helper ...
              0|MagicMir | [2020-04-04 17:04:46.005] [LOG]    Module helper loaded: updatenotification
              0|MagicMir | [2020-04-04 17:04:46.006] [LOG]    No helper found for module: clock.
              0|MagicMir | [2020-04-04 17:04:49.767] [LOG]    Initializing new module helper ...
              0|MagicMir | [2020-04-04 17:04:49.767] [LOG]    Module helper loaded: calendar
              0|MagicMir | [2020-04-04 17:04:49.768] [LOG]    No helper found for module: compliments.
              0|MagicMir | [2020-04-04 17:04:49.768] [LOG]    No helper found for module: currentweather.
              0|MagicMir | [2020-04-04 17:04:49.769] [LOG]    No helper found for module: weatherforecast.
              0|MagicMir | [2020-04-04 17:04:50.305] [LOG]    Initializing new module helper ...
              0|MagicMir | [2020-04-04 17:04:50.306] [LOG]    Module helper loaded: newsfeed
              0|MagicMir | [2020-04-04 17:04:50.306] [LOG]    All module helpers loaded.
              0|MagicMir | [2020-04-04 17:04:52.640] [LOG]    Starting server on port 8080 ...
              0|MagicMir | [2020-04-04 17:04:52.791] [LOG]    Server started ...
              0|MagicMir | [2020-04-04 17:04:52.791] [LOG]    Connecting socket for: updatenotification
              0|MagicMir | [2020-04-04 17:04:52.792] [LOG]    Connecting socket for: calendar
              0|MagicMir | [2020-04-04 17:04:52.793] [LOG]    Starting node helper for: calendar
              0|MagicMir | [2020-04-04 17:04:52.794] [LOG]    Connecting socket for: newsfeed
              0|MagicMir | [2020-04-04 17:04:52.794] [LOG]    Starting module: newsfeed
              0|MagicMir | [2020-04-04 17:04:52.795] [LOG]    Sockets connected & modules started ...
              0|MagicMir | [2020-04-04 17:04:57.477] [LOG]    Launching application.
              0|MagicMir | [2020-04-04 17:05:13.853] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
              0|MagicMir | [2020-04-04 17:05:13.877] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
              0|MagicMir | [2020-04-04 17:08:23.461] [LOG]    Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml
              0|MagicMir | [2020-04-04 17:10:54.065] [LOG]    Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml
              0|MagicMir | [2020-04-04 17:11:20.441] [LOG]    Shutting down server...
              0|MagicMir | [2020-04-04 17:11:20.442] [LOG]    Stopping module helper: updatenotification
              0|MagicMir | [2020-04-04 17:11:20.442] [LOG]    Stopping module helper: calendar
              0|MagicMir | [2020-04-04 17:11:20.443] [LOG]    Stopping module helper: newsfeed
              0|MagicMir |
              0|MagicMir |
              0|MagicMir | [2020-04-04 17:11:22.294] [LOG]    Starting MagicMirror: v2.11.0
              0|MagicMir | [2020-04-04 17:11:22.301] [LOG]    Loading config ...
              0|MagicMir | [2020-04-04 17:11:22.306] [LOG]    Loading module helpers ...
              0|MagicMir | [2020-04-04 17:11:22.308] [LOG]    No helper found for module: alert.
              0|MagicMir | [2020-04-04 17:11:22.343] [LOG]    Initializing new module helper ...
              0|MagicMir | [2020-04-04 17:11:22.344] [LOG]    Module helper loaded: updatenotification
              0|MagicMir | [2020-04-04 17:11:22.345] [LOG]    No helper found for module: clock.
              0|MagicMir | [2020-04-04 17:11:22.632] [LOG]    Initializing new module helper ...
              0|MagicMir | [2020-04-04 17:11:22.632] [LOG]    Module helper loaded: calendar
              0|MagicMir | [2020-04-04 17:11:22.633] [LOG]    No helper found for module: compliments.
              0|MagicMir | [2020-04-04 17:11:22.633] [LOG]    No helper found for module: currentweather.
              0|MagicMir | [2020-04-04 17:11:22.634] [LOG]    No helper found for module: weatherforecast.
              0|MagicMir | [2020-04-04 17:11:22.654] [LOG]    Initializing new module helper ...
              0|MagicMir | [2020-04-04 17:11:22.655] [LOG]    Module helper loaded: newsfeed
              0|MagicMir | [2020-04-04 17:11:22.655] [LOG]    All module helpers loaded.
              0|MagicMir | [2020-04-04 17:11:22.742] [LOG]    Starting server on port 8080 ...
              0|MagicMir | [2020-04-04 17:11:22.754] [LOG]    Server started ...
              0|MagicMir | [2020-04-04 17:11:22.754] [LOG]    Connecting socket for: updatenotification
              0|MagicMir | [2020-04-04 17:11:22.755] [LOG]    Connecting socket for: calendar
              0|MagicMir | [2020-04-04 17:11:22.756] [LOG]    Starting node helper for: calendar
              0|MagicMir | [2020-04-04 17:11:22.757] [LOG]    Connecting socket for: newsfeed
              0|MagicMir | [2020-04-04 17:11:22.757] [LOG]    Starting module: newsfeed
              0|MagicMir | [2020-04-04 17:11:22.758] [LOG]    Sockets connected & modules started ...
              0|MagicMir | [2020-04-04 17:11:22.879] [LOG]    Launching application.
              0|MagicMir | [2020-04-04 17:11:24.374] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
              0|MagicMir | [2020-04-04 17:11:24.480] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
              0|MagicMir | [2020-04-04 17:41:33.168] [LOG]    Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml
              0|MagicMir | [2020-04-04 17:41:37.073] [LOG]    Shutting down server...
              0|MagicMir | [2020-04-04 17:41:37.074] [LOG]    Stopping module helper: updatenotification
              0|MagicMir | [2020-04-04 17:41:37.075] [LOG]    Stopping module helper: calendar
              0|MagicMir | [2020-04-04 17:41:37.075] [LOG]    Stopping module helper: newsfeed
              0|MagicMir |
              0|MagicMir |
              0|MagicMir | [2020-04-04 17:41:38.908] [LOG]    Starting MagicMirror: v2.11.0
              0|MagicMir | [2020-04-04 17:41:38.915] [LOG]    Loading config ...
              0|MagicMir | [2020-04-04 17:41:38.920] [LOG]    Loading module helpers ...
              0|MagicMir | [2020-04-04 17:41:38.922] [LOG]    No helper found for module: alert.
              0|MagicMir | [2020-04-04 17:41:38.956] [LOG]    Initializing new module helper ...
              0|MagicMir | [2020-04-04 17:41:38.956] [LOG]    Module helper loaded: updatenotification
              0|MagicMir | [2020-04-04 17:41:38.957] [LOG]    No helper found for module: clock.
              0|MagicMir | [2020-04-04 17:41:39.244] [LOG]    Initializing new module helper ...
              0|MagicMir | [2020-04-04 17:41:39.245] [LOG]    Module helper loaded: calendar
              0|MagicMir | [2020-04-04 17:41:39.245] [LOG]    No helper found for module: compliments.
              0|MagicMir | [2020-04-04 17:41:39.246] [LOG]    No helper found for module: currentweather.
                @goncalovsc said in MM on Ubuntu:
                ok, the modules were started
                i don’t understand why you are not seeing the output
                • G
                  @sdetweil its better to do a clean install?
                    @goncalovsc sure, I guess, should be quick
                    mv ~/MagicMirror ~/MagucMirror.old
                    bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                    • G
                      @sdetweil said in MM on Ubuntu:
                      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
                      Do you want use pm2 for auto starting of your MagicMirror (y/N)?
                      Should I say no? last time i said yes
                        @goncalovsc sure, yes
                        • G
                          @sdetweil Wait, sure to say no, or sure to say yes? :smiling_face_with_open_mouth_cold_sweat:
                            @goncalovsc I said yes above
                            • G
                              @sdetweil Aaaand its installed again
                              https://gyazo.com/5366b44db5c66b86c625afaf061573ff
                                @goncalovsc good, now edit the ~/MagicMirror/config/config.js and add the info for the two weather modules
                                then do pm2 restart 0
                                • G
                                  @sdetweil I opened the file and its already edited. I think its using the old files
                                    @goncalovsc no… if u moved the folder as in the instructions it would have pulled down a whole new copy
                                    show output of
                                    pm2 status
                                    pm2 show 0
                                    pm2 show 1
                                    • G
                                      @sdetweil I´ve ran exactly the commands that you said
                                      Sorry cant copy paste
                                      https://gyazo.com/623dd157c791ea2edc6c1526502a2927
                                      https://gyazo.com/b6df9267fe1b7fd23dd8b5afc18226d4
                                        @goncalovsc weird
                                        show
                                        cd MagicMirror/config
                                        ls -laF
                                        nano config.js
                                        ctrl-x to get out of nano
                                        • G
                                          @sdetweil Here the file isnt edited, its just like the sample :thinking_face:
                                            @goncalovsc as expected… u can do
                                            cd ~/MagicMirror/config
                                            cp ~/MagicMirror.old/config/config.js .
                                            nano config.js
                                            verify changes in config file
                                            • 3 / 5
