    MM on Ubuntu
    90 Posts 4 Posters 64.6k Views 4 Watching
    • G
      goncalovsc @sdetweil
      @sdetweil said in MM on Ubuntu:
      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
      Do you want use pm2 for auto starting of your MagicMirror (y/N)?
      Should I say no? last time i said yes
        sdetweil @goncalovsc
        @goncalovsc sure, yes
        G 1 Reply Last reply
        • G
          @sdetweil Wait, sure to say no, or sure to say yes? :smiling_face_with_open_mouth_cold_sweat:
            @goncalovsc I said yes above
            • G
              @sdetweil Aaaand its installed again
              https://gyazo.com/5366b44db5c66b86c625afaf061573ff
                @goncalovsc good, now edit the ~/MagicMirror/config/config.js and add the info for the two weather modules
                then do pm2 restart 0
                • G
                  @sdetweil I opened the file and its already edited. I think its using the old files
                    @goncalovsc no… if u moved the folder as in the instructions it would have pulled down a whole new copy
                    show output of
                    pm2 status
                    pm2 show 0
                    pm2 show 1
                    • G
                      @sdetweil I´ve ran exactly the commands that you said
                      Sorry cant copy paste
                      https://gyazo.com/623dd157c791ea2edc6c1526502a2927
                      https://gyazo.com/b6df9267fe1b7fd23dd8b5afc18226d4
                        @goncalovsc weird
                        show
                        cd MagicMirror/config
                        ls -laF
                        nano config.js
                        ctrl-x to get out of nano
                        • G
                          @sdetweil Here the file isnt edited, its just like the sample :thinking_face:
                            @goncalovsc as expected… u can do
                            cd ~/MagicMirror/config
                            cp ~/MagicMirror.old/config/config.js .
                            nano config.js
                            verify changes in config file
                            • G
                              When
                              Its says file or directory doesnt exist
                              — btw — edited on nano the file and worked
                                @goncalovsc said in MM on Ubuntu:
                                oops, typo on my previous command
                                ~/MagucMirror.old
                                woohoo…
                                G 2 Replies Last reply
                                • G
                                  @sdetweil now it opened, what im supposed to do with this one? How can i replace the old files? Its a bit weird seeing them on the GUI and cant edit them
                                  • G
                                    @sdetweil and btw, how can i solve this?
                                    https://gyazo.com/02cd494d4c3777805806e0c2be69a533
                                    already changed from UTF-8 to the other thats on the config but same result
                                      @goncalovsc u don’t need to do anything with the old ones… u edited the new one…
                                      if there is nothing else in the old, throw it away
                                      cd ~/
                                      rm -rf MagucMirror.old
                                        @goncalovsc sorry, no idea on the RSS feed
                                        • G
                                          @sdetweil deleted magucmirror.old and everything went back to zero, all the changes i´ve made :/
                                            @goncalovsc what?
                                            pm2 stop 0
                                            npm start
                                            • 4 / 5
