    MM on Ubuntu
    90 Posts 4 Posters 64.6k Views 4 Watching
      sdetweil @goncalovsc
      @goncalovsc good, now edit the ~/MagicMirror/config/config.js and add the info for the two weather modules
      then do pm2 restart 0
      G 1 Reply Last reply
      • G
        goncalovsc @sdetweil
        @sdetweil I opened the file and its already edited. I think its using the old files
          @goncalovsc no… if u moved the folder as in the instructions it would have pulled down a whole new copy
          show output of
          pm2 status
          pm2 show 0
          pm2 show 1
          • G
            @sdetweil I´ve ran exactly the commands that you said
            Sorry cant copy paste
            https://gyazo.com/623dd157c791ea2edc6c1526502a2927
            https://gyazo.com/b6df9267fe1b7fd23dd8b5afc18226d4
              @goncalovsc weird
              show
              cd MagicMirror/config
              ls -laF
              nano config.js
              ctrl-x to get out of nano
              • G
                @sdetweil Here the file isnt edited, its just like the sample :thinking_face:
                  @goncalovsc as expected… u can do
                  cd ~/MagicMirror/config
                  cp ~/MagicMirror.old/config/config.js .
                  nano config.js
                  verify changes in config file
                  • G
                    @sdetweil said in MM on Ubuntu:
                    When
                    Its says file or directory doesnt exist
                    — btw — edited on nano the file and worked
                      @goncalovsc said in MM on Ubuntu:
                      oops, typo on my previous command
                      ~/MagucMirror.old
                      woohoo…
                      G 2 Replies Last reply
                      • G
                        @sdetweil now it opened, what im supposed to do with this one? How can i replace the old files? Its a bit weird seeing them on the GUI and cant edit them
                        • G
                          @sdetweil and btw, how can i solve this?
                          https://gyazo.com/02cd494d4c3777805806e0c2be69a533
                          already changed from UTF-8 to the other thats on the config but same result
                            @goncalovsc u don’t need to do anything with the old ones… u edited the new one…
                            if there is nothing else in the old, throw it away
                            cd ~/
                            rm -rf MagucMirror.old
                              @goncalovsc sorry, no idea on the RSS feed
                              • G
                                @sdetweil deleted magucmirror.old and everything went back to zero, all the changes i´ve made :/
                                  @goncalovsc what?
                                  pm2 stop 0
                                  npm start
                                  • G
                                    @sdetweil Probably i was editing on the wrong files. Already re-edited on the correct ones. Thanks for your kind help
                                      dwburger
                                      My MM2 is running well under Ubuntu 18.04. I’ve installed pm2 and that works as well to start/stop MM2. However, I’m not able to get pm2 to work when using crontab. My crontab script looks like this:
                                      40 * * * * pm2 restart mm.sh
                                      so I can restart MM2 at 40 minutes after each hour. I don’t really plan to restart MM2 that often, I just want to get this working. I don’t know my way around Linux well enough to figure out what’s wrong. Can anyone point me to solution or an approach to one? Thanks!
                                        sdetweil @dwburger
                                        @dwburger what does crontab say when i tries to launch pm2?
                                          dwburger
                                          Well…I learned something. I didn’t know about crontab logs and I found this command to try:
                                          sudo grep CRON /var/log/syslog
                                          When I did that I found this line on the end of the log:
                                          Apr 24 10:40:01 dave-ubuntu CRON[2931]: (CRON) info (No MTA installed, discarding output)
                                          I guess I need to install an MTA???
                                            sdetweil @dwburger
                                            @dwburger said in MM on Ubuntu:
                                            see the last answer here
                                            https://superuser.com/questions/445347/why-is-my-crontab-not-running
                                            but that doesn’t some why pm2 was not executed
                                            note that you saved the pm2 config as user pi, and cron will run as root
                                            • 4 / 5
