    MM on Ubuntu
    90 Posts 4 Posters 64.6k Views 4 Watching
    • G
      goncalovsc @sdetweil
      @sdetweil Wait, sure to say no, or sure to say yes? :smiling_face_with_open_mouth_cold_sweat:
        sdetweil @goncalovsc
        @goncalovsc I said yes above
        G 1 Reply Last reply
        • G
          @sdetweil Aaaand its installed again
          https://gyazo.com/5366b44db5c66b86c625afaf061573ff
            @goncalovsc good, now edit the ~/MagicMirror/config/config.js and add the info for the two weather modules
            then do pm2 restart 0
            • G
              @sdetweil I opened the file and its already edited. I think its using the old files
                @goncalovsc no… if u moved the folder as in the instructions it would have pulled down a whole new copy
                show output of
                pm2 status
                pm2 show 0
                pm2 show 1
                • G
                  @sdetweil I´ve ran exactly the commands that you said
                  Sorry cant copy paste
                  https://gyazo.com/623dd157c791ea2edc6c1526502a2927
                  https://gyazo.com/b6df9267fe1b7fd23dd8b5afc18226d4
                    @goncalovsc weird
                    show
                    cd MagicMirror/config
                    ls -laF
                    nano config.js
                    ctrl-x to get out of nano
                    • G
                      @sdetweil Here the file isnt edited, its just like the sample :thinking_face:
                        @goncalovsc as expected… u can do
                        cd ~/MagicMirror/config
                        cp ~/MagicMirror.old/config/config.js .
                        nano config.js
                        verify changes in config file
                        • G
                          @sdetweil said in MM on Ubuntu:
                          When
                          Its says file or directory doesnt exist
                          — btw — edited on nano the file and worked
                            @goncalovsc said in MM on Ubuntu:
                            oops, typo on my previous command
                            ~/MagucMirror.old
                            woohoo…
                            G 2 Replies Last reply
                            • G
                              @sdetweil now it opened, what im supposed to do with this one? How can i replace the old files? Its a bit weird seeing them on the GUI and cant edit them
                              • G
                                @sdetweil and btw, how can i solve this?
                                https://gyazo.com/02cd494d4c3777805806e0c2be69a533
                                already changed from UTF-8 to the other thats on the config but same result
                                  @goncalovsc u don’t need to do anything with the old ones… u edited the new one…
                                  if there is nothing else in the old, throw it away
                                  cd ~/
                                  rm -rf MagucMirror.old
                                    @goncalovsc sorry, no idea on the RSS feed
                                    • G
                                      @sdetweil deleted magucmirror.old and everything went back to zero, all the changes i´ve made :/
                                        @goncalovsc what?
                                        pm2 stop 0
                                        npm start
                                        • G
                                          @sdetweil Probably i was editing on the wrong files. Already re-edited on the correct ones. Thanks for your kind help
                                            dwburger
                                            My MM2 is running well under Ubuntu 18.04. I’ve installed pm2 and that works as well to start/stop MM2. However, I’m not able to get pm2 to work when using crontab. My crontab script looks like this:
                                            40 * * * * pm2 restart mm.sh
                                            so I can restart MM2 at 40 minutes after each hour. I don’t really plan to restart MM2 that often, I just want to get this working. I don’t know my way around Linux well enough to figure out what’s wrong. Can anyone point me to solution or an approach to one? Thanks!
                                            • 4 / 5
