    MM on Ubuntu
    90 Posts 4 Posters 64.6k Views 4 Watching
      sdetweil @goncalovsc
      @goncalovsc said in MM on Ubuntu:
      0|MagicMir | [2020-04-04 17:41:39.246] [LOG] No helper found for module: currentweather.
      0|MagicMir | [2020-04-04 17:41:39.247] [LOG] No helper found for module: weatherforecast.
      ok, the modules were started
      i don’t understand why you are not seeing the output
      G 1 Reply Last reply
      • G
        goncalovsc @sdetweil
        @sdetweil its better to do a clean install?
          @goncalovsc sure, I guess, should be quick
          mv ~/MagicMirror ~/MagucMirror.old
          bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
          • G
            @sdetweil said in MM on Ubuntu:
            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
            Do you want use pm2 for auto starting of your MagicMirror (y/N)?
            Should I say no? last time i said yes
              @goncalovsc sure, yes
              • G
                @sdetweil Wait, sure to say no, or sure to say yes? :smiling_face_with_open_mouth_cold_sweat:
                  @goncalovsc I said yes above
                  • G
                    @sdetweil Aaaand its installed again
                    https://gyazo.com/5366b44db5c66b86c625afaf061573ff
                      @goncalovsc good, now edit the ~/MagicMirror/config/config.js and add the info for the two weather modules
                      then do pm2 restart 0
                      • G
                        @sdetweil I opened the file and its already edited. I think its using the old files
                          @goncalovsc no… if u moved the folder as in the instructions it would have pulled down a whole new copy
                          show output of
                          pm2 status
                          pm2 show 0
                          pm2 show 1
                          • G
                            @sdetweil I´ve ran exactly the commands that you said
                            Sorry cant copy paste
                            https://gyazo.com/623dd157c791ea2edc6c1526502a2927
                            https://gyazo.com/b6df9267fe1b7fd23dd8b5afc18226d4
                              @goncalovsc weird
                              show
                              cd MagicMirror/config
                              ls -laF
                              nano config.js
                              ctrl-x to get out of nano
                              • G
                                @sdetweil Here the file isnt edited, its just like the sample :thinking_face:
                                  @goncalovsc as expected… u can do
                                  cd ~/MagicMirror/config
                                  cp ~/MagicMirror.old/config/config.js .
                                  nano config.js
                                  verify changes in config file
                                  • G
                                    When
                                    Its says file or directory doesnt exist
                                    — btw — edited on nano the file and worked
                                      oops, typo on my previous command
                                      ~/MagucMirror.old
                                      woohoo…
                                      G 2 Replies Last reply
                                      • G
                                        @sdetweil now it opened, what im supposed to do with this one? How can i replace the old files? Its a bit weird seeing them on the GUI and cant edit them
                                        • G
                                          @sdetweil and btw, how can i solve this?
                                          https://gyazo.com/02cd494d4c3777805806e0c2be69a533
                                          already changed from UTF-8 to the other thats on the config but same result
                                            @goncalovsc u don’t need to do anything with the old ones… u edited the new one…
                                            if there is nothing else in the old, throw it away
                                            cd ~/
                                            rm -rf MagucMirror.old
                                            • 3 / 5
