    Black screen after update 2.11 (electron)
    24 Posts 2 Posters 7.2k Views 2 Watching
      Blackmirror @sdetweil
      sorry i have not all // delete from the MMM-Buttons module. It the same blank mirror.
      At I get the same errors in the MMM-Buttons module after npm install. Your script have not wrote that it is make npm install at the MMM-Buttons module
        sdetweil @Blackmirror
        @Blackmirror said in Black screen after update 2.11 (electron):
        MMM-Buttons
        it should, there is a package.json file present…
        please show me upgrade.log
        ~/MagicMirror/installers/upgrade.log
          Blackmirror
          Yes it have it.
          I can not open the log file.
          No authorization.
          S B 2 Replies Last reply
            @Blackmirror eh? was created in user name running the script
            please do
            ls -laF ~/MagicMirror/installers
            show results
              Blackmirror @Blackmirror
              Okay works if it run in single steps
              Upgrade started - Sa Apr  4 17:52:55 CEST 2020
              system is Linux Mirror 4.9.22-v7+ #987 SMP Fri Apr 14 23:23:05 BST 2017 armv7l GNU/L$
              the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 8.0 (jessie) Rele$
              user requested to force apply changes
              doing test run = false
              saving custom.css
              remote name = origin
              upgrading from version 2.11.0 to 2.11.0
              fetching latest revisions
              git fetch rc=0
              current branch = master
              On branch master
              Your branch is up-to-date with 'origin/master'.
                (use "git add <file>..." to update what will be committed)
                (use "git checkout -- <file>..." to discard changes in working directory)
                      modified:   package.json
              Untracked files:
                (use "git add <file>..." to include in what will be committed)
                      core
                      css/save_custom.css
                      modules/default/compliments/compliments.json
                @Blackmirror there should be more
                B 1 Reply Last reply
                  Untracked files:
                          core
                          css/save_custom.css
                  no changes added to commit (use "git add" and/or "git commit -a")
                  there are 1 local files that are different than the master repo
                     package.json
                  save/restore files selection = y
                  Saved working directory and index state WIP on master: 447c0bf Merge pull request #1968 from MichMich/develop
                  HEAD ist jetzt bei 447c0bf Merge pull request #1968 from MichMich/develop
                  test merge result rc='' , if empty, no conflicts
                  executing merge, apply specified
                  merge result rc= 0
                   Already up-to-date.
                  processor architecture is armv7l
                  > magicmirror@2.11.0 install /home/pi/MagicMirror
                  " && cd vendor && npm install --loglevel=error
                  > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
                  > npm run install-fonts && echo "MagicMirror installation finished successfully!
                  > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
                  > echo "Installing fonts ...
                  " && cd fonts && npm install --loglevel=error
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.1 (node_modules/chokidar/node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  npm WARN ws@7.2.3 requires a peer of bufferutil@^4.0.1 but none was installed.
                  npm WARN ws@7.2.3 requires a peer of utf-8-validate@^5.0.2 but none was installed.
                  npm install completed - Sa Apr  4 17:54:21 CEST 2020 on base
                  downloading dumpactivemodules script
                  processing for module MMM-Carousel please wait
                  processing complete for module MMM-Carousel
                  processing for module MMM-Podcast please wait
                  > Magic-Mirror-Module-Podcast@1.0.1 postinstall /home/pi/MagicMirror/modules/MMM-Podcast
                  > electron-rebuild -e ../../node_modules/electron
                  - Searching dependency tree
                  ✔ Rebuild Complete
                  processing complete for module MMM-Podcast
                  processing for module MMM-DWD-WarnWeather please wait
                  processing complete for module MMM-DWD-WarnWeather
                  processing for module MMM-Todoist please wait
                  processing complete for module MMM-Todoist
                  processing for module MMM-FRITZ-Box-Callmonitor please wait
                  processing complete for module MMM-FRITZ-Box-Callmonitor
                  processing for module MMM-RadioDe please wait
                  processing complete for module MMM-RadioDe
                  processing for module MMM-Fuel please wait
                  npm WARN eslint-config-airbnb-base@11.1.3 requires a peer of eslint@^3.19.0 but none was installed.
                  npm WARN eslint-plugin-import@2.2.0 requires a peer of eslint@2.x - 3.x but none was installed.
                  processing complete for module MMM-Fuel
                  restoring custom.css
                  removing git alias
                  we stashed a set of files that appear changed from the latest repo versions. you should review them
                  Upgrade ended - Sa Apr  4 17:55:24 CEST 2020
                  Upgrade started - Sa Apr  4 17:57:51 CEST 2020
                  system is Linux Mirror 4.9.22-v7+ #987 SMP Fri Apr 14 23:23:05 BST 2017 armv7l GNU/Linux
                  the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 8.0 (jessie) Release: 8.0 Codename: jessie
                  saving custom.css
                  git fetch rc=0
                  On branch master
                  Untracked files:
                          core
                          css/save_custom.css
                          installers/stashed_files
                  nothing added to commit but untracked files present (use "git add" to track)
                  no files different from github version
                  merge result rc= 0
                   Already up-to-date.
                  npm install completed - Sa Apr  4 17:58:55 CEST 2020 on base
                  no modules found needing npm refresh
                  removing git alias
                  Upgrade ended - Sa Apr  4 17:58:55 CEST 2020
                    @Blackmirror can u show me the config.js section for MMM-Button?
                    my code (dumpActiveModules.js) lists out the modules that are enabled…
                           module: 'MMM-Buttons',
                      //                        classes: 'default everyone',
                          minShortPressTime: 20,
                          bounceTimeout: 10,
                                   buttons: [
                                   pin: 10,
                                   longPress: {
                                            notification: "CURRENT_PROFILE",
                                          payload: "default"},
                                   shortPress: {
                                          payload: "Radio"}},
                                  pin: 11,
                                  longPress: {
                                    notification: "BUTTON_PRESSED",
                                    payload: true
                                 shortPress: {
                                    payload: true
                      But I think it have not update the MMM-Buttons because it was out comment.
                      I have your script restarted at now it comes the same error codes as I start npm install in the MMM-Buttons module
                        ok, that explains it.
                        lets try this
                        cd ~/MagicMirror/modules
                        mv MMM-Buttons MMM-Buttons.save
                        git clone https://github.com/Jopyth/MMM-Buttons.git
                        cd MMM-Buttons
                        npm install
                        it worked ok on my system
                          @sdetweil said in Black screen after update 2.11 (electron):
                          cd MMM-Buttons
                          npm install
                          Yes Thanks. It’s works.
                            @Blackmirror ok, I have fixed update to erase the old files (node_modules and package-lock.json) to force a different npm install
                            weird
                            thanks for your help and patience
