    MMM-GoogleFit
    Scheduled Pinned Locked Moved Health
    19 Posts 7 Posters 15.3k Views 8 Watching
    • A
      amcolash
      @nitram So glad to hear that things worked out smoothly - yeah forgot about renaming the file - sorry about that. Glad that you and your wife are liking this module! Cheers
        StacheEnthusiast
        I’m getting an auth error, “stats error”. I’ve followed the steps and MMM-GoogleFit shows up in my google apps with permissions. Any ideas?
        Edit: Update, The issue has resolved without me doing anything different so I’m not quite sure what the issue was but the module is working great. Thank you for this!
        • A
          amcolash
          @StacheEnthusiast: Made a github issue, I will respond in detail and help troubleshoot there.
          https://github.com/amcolash/MMM-GoogleFit/issues/4
          • T
            tismepaulo
            Thank you @amcolash I set this module up tonight. All working great, except when I edit chartWidth (to anything more than 360) to make it bigger, it cuts off part of the leftmost pie chart. It does this whether I’m using icons or not. I use it in bottom_center if that makes any difference. Any idea how to stop this happening? I’d like to have larger pies!
            • A
              amcolash @tismepaulo
              @tismepaulo: Please make a github issue so I can track this issue. Sorry for the late response, I just moved cross-country to Seattle.
                banbutcher
                hi,
                with the weights in Kgs… is it possible to have it to 1 decimal place?
                Thank you
                • MeidlmarkusM
                  Meidlmarkus
                  open: /home/pi/MagicMirror/modules/MMM-GoogleFit/MMM-GoogleFit.js in a notepad.
                  Change line 112 from
                  total = total.toFixed(0);
                  to
                  total = total.toFixed(1);
                  Just tried it out, it works (I also like it ;-) )
                  But please note that any change in a module will be overwritten as soon as you do an update of the module.
                  Cheers
                  Markus
                    banbutcher @Meidlmarkus
                    @Meidlmarkus
                    Awesome… thanks I’ll try it out soon! 😊
                    … worked like a charm! :)
                      banbutcher
                      another quick question… is it possible to have a graph of some sort weeky/monthly of weight?
                      i think i read on one of the new covid19 threads that this module has a graph function!?
                      thanks again
                      MeidlmarkusM 1 Reply Last reply Reply Quote 0
                      • MeidlmarkusM
                        Meidlmarkus @banbutcher
                        @banbutcher cool that you got it to work :-)
                        About weight graph: Well the GoogleFit module would have to be extended with this functionality, it would have to be coded (nothing that could be done with a quick fix, I’m afraid ;-) )
                          @Meidlmarkus
                          That’s what I thought, thanks for the reply!
