    electron.js HELP
    10 Posts 2 Posters 2.2k Views 2 Watching
      sdetweil @Manu85
      @Manu85 u can get the original back.
      erase electron.js or rename it
      Then
      git checkout js/electron.js
        Manu85
        @sdetweil thank you very much, it restarted !!!
        I was trying to fix an error on the module of @ mykle1 which recommended the following thing:
        Electron may hinder the use of autoplay. Known issue.
        This will fix it
        Edit MagicMirror/js/electron.js
        Add the line shown below
        let mainWindow;
        function createWindow() {
        app.commandLine.appendSwitch(‘autoplay-policy’, ‘no-user-gesture-required’); //< -------- added
        Save and restart MagicMirror
          sdetweil @Manu85
          @Manu85 u don’t need that. We added it a couple releases ago
            Manu85
            @sdetweil ok, the module crashes from time to time and I have a message telling me that I have an update problem (something like that) and I have a photo of the horizon with a sunset
              sdetweil @Manu85
              @Manu85 could you be a little more specific on the error… if using pm2 to start, show the part in the output from
              pm2 logs --lines=100
              the line
              only applies to video or audio files
                Manu85 @sdetweil
                @sdetweil you know me well :-)
                  Manu85
                  I don’t see this line!
                    sdetweil @Manu85
                    @Manu85 ver 2.11 direct from github
                    	app.commandLine.appendSwitch("autoplay-policy", "no-user-gesture-required");
                    I added that in ver 2.8 last year
                      Manu85
                      @sdetweil Thank you for your answer
