    MMM-AssistantMk2
    421 Posts 61 Posters 744.4k Views 57 Watching
      [[global:former-user]] @MisterT
      @MisterT
      Need a log to know what happens.
        MisterT @Guest
        @Sean after uninstall, re install, rebuilt electron from MK2 and from Hotword, it was always the same.
        So i decided to start a simple config.js with only default modules and Mk2 and hotword. Finaly…Tada !!! it works.
        The guilty module is MMM-GooglemapsTraffic. So I hid it in my config.js
        I have no console log about Mk2 if MMM-GooglemapsTraffic is on.
        Have you an idea?
          sdetweil @MisterT
          @MisterT said in MMM-AssistantMk2:
          yes, it has a bug, download the fixed version from my repo (the author has not updated from my changes, last updated 2 years ago)
          rename the existing module folder out of the way
          cd ~/MagicMirror/modules
          mv MMM-GooglemapsTraffic MMM-GooglemapsTraffic.original
          git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic.git
          cd MMM-GooglemapsTraffic
          npm install
            MisterT @sdetweil
            @sdetweil ok i installed MMM-GoogleMapsTraffic from your repo and i launched my MM. The result is :
            • MMM-MK2 works very well
            • MMM-GoogleMapsTraffic not works. I haven’t maps on the screen
            When i installed from your repo i had some “warn” message.See below
            npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
            npm notice created a lockfile as package-lock.json. You should commit this file.
            npm WARN grunt-stylelint@0.14.0 requires a peer of stylelint@^13.2.0 but none is installed. You must install peer dependencies yourself.
            npm WARN stylelint-config-standard@20.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
            npm WARN stylelint-config-recommended@3.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
            npm WARN MMM-GoogleMapsTraffic@1.0.0 No repository field.
            is it possible that these “warn” are the problem ?
            My config if need:
            module: 'MMM-GoogleMapsTraffic',
                     position: 'bottom_left',
                          key: 'xxxxxxxxx',
                           lat: 4x.470485,
                            lng: x.231369,
                            height: '300px',
                            width: '300px',
            		zoom: 14,
                            styledMapType: "transparent",
                            disableDefaultUI: true,
                            backgroundColor: 'hsla(0, 0%, 0%, 0)',
                            	markers: [
                                    lat: 4x.470485,
                                    lng: x.231369,
                                    fillColor: '#9966ff'
              sdetweil @MisterT
              @MisterT if you use the sample config with your apikey does it work? (my api key below)
              if you look at the console log, do you see any errors reported
              pm2 logs, if you use pm2 to start the mirror, else the terminal window where you do npm start
                          position: 'top_left',
                              key: 'AIzaSyCJyY3ijaw9X9xJis62XWsbz32PXIk8krI',     /// put your key here
                              lat: 37.8262306,
                              lng: -122.2920096,
                              height: '300px',
                              width: '300px'
                              markers: [
                                      lat: 37.8262316,
                                      lng: -122.2920196,
                MisterT
                @sdetweil everything is fine now :smiling_face_with_open_mouth_cold_sweat:
                With a lot of tests and modification in my confis.js, i forgot to enable MMM-GoogleMapsTraffic in MMM-Pages module config file :dizzy_face:
                So now it’s great
                Thx for your support
                See you next time
                • K Offline
                  kondef
                  @Sean thanks for your work in relationship with the google assisstant. I am quite new in all of these set ups and i am facing a problem now which i can’t by pass. I tried to Register-my-Mirror-as-Google-Assistant-related-device but when i insert the foolowing code :curl -s -X POST -H “Content-Type: application/json”
                  -H “Authorization: Bearer $ACCESSTOKEN” -d @deviceInstance.json
                  https://embeddedassistant.googleapis.com/v1alpha2/projects/YOUR_PROJECT_ID/devices/
                  i am getting the following error "bash: https://embeddedassistant.googleapis.com/v1alpha2/projects/(my_project_id)/devices/: No such file or directory
                  Do you have any idea how i can resolve that issue??
                  Thank you guys in advance
                    [[global:former-user]] @kondef
                    @kondef said in MMM-AssistantMk2:
                    This should be done in one line. I think you probably break line before https://embeddedassistant....
                      airart
                      where I find a different UI, maybe transparent, I saw bars and bubbles with a transparent background
                      thanks a lot and great job
                        banbutcher
                        howdy,
                        ive seen a couple of people running assistantmk2 v2 and i liked the interface better than the v3 and i was wondering if its possible to install the v2 instead of v3. how would i go about downgrading to v2?
                        thanks
                        Richie
                          acimail01
                          Can you trigger a sound output from a recipe while the Assistantmk2 is active?
                          For me sound output only works when the assistant is not active e.g. when I trigger sound output via web service (e.g. MMM-Sound or MMM-Text-To-Speech).
                          My use case is:
                          A recipe that listens to “mirror mirror on the wall” and then either plays an mp3 / wav or speak TTS
                            acimail01
                            does anyone have any idea how to trigger sound output with the Assitantmk2?
                              Mrtrol2013
                              Does this module support Russian?
                              • E Offline
                                Egnos
                                Hi guys!
                                first I would like to thank @Sean for the fantastic job.
                                MMM-AssistantMk2 works very well!
                                Has anyone ever commanded the pages of the MMM-Page-Selector module?
                                If yes, could you explain how to do it?
                                Thank you very much.
                                • 18
                                • 19
                                • 20
                                • 21
                                • 22
                                • 21 / 22
