    MMM-AssistantMk2
    421 Posts 61 Posters 796.8k Views 57 Watching
      A Former User @tontonchow
      @tontonchow
      Weird. Transcription on the log is returned as French as expected?
      T 1 Reply Last reply
      • T
        tontonchow @Guest
        @Sean Yes
        I don’t know why but it seems to work after adjust config.js and reboot
        add , after lang line
        profiles: {
                 "default" : {
                            profileFile: "default.json",
                            lang: "fr-FR",
        ? 1 Reply Last reply
          @tontonchow
          Can you show me the log of transcription part when you said some phrases as French? To see whether transcription was recognized as French or not.
            MisterT
            Hi Sean,
            Nice works for MK2 update but i have a problem to install it. I launched the auto installation but a packet is not found. gcc-7 is missing. when a try to install manually the answer is (in french):
            pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ sudo apt-get install gcc-7
            Lecture des listes de paquets... Fait
            Construction de l'arbre des dépendances
            Lecture des informations d'état... Fait
            E: Impossible de trouver le paquet gcc-7
            when i write gcc -v the result is:
            gcc version 6.3.0 20170516 (Raspbian 6.3.0-18+rpi1+deb9u1)
            And without this my Magic mirror turn into a black screen
            How i can install gcc-7 ?
            Do i need an update of raspbian to install gcc-7. I’m on last version of raspbian Stretch
            Thanks for your support and your next answers
              A Former User @MisterT
              @MisterT
              first, try to install without gcc7. usually gcc8 on buster was a reason of problem, so gcc6 on stretch might be ok(not tested currently but it worked a year ago)
                MisterT
                hi @Sean thanks for your reply. So retry auto installation with gc6 and rebuild electron. Then finish the config with my audio and mic. Great
                After these, i download my credentials then make my default profile.
                So everithing seem to bo good. that’t why i start MM and:
                MK2v3 logo is on my Magic mirror with animation but when i say a simple sentence, nothing happen.
                I changed hotword word to Jarvis and html5 to mpg321 but it’s the same thing.
                See below my config js for hotword and MK2
                	module: "MMM-Hotword",
                	useDisplay: false,
                	chimeOnFinish: null,
                	recipes: ["with-AMk2v3_Jarvis.js"],
                	mic: {
                		recordProgram: "arecord",
                		device: "plughw:1",
                  	module: "MMM-AssistantMk2",
                	debug: true,
                	 ui: "Classic",
                	assistantConfig: {
                	latitude: 43.64074, // -90.0 - +90.0
                	longitude: 5.09545, // -180.0 - +180.0
                	responseConfig: {
                	useHTML5: false, // sound render by HTML5
                	playProgram: "mpg321",
                	micConfig: {
                	recorder: "arecord",
                	device: "plughw:1",
                	recipes: [
                	"with-MMM-Hotword.js"
                	profiles: {
                	"default": {
                			lang: "fr-FR"
                have you an idea ?
                  @MisterT
                  Need a log to know what happens.
                  M 1 Reply Last reply
                    MisterT @Guest
                    @Sean after uninstall, re install, rebuilt electron from MK2 and from Hotword, it was always the same.
                    So i decided to start a simple config.js with only default modules and Mk2 and hotword. Finaly…Tada !!! it works.
                    The guilty module is MMM-GooglemapsTraffic. So I hid it in my config.js
                    I have no console log about Mk2 if MMM-GooglemapsTraffic is on.
                    Have you an idea?
                      sdetweil @MisterT
                      @MisterT said in MMM-AssistantMk2:
                      yes, it has a bug, download the fixed version from my repo (the author has not updated from my changes, last updated 2 years ago)
                      rename the existing module folder out of the way
                      cd ~/MagicMirror/modules
                      mv MMM-GooglemapsTraffic MMM-GooglemapsTraffic.original
                      git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic.git
                      cd MMM-GooglemapsTraffic
                      npm install
                        MisterT @sdetweil
                        @sdetweil ok i installed MMM-GoogleMapsTraffic from your repo and i launched my MM. The result is :
                        • MMM-MK2 works very well
                        • MMM-GoogleMapsTraffic not works. I haven’t maps on the screen
                        When i installed from your repo i had some “warn” message.See below
                        npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                        npm notice created a lockfile as package-lock.json. You should commit this file.
                        npm WARN grunt-stylelint@0.14.0 requires a peer of stylelint@^13.2.0 but none is installed. You must install peer dependencies yourself.
                        npm WARN stylelint-config-standard@20.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
                        npm WARN stylelint-config-recommended@3.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
                        npm WARN MMM-GoogleMapsTraffic@1.0.0 No repository field.
                        is it possible that these “warn” are the problem ?
                        My config if need:
                        module: 'MMM-GoogleMapsTraffic',
                                 position: 'bottom_left',
                                      key: 'xxxxxxxxx',
                                       lat: 4x.470485,
                                        lng: x.231369,
                                        height: '300px',
                                        width: '300px',
                        		zoom: 14,
                                        styledMapType: "transparent",
                                        disableDefaultUI: true,
                                        backgroundColor: 'hsla(0, 0%, 0%, 0)',
                                        	markers: [
                                                lat: 4x.470485,
                                                lng: x.231369,
                                                fillColor: '#9966ff'
                          sdetweil @MisterT
                          @MisterT if you use the sample config with your apikey does it work? (my api key below)
                          if you look at the console log, do you see any errors reported
                          pm2 logs, if you use pm2 to start the mirror, else the terminal window where you do npm start
                                      position: 'top_left',
                                          key: 'AIzaSyCJyY3ijaw9X9xJis62XWsbz32PXIk8krI',     /// put your key here
                                          lat: 37.8262306,
                                          lng: -122.2920096,
                                          height: '300px',
                                          width: '300px'
                                          markers: [
                                                  lat: 37.8262316,
                                                  lng: -122.2920196,
                            MisterT
                            @sdetweil everything is fine now :smiling_face_with_open_mouth_cold_sweat:
                            With a lot of tests and modification in my confis.js, i forgot to enable MMM-GoogleMapsTraffic in MMM-Pages module config file :dizzy_face:
                            So now it’s great
                            Thx for your support
                            See you next time
                            • K
                              kondef
                              @Sean thanks for your work in relationship with the google assisstant. I am quite new in all of these set ups and i am facing a problem now which i can’t by pass. I tried to Register-my-Mirror-as-Google-Assistant-related-device but when i insert the foolowing code :curl -s -X POST -H “Content-Type: application/json”
                              -H “Authorization: Bearer $ACCESSTOKEN” -d @deviceInstance.json
                              https://embeddedassistant.googleapis.com/v1alpha2/projects/YOUR_PROJECT_ID/devices/
                              i am getting the following error "bash: https://embeddedassistant.googleapis.com/v1alpha2/projects/(my_project_id)/devices/: No such file or directory
                              Do you have any idea how i can resolve that issue??
                              Thank you guys in advance
                                A Former User @kondef
                                @kondef said in MMM-AssistantMk2:
                                This should be done in one line. I think you probably break line before https://embeddedassistant....
                                • A
                                  airart
                                  where I find a different UI, maybe transparent, I saw bars and bubbles with a transparent background
                                  thanks a lot and great job
                                    banbutcher
                                    howdy,
                                    ive seen a couple of people running assistantmk2 v2 and i liked the interface better than the v3 and i was wondering if its possible to install the v2 instead of v3. how would i go about downgrading to v2?
                                    thanks
                                    Richie
                                    • A
                                      acimail01
                                      Can you trigger a sound output from a recipe while the Assistantmk2 is active?
                                      For me sound output only works when the assistant is not active e.g. when I trigger sound output via web service (e.g. MMM-Sound or MMM-Text-To-Speech).
                                      My use case is:
                                      A recipe that listens to “mirror mirror on the wall” and then either plays an mp3 / wav or speak TTS
                                      • A
                                        acimail01
                                        does anyone have any idea how to trigger sound output with the Assitantmk2?
                                          Mrtrol2013
                                          Does this module support Russian?
                                          • E
                                            Egnos
                                            Hi guys!
                                            first I would like to thank @Sean for the fantastic job.
                                            MMM-AssistantMk2 works very well!
                                            Has anyone ever commanded the pages of the MMM-Page-Selector module?
                                            If yes, could you explain how to do it?
                                            Thank you very much.
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 21 / 22
