    MMM-AssistantMk2
    421 Posts 61 Posters 761.7k Views 57 Watching
      A Former User @juantata
      @juantata
      If you have no unsatisfying or any issue with current version, You don’t need to update. Not for only this module, but for all modules of MagicMirror, and forMagicMirror itself. This is my personal recommendation.
      The error means you’d modified the source (Why?) Usually, a user doesn’t need to (SHOULDN’T) do modifying the source itself.
      Don’t do what you don’t understand.
      However you want to update anyway, just remove those files then git pull again. (If not work, try git stash)
        berne
        @Sean said in MMM-AssistantMk2:
        -Multi profile and language demo
        mmm so i can use google assistant and speak Swedish to it in the new mk2?
        if so… im going to make a new build
          A Former User @berne
          @berne
          Swedish is not supported by Google officially yet.
          https://developers.google.com/assistant/sdk/reference/rpc/languages
          • T Offline
            tontonchow
            Hi
            This module is fine but I I can’t get it to work in French. When I call “jarvis”, mk2 assistant don’t undertand french, only english. Someone have the same issue ?
              A Former User @tontonchow
              @tontonchow
              simply, adjust your account setting on your google assistant app of your smartphone.
              • T Offline
                tontonchow @Guest
                @Sean my app is correctly configure for me. If he don’t understand histoire reply is in french but if i speak french he don’t understand.
                Étrange
                  @tontonchow
                  Weird. Transcription on the log is returned as French as expected?
                  • T Offline
                    tontonchow @Guest
                    @Sean Yes
                    I don’t know why but it seems to work after adjust config.js and reboot
                    add , after lang line
                    profiles: {
                             "default" : {
                                        profileFile: "default.json",
                                        lang: "fr-FR",
                      @tontonchow
                      Can you show me the log of transcription part when you said some phrases as French? To see whether transcription was recognized as French or not.
                        MisterT
                        Hi Sean,
                        Nice works for MK2 update but i have a problem to install it. I launched the auto installation but a packet is not found. gcc-7 is missing. when a try to install manually the answer is (in french):
                        pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ sudo apt-get install gcc-7
                        Lecture des listes de paquets... Fait
                        Construction de l'arbre des dépendances
                        Lecture des informations d'état... Fait
                        E: Impossible de trouver le paquet gcc-7
                        when i write gcc -v the result is:
                        gcc version 6.3.0 20170516 (Raspbian 6.3.0-18+rpi1+deb9u1)
                        And without this my Magic mirror turn into a black screen
                        How i can install gcc-7 ?
                        Do i need an update of raspbian to install gcc-7. I’m on last version of raspbian Stretch
                        Thanks for your support and your next answers
                          A Former User @MisterT
                          @MisterT
                          first, try to install without gcc7. usually gcc8 on buster was a reason of problem, so gcc6 on stretch might be ok(not tested currently but it worked a year ago)
                            MisterT
                            hi @Sean thanks for your reply. So retry auto installation with gc6 and rebuild electron. Then finish the config with my audio and mic. Great
                            After these, i download my credentials then make my default profile.
                            So everithing seem to bo good. that’t why i start MM and:
                            MK2v3 logo is on my Magic mirror with animation but when i say a simple sentence, nothing happen.
                            I changed hotword word to Jarvis and html5 to mpg321 but it’s the same thing.
                            See below my config js for hotword and MK2
                            	module: "MMM-Hotword",
                            	useDisplay: false,
                            	chimeOnFinish: null,
                            	recipes: ["with-AMk2v3_Jarvis.js"],
                            	mic: {
                            		recordProgram: "arecord",
                            		device: "plughw:1",
                              	module: "MMM-AssistantMk2",
                            	debug: true,
                            	 ui: "Classic",
                            	assistantConfig: {
                            	latitude: 43.64074, // -90.0 - +90.0
                            	longitude: 5.09545, // -180.0 - +180.0
                            	responseConfig: {
                            	useHTML5: false, // sound render by HTML5
                            	playProgram: "mpg321",
                            	micConfig: {
                            	recorder: "arecord",
                            	device: "plughw:1",
                            	recipes: [
                            	"with-MMM-Hotword.js"
                            	profiles: {
                            	"default": {
                            			lang: "fr-FR"
                            have you an idea ?
                              @MisterT
                              Need a log to know what happens.
                                MisterT @Guest
                                @Sean after uninstall, re install, rebuilt electron from MK2 and from Hotword, it was always the same.
                                So i decided to start a simple config.js with only default modules and Mk2 and hotword. Finaly…Tada !!! it works.
                                The guilty module is MMM-GooglemapsTraffic. So I hid it in my config.js
                                I have no console log about Mk2 if MMM-GooglemapsTraffic is on.
                                Have you an idea?
                                  sdetweil @MisterT
                                  @MisterT said in MMM-AssistantMk2:
                                  yes, it has a bug, download the fixed version from my repo (the author has not updated from my changes, last updated 2 years ago)
                                  rename the existing module folder out of the way
                                  cd ~/MagicMirror/modules
                                  mv MMM-GooglemapsTraffic MMM-GooglemapsTraffic.original
                                  git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic.git
                                  cd MMM-GooglemapsTraffic
                                  npm install
                                    MisterT @sdetweil
                                    @sdetweil ok i installed MMM-GoogleMapsTraffic from your repo and i launched my MM. The result is :
                                    • MMM-MK2 works very well
                                    • MMM-GoogleMapsTraffic not works. I haven’t maps on the screen
                                    When i installed from your repo i had some “warn” message.See below
                                    npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                                    npm notice created a lockfile as package-lock.json. You should commit this file.
                                    npm WARN grunt-stylelint@0.14.0 requires a peer of stylelint@^13.2.0 but none is installed. You must install peer dependencies yourself.
                                    npm WARN stylelint-config-standard@20.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
                                    npm WARN stylelint-config-recommended@3.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
                                    npm WARN MMM-GoogleMapsTraffic@1.0.0 No repository field.
                                    is it possible that these “warn” are the problem ?
                                    My config if need:
                                    module: 'MMM-GoogleMapsTraffic',
                                             position: 'bottom_left',
                                                  key: 'xxxxxxxxx',
                                                   lat: 4x.470485,
                                                    lng: x.231369,
                                                    height: '300px',
                                                    width: '300px',
                                    		zoom: 14,
                                                    styledMapType: "transparent",
                                                    disableDefaultUI: true,
                                                    backgroundColor: 'hsla(0, 0%, 0%, 0)',
                                                    	markers: [
                                                            lat: 4x.470485,
                                                            lng: x.231369,
                                                            fillColor: '#9966ff'
                                      sdetweil @MisterT
                                      @MisterT if you use the sample config with your apikey does it work? (my api key below)
                                      if you look at the console log, do you see any errors reported
                                      pm2 logs, if you use pm2 to start the mirror, else the terminal window where you do npm start
                                                  position: 'top_left',
                                                      key: 'AIzaSyCJyY3ijaw9X9xJis62XWsbz32PXIk8krI',     /// put your key here
                                                      lat: 37.8262306,
                                                      lng: -122.2920096,
                                                      height: '300px',
                                                      width: '300px'
                                                      markers: [
                                                              lat: 37.8262316,
                                                              lng: -122.2920196,
                                        MisterT
                                        @sdetweil everything is fine now :smiling_face_with_open_mouth_cold_sweat:
                                        With a lot of tests and modification in my confis.js, i forgot to enable MMM-GoogleMapsTraffic in MMM-Pages module config file :dizzy_face:
                                        So now it’s great
                                        Thx for your support
                                        See you next time
                                        • K Offline
                                          kondef
                                          @Sean thanks for your work in relationship with the google assisstant. I am quite new in all of these set ups and i am facing a problem now which i can’t by pass. I tried to Register-my-Mirror-as-Google-Assistant-related-device but when i insert the foolowing code :curl -s -X POST -H “Content-Type: application/json”
                                          -H “Authorization: Bearer $ACCESSTOKEN” -d @deviceInstance.json
                                          https://embeddedassistant.googleapis.com/v1alpha2/projects/YOUR_PROJECT_ID/devices/
                                          i am getting the following error "bash: https://embeddedassistant.googleapis.com/v1alpha2/projects/(my_project_id)/devices/: No such file or directory
                                          Do you have any idea how i can resolve that issue??
                                          Thank you guys in advance
                                            A Former User @kondef
                                            @kondef said in MMM-AssistantMk2:
                                            This should be done in one line. I think you probably break line before https://embeddedassistant....
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 21 / 22
