    MMM-AssistantMk2
    421 Posts 61 Posters 796.8k Views 57 Watching
      sdetweil @MisterT
      @MisterT if you use the sample config with your apikey does it work? (my api key below)
      if you look at the console log, do you see any errors reported
      pm2 logs, if you use pm2 to start the mirror, else the terminal window where you do npm start
                  module: 'MMM-GoogleMapsTraffic',
                  position: 'top_left',
                      key: 'AIzaSyCJyY3ijaw9X9xJis62XWsbz32PXIk8krI',     /// put your key here
                      lat: 37.8262306,
                      lng: -122.2920096,
                      height: '300px',
                      width: '300px'
                      styledMapType: "transparent",
                      disableDefaultUI: true,
                      backgroundColor: 'hsla(0, 0%, 0%, 0)',
                      markers: [
                              lat: 37.8262316,
                              lng: -122.2920196,
                              fillColor: '#9966ff'
        MisterT
        @sdetweil everything is fine now :smiling_face_with_open_mouth_cold_sweat:
        With a lot of tests and modification in my confis.js, i forgot to enable MMM-GoogleMapsTraffic in MMM-Pages module config file :dizzy_face:
        So now it’s great
        Thx for your support
        See you next time
        • K
          kondef
          @Sean thanks for your work in relationship with the google assisstant. I am quite new in all of these set ups and i am facing a problem now which i can’t by pass. I tried to Register-my-Mirror-as-Google-Assistant-related-device but when i insert the foolowing code :curl -s -X POST -H “Content-Type: application/json”
          -H “Authorization: Bearer $ACCESSTOKEN” -d @deviceInstance.json
          https://embeddedassistant.googleapis.com/v1alpha2/projects/YOUR_PROJECT_ID/devices/
          i am getting the following error "bash: https://embeddedassistant.googleapis.com/v1alpha2/projects/(my_project_id)/devices/: No such file or directory
          Do you have any idea how i can resolve that issue??
          Thank you guys in advance
          ? 1 Reply Last reply
            A Former User @kondef
            @kondef said in MMM-AssistantMk2:
            This should be done in one line. I think you probably break line before https://embeddedassistant....
            • A
              airart
              where I find a different UI, maybe transparent, I saw bars and bubbles with a transparent background
              thanks a lot and great job
                banbutcher
                howdy,
                ive seen a couple of people running assistantmk2 v2 and i liked the interface better than the v3 and i was wondering if its possible to install the v2 instead of v3. how would i go about downgrading to v2?
                thanks
                Richie
                • A
                  acimail01
                  Can you trigger a sound output from a recipe while the Assistantmk2 is active?
                  For me sound output only works when the assistant is not active e.g. when I trigger sound output via web service (e.g. MMM-Sound or MMM-Text-To-Speech).
                  My use case is:
                  A recipe that listens to “mirror mirror on the wall” and then either plays an mp3 / wav or speak TTS
                  • A
                    acimail01
                    does anyone have any idea how to trigger sound output with the Assitantmk2?
                      Mrtrol2013
                      Does this module support Russian?
                      • E
                        Egnos
                        Hi guys!
                        first I would like to thank @Sean for the fantastic job.
                        MMM-AssistantMk2 works very well!
                        Has anyone ever commanded the pages of the MMM-Page-Selector module?
                        If yes, could you explain how to do it?
                        Thank you very much.
                        • 18
                        • 19
                        • 20
                        • 21
                        • 22
                        • 22 / 22
