    Word Clock Screensaver
    7 Posts 3 Posters 5.0k Views 3 Watching
    • SnilleS Offline
      Snille Module Developer @j.e.f.f
      @j.e.f.f Hi! You can use the MMM-TextClock to what you want. Then use the MMM-ModuleScheduler to set the time when it should be displayed. :)
      If you cant find it, make it and share it!
      Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
        j.e.f.f Project Sponsor Module Developer @Snille
        @Snille That is amazing!
        One question: I don’t want to schedule it, per se, but I’d like it to appear after, say, ten minutes of no motion detected, and hide again when the PIR sensor detects motion. Is this possible out of the box or would I need to write something custom to do this? (I’m already using a customized version of MMM-PIRSensor to control the screensaver and monitor power-off, so I suppose this shouldn’t be a big deal).
        SnilleS 1 Reply Last reply Reply Quote 0
        • SnilleS Offline
          @j.e.f.f said in Word Clock Screensaver:
          Hmm… I think you can do it with the MMM-RemoteControl you can send the remote strings to hide and show stuff using the “modified” pir. :)
            airart
            did you manage to do what you wanted? I am in the same situation and I use a usb camera for motion detect
            I would like the module with the clock to be full screen when no one is in front, then with the PS3 USB camera when someone is in front of the MM bring up all the modules.
            I have already installed MMM-motiondetector
              j.e.f.f Project Sponsor Module Developer @airart
              @airart No need to do anything fancy. I ended up writing my own word clock module and made work with the MMM-PIR-Sensor natively. You just specify the timeout in your config. with the showClockTimeOut parameter. That’s how long there needs to be no motion detected for the clock to show.
              Example:
                module: "MMM-MyWordClock",
                position: "fullscreen_above",
                  showClockTimeOut: 5 * 60 * 1000, //5 minutes
                  language: "EN",
                  orientation: "tall"
              Download MMM-MyWordClock here:
              https://github.com/jclarke0000/MMM-MyWordClock
