    Can't clone from GitHub
    107 Posts 3 Posters 71.5k Views 3 Watching
      sdetweil @MMRPi1
      @MMRPi1 ok, there was another person that had a similar problem and there was an extra . On the end of the url
        MMRPi1 @sdetweil
        @sdetweil Oh alright. I think the issue here is somewhat security related but I could be wrong.
        Not sure what to do about it though. Since I’ve been able to update MM and also add new modules in the past.
          sdetweil @MMRPi1
          @MMRPi1 some folks are experiencing this cause their antivirus live protection has downlevel tls (https) support
          https://github.community/t5/How-to-use-Git-and-GitHub/Unable-to-Push-to-repo-gnutls-handshake-failed/td-p/6584/page/2
            MMRPi1 @sdetweil
            @sdetweil Hmm, tried disabling my Antivirus but I still got the same error.
              MMRPi1 @sdetweil
              @sdetweil Do you know what else might be the problem?
                sdetweil @MMRPi1
                @MMRPi1 no… not really…
                so when u go to clone, you open the project github page, push the green clone or download button mid page right, then push the copy button next to the url, right?
                then open the terminal window and type git clone
                and then paste in the url just copied…
                lets try to get one file, not using git
                curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/dumpactivemodules.js >dumpactivemodules.js
                should produce a tiny js file
                  MMRPi1 @sdetweil
                  @sdetweil I think that worked
                    this link says it might be a library update
                    are you on windows or linux?
                    for linux
                    https://stackoverflow.com/questions/52379234/gnutls-handshake-failed-error-in-the-pull-function
                    circa 2019…
                    for windows, do you use a proxy to access the network?
                      MMRPi1 @sdetweil
                      @sdetweil I’m using SSH on Windows to access the pi (Linux obviously). I tried on the pi as well but I got the same error.
                      I tried the advice on stack overflow but got the same error.
                        sdetweil @MMRPi1
                        @MMRPi1 how do you connect to the internet?
                        • 10
                        • 11
                        • 1 / 11
