    Weird display error?
    4 Posts 2 Posters 885 Views 2 Watching
    • N Offline
      nakulbende
      Hello, npm start in my magicmirror directory crashes and has this output:
       npm start
      > magicmirror@2.11.0 start /home/pi/MagicMirror
      internal/stream_base_commons.js:141
      function afterWritgDaspaôched(self, r%q, erz>cb; {
      SyntaxError: Unexpected token %
          at NativeModule.compile (internal/bootstrap/loaders.js:303:16)
          at nativeModuleRequire (internal/bootstrap/loaders.js:191:14)
          at net.js:71:5
          at NativeModule.compile (internal/bootstrap/loaders.js:304:5)
          at internal/child_process.js:21:13
          at child_process.js:44:23
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.11.0 start script.
      npm ERR!     /home/pi/.npm/_logs/2020-04-14T14_22_02_210Z-debug.log
      • N Offline
        nakulbende
        Huh, i removed all the overscan settings from boot/config.txt and it worked! But now I have a border on left side of my mirror which is not being displayed.
          @nakulbende said in Weird display error?:
          I think you are starting to experience SD card failures…
          that function name should not have accent characters
          • N Offline
            nakulbende @sdetweil
            @sdetweil Oh no - I did had a corruption, I formatted and reinstalled everything again. Time for a backup!
