    Recipes not loading MMM-AssistantMK2
    3 Posts 2 Posters 579 Views 2 Watching
    • F
      Faiek
      Hi guys really needing some help here.
      Recently upgrade use to work well
      My recipes is not loading - cant see them loaded in the logs.
      No response with assistant .
      Re-Loaded my entire mirror twice hoping to fix this.
      Any help will be appreciated
      My Config : ```
      			module: "MMM-AssistantMk2",
      			    ui: "Classic",
      			    assistantConfig: {
      			      latitude: -26.104611,
      			      longitude: 27.955034,
      			micConfig: { // put there configuration generated by auto-installer
      			      recorder: "arecord",
      			      device: "plughw:1",
      			 recipes: ["with-MMM-Hotword.js","with-MMM-Spotify","with-MMM-Youtube","Reboot-Restart-Shutdown"],
      			    profiles: {
      			      "default": {
      				profileFile: "default.json",
      				lang: "en-US"
      			    useA2D: false,
      		       module: "MMM-Hotword",
      		       position: "bottom_left",
      		        useDisplay: false,
      		        chimeOnFinish: null,
      		        recipes: ["with-AMk2v3_Jarvis.js"],
      		      mic: {
      			recordProgram: "arecord",
      			device: "plughw:1",
      I have tried everything i can think of .
      pi@HomePi:~/MagicMirror $ npm start
      > magicmirror@2.11.0 start /home/pi/MagicMirror
      [2020-04-15 13:57:12.168] [LOG]    Starting MagicMirror: v2.11.0
      [2020-04-15 13:57:12.179] [LOG]    Loading config ...
      [2020-04-15 13:57:12.187] [LOG]    Loading module helpers ...
      [2020-04-15 13:57:12.190] [LOG]    No helper found for module: alert.
      [2020-04-15 13:57:12.277] [LOG]    Initializing new module helper ...
      [2020-04-15 13:57:12.278] [LOG]    Module helper loaded: updatenotification
      [2020-04-15 13:57:12.279] [LOG]    No helper found for module: clock.
      [2020-04-15 13:57:12.281] [LOG]    No helper found for module: compliments.
      [2020-04-15 13:57:12.282] [LOG]    No helper found for module: MMM-OpenmapWeather.
      [2020-04-15 13:57:12.283] [LOG]    No helper found for module: weatherforecast.
      [2020-04-15 13:57:13.250] [LOG]    Initializing new module helper ...
      [2020-04-15 13:57:13.251] [LOG]    Module helper loaded: MMM-PushBulletNotifications
      [2020-04-15 13:57:13.807] [LOG]    Initializing new module helper ...
      [2020-04-15 13:57:13.808] [LOG]    Module helper loaded: MMM-MyCommute
      [2020-04-15 13:57:13.871] [LOG]    Initializing new module helper ...
      [2020-04-15 13:57:13.872] [LOG]    Module helper loaded: MMM-network-signal
      [2020-04-15 13:57:14.225] [LOG]    Initializing new module helper ...
      [2020-04-15 13:57:14.226] [LOG]    Module helper loaded: MMM-COVID19-SPARKLINE
      [2020-04-15 13:57:14.756] [LOG]    Initializing new module helper ...
      [2020-04-15 13:57:14.757] [LOG]    Module helper loaded: MMM-Spotify
      [2020-04-15 13:57:17.414] [LOG]    Initializing new module helper ...
      [2020-04-15 13:57:17.415] [LOG]    Module helper loaded: MMM-News
      [2020-04-15 13:57:19.651] [LOG]    Initializing new module helper ...
      [2020-04-15 13:57:19.652] [LOG]    Module helper loaded: MMM-AssistantMk2
      [2020-04-15 13:57:19.935] [LOG]    Initializing new module helper ...
      [2020-04-15 13:57:19.936] [LOG]    Module helper loaded: MMM-Hotword
      [2020-04-15 13:57:19.937] [LOG]    All module helpers loaded.
      [2020-04-15 13:57:20.128] [LOG]    Starting server on port 8080 ...
      [2020-04-15 13:57:20.136] [INFO]   You're using a full whitelist configuration to allow for all IPs
      [2020-04-15 13:57:20.146] [LOG]    Server started ...
      [2020-04-15 13:57:20.148] [LOG]    Connecting socket for: updatenotification
      [2020-04-15 13:57:20.149] [LOG]    Connecting socket for: MMM-PushBulletNotifications
      [2020-04-15 13:57:20.151] [LOG]    Connecting socket for: MMM-MyCommute
      [2020-04-15 13:57:20.152] [LOG]    ====================== Starting node_helper for module [MMM-MyCommute]
      [2020-04-15 13:57:20.152] [LOG]    Connecting socket for: MMM-network-signal
      [2020-04-15 13:57:20.153] [LOG]    MMM-network-signal helper started ...
      [2020-04-15 13:57:20.154] [LOG]    Connecting socket for: MMM-COVID19-SPARKLINE
      [2020-04-15 13:57:20.155] [LOG]    Starting node helper for: MMM-COVID19-SPARKLINE
      [2020-04-15 13:57:20.156] [LOG]    Connecting socket for: MMM-Spotify
      [2020-04-15 13:57:20.159] [LOG]    [SPOTIFY_AUTH] Token is fresh.
      [2020-04-15 13:57:20.160] [LOG]    Connecting socket for: MMM-News
      [2020-04-15 13:57:20.161] [LOG]    Connecting socket for: MMM-AssistantMk2
      [2020-04-15 13:57:20.162] [LOG]    Connecting socket for: MMM-Hotword
      [2020-04-15 13:57:20.163] [LOG]    [HOTWORD] MMM-Hotword starts
      [2020-04-15 13:57:20.164] [LOG]    Sockets connected & modules started ...
      [2020-04-15 13:57:20.336] [LOG]    Launching application.
      [2020-04-15 13:57:23.807] [LOG]    [MMM-PushBulletNotifications][Info] 13:57:23.710 - START received
      [2020-04-15 13:57:23.941] [LOG]    [COVID:CORE] Scan starts.
      [2020-04-15 13:57:23.973] [LOG]    [NEWS] Initialized.
      [2020-04-15 13:57:23.995] [LOG]    [HOTWORD] Recipe is loaded: with-AMk2v3_Jarvis.js
      [2020-04-15 13:57:24.327] [LOG]    [AMK2] MMM-AssistantMk2 Version: 3.2.0
      [2020-04-15 13:57:24.374] [LOG]    [AMK2] AssistantMk2 is initialized.
      [2020-04-15 13:57:25.175] [LOG]    [MMM-Spotify] Starting
      [2020-04-15 13:57:25.603] [LOG]    [HOTWORD] begins.
      [2020-04-15 13:57:25.606] [LOG]    [HOTWORD] Detector starts listening.
      [2020-04-15 13:57:26.106] [LOG]    [COVID:CORE] Access to data source.
      [2020-04-15 13:57:26.352] [LOG]    [MMM-PushBulletNotifications][Info] 13:57:26.351 - PushBullet connected
      [2020-04-15 13:57:26.723] [LOG]    [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_confirmed_global.csv
      [2020-04-15 13:57:27.258] [LOG]    [NEWS] Articles are aggregated :  20
      [2020-04-15 13:57:27.719] [LOG]    [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_deaths_global.csv
      [2020-04-15 13:57:28.004] [LOG]    [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_recovered_global.csv
      [2020-04-15 13:57:28.044] [LOG]    can't find property recovered Canada:
      [2020-04-15 13:57:28.045] [LOG]    adding...
      [2020-04-15 13:57:28.177] [LOG]    [COVID:CORE] Calculating Wordlwide total.
      [2020-04-15 13:57:28.336] [LOG]    [COVID:CORE] Scan Completed.
      [2020-04-15 14:07:25.288] [LOG]    [NEWS] Articles are aggregated :  20
      [2020-04-15 14:17:25.070] [LOG]    [NEWS] Articles are aggregated :  20
        A Former User
        @Faiek said in Recipes not loading MMM-AssistantMK2:
        with-MMM-Spotify
        should be with-MMM-Spotify.js
        because it’s a js file, so same for other ;)
        F 1 Reply Last reply
        • F
          Faiek @Guest
          @Bugsounet - Thanks for the prompt response
          Can kick myself for that one ! - fairly new still - done it now - should i be see it loading in the log as i use too ? - [MK2} recipe is loaded : …
          because i don’t.
          Haven’t done a test on the mirror as I’m sorting my mic.
          Thanks …
