    MM on Ubuntu
    90 Posts 4 Posters 64.6k Views 4 Watching
      sdetweil @dwburger
      @dwburger i have never seen that behavior…
      do you have two entries in pm2??
      show the results of
      pm2 status
        dwburger
        No, just 1…MagicMirror.
          sdetweil @dwburger
          @dwburger hm… what system is this on? I have 9 instances running… never seen it behave that way… MM controls all the modules
            dwburger
            This is on a MiniPC running Ubuntu 18.04.4.
              sdetweil @dwburger
              @dwburger hm… my desktop is ubuntu 18.04, w MM running… on second display
              D 1 Reply Last reply
                dwburger @sdetweil
                @sdetweil I’m using the MiniPC solely for the MM2. The MiniPC is mounted to the back of an old wall-mounted LCD monitor and serves, basically, as an information kiosk for me running clock, calendar, radar, traffic, weather and to-do list modules.
                S 2 Replies Last reply
                  sdetweil @dwburger
                  @dwburger weird…
                  install this module , and add it to config.js as the 1st in the module list
                  https://github.com/sdetweil/MMM-Logging
                              module: 'MMM-Logging',
                              disabled: false,
                                  // Module functions out of the box with nothing set here.
                                  // See below for configurable options.
                                  echoLocal: true,
                                  echoRemote: true,
                                  overwriteBrowserMethods: true,
                                  format: "{{message}} ({{folder}}/{{file}}:{{line}} {{method}})",
                  stop MM via pm2,
                  pm2 stop 0
                  pm2 flush
                  pm2 start 0
                  then reboot (this is where it comes up partway, right)
                    dwburger @sdetweil
                    @sdetweil I just restarted my Ubuntu MiniPC 3 times after minimizing the MM2 window and MM2 started up perfectly each time. If it starts to act up again I’ll install the MMM-Logging module. When the problem was more evident the other day Ubuntu was displaying an error message that indicated it had some kind of issue with my WiFi and a “localhost”. I was focused on other things at the time and didn’t pay enough attention to this error message. I’ve not been receiving it lately so maybe something got resolved between my Ubuntu and my WiFi connection that also took care of this startup issue with MM2???
                      sdetweil @dwburger
                      @dwburger said in MM on Ubuntu:
                      all of those need internet access… so its possible…
                      many modules do not handle lack of connection properly
                        dwburger
                        Right. I’ll watch more carefully for any error messages I receive from Ubuntu. Thanks!
                        • 5 / 5
