    MMM-AssistantMk2 with Hotword not picking up anything.
    11 Posts 3 Posters 2.3k Views 3 Watching
      A Former User
      I think its better for you to restart with MMM-AssistantMk2 wiki
      MMM-Hotword is designed for complexe configuration with multiple keyword for execute notification to other module with some keyword installed
      if MMM-Hotword is too complex for you use MMM-Snowboy
        reubenvickers
        Okay, I’ll give that a go. I didn’t realise that you could just use snowboy - although when I tried to set it up before the website wouldn’t allow me to record (obviously not your problem, probably either theirs or mine)
        Cheers
          reubenvickers
          @Bugsounet So I’ve got it working to a much better extent (it actually shows up on screen which is useful). Do you actually need to use Snowboy or Hotword at all? Or can you just use ‘Ok Google’, if so that’s not working so it could be my mic.
            JohnBachini @reubenvickers
            @reubenvickers
            When you install does it pass Play/Mic test…?
            And you have copied mic config into Assistant config.
              A Former User
              @reubenvickers : can’t use Ok Google, it’s not a real google device, it’s just an Google SDK project
              If you want to use Ok Google keyword, it’s possible but it’s complex
                reubenvickers @Guest
                @Bugsounet finally got it working using Snowboy. Thanks for all your help and sorry for my ineptitude.
                  A Former User
                  it doesn’t matter, just read the wiki,
                  I think I did something complete :)
                    A Former User
                    @reubenvickers : now let’s try MMM-Assistant2Display !
