    Is it possible to have CSS for normal screens and a custom CSS for 7in screen?
    32 Posts 3 Posters 13.4k Views 3 Watching
      @Radnor said
      I have config_CLOCK with modules clock, wx, and wx forecast. In this config I told it via disable: width > small ? false:true. On my laptop get all 3. on phone no forecast (which should not be there).
      I see 4 things in the list
      on phone, no forecast, which is not an error?
      i set my newsfeed to
      			module: "newsfeed",
      			disabled: width>small_screen?false:true,
      see on desktop, not on phone, as expected
        Radnor
        There’s 3 (wx forecast) is forecast. Not weather AND forecast.
        No error because in forecast was disabled because of small screen.
        I copied your 2 lines (newsfeed & disabled) and get error when starting it. Complains about my config file…
        Any way of letting it load up and do a display:none in the CSS file for small screen?
          sdetweil @Radnor
          @Radnor notice my variable names (small_screen) are not the same as yours… (small_size)
            Radnor
            Initially, I did NOT see the different variable name.
            Cannot get the Ternary op to work at all. I copy/paste (and change var name) your code without luck.
            A straight “disabled: true” works.
              sdetweil @Radnor
              @Radnor its a (if) ? when_true : when_false
              show me your code now
                Radnor
                var small_size = 800;
                var width = 0;
                try {
                width=outerWidth
                catch(error){
                var config = …
                		module: "newsfeed",
                disabled: width < small_size ? true:false,
                position: “bottom_bar”,
                I had it WITH and WITHOUT the comma after false. I had parens around the logical test too.
                  Radnor
                  Event tried:
                  if (small_size>width) {
                  disabled: true,
                  this generates error in config with lots of red text on loading up
                    sdetweil @Radnor
                    @Radnor gotta have the comma after, cause there is more to this module definition… (, comma means more info following this line)
                    so, u want news feed ON for laptop (disabled:false), OFF for small display (disabled:true)
                    so, newsfeed has two parts… the node_helper, and the browser part (modulename.js)
                    so, we WANT the node_helper to load (disabled:false), but don’t know anything about the screen size yet, so it must be ALWAYS disable:false
                    var width = 801;   // notice 1 larger than expected size of small screen
                    try {
                        width=outerWidth        // get the actual screen width (only works in browser usage)
                    catch(error){                       // this catches the fatal error in node_helper loading
                    config info
                    		module: "newsfeed",
                                    disabled: width > small_size ?        // on startup, this will be true, so we want disabled:false
        // when the browser on laptop pulls in modulename, this will be true
        //              so disabled: false
        false:
        // when the small device is used, this will be false (800 is NOT greater than 800)
        // so we want disabled: true
        true
        ,     // more stuff coming on next line
                      Radnor
                      Thank you.
                      I’ve had it with and without the ending comma. Your changes, I’ve put in config.js only (node helper???) I did not put it in the modulename.js
                        sdetweil @Radnor
                        @Radnor said in Is it possible to have CSS for normal screens and a custom CSS for 7in screen?:
                        you do NOT put it into anything other than config.js,
                        the system (MM) will load config.js
                        once for loading node_helpers
                        once for each browser that connects to MM (including one that is included when npm start is done)
                          Radnor
                          Thats good. Did not mess that up…
                          I did a copy and paste of your code into my config file.
                          On the laptop I want the newsfeed. It just says “Loading …” (BEFORE changing width to 801)
                          On my phone, I do not want the newsfeed and it is NOT there. So that works great.
                          THANK YOU!!!
                          Changed width to 801 seems to be working now!
                          The short code works not too (without all the comments)
                          Thank you again! Be safe!
                            sdetweil @Radnor
                            right, the node_helper was not loaded, so the UI will just sit and wait for data that will never come
                            if you opened the dev window, console tabe, you would see an error from the module trying to send a message to the node_helper, which is not loaded…oops…
