    Is it possible to have CSS for normal screens and a custom CSS for 7in screen?
    32 Posts 3 Posters 13.4k Views 3 Watching
      @Radnor I had to fix the size for node_helper loading…
      I have them enabled if big screen, disabled if small screen
        @sdetweil better
        var width	= 801
        try {
          	width=outerWidth
        catch(error){
        var small_screen=800
        and module disabled
        			disabled: width>small_screen ?false: true,
          Radnor
          OK, I think the disabled has something to do with the newsfeed.
          I have several config files. config_WORKING has modules alert, notify, clock, wx, wx forecast, calendar, and newsfeed.
          I have config_CLOCK with modules clock, wx, and wx forecast. In this config I told it via disable: width > small ? false:true. On my laptop get all 3. on phone no forecast (which should not be there).
          In the newsfeed module the disable test is messing it up.
          I rename either WORKING or CLOCK to just config.js to test.
            I see 4 things in the list
            on phone, no forecast, which is not an error?
            i set my newsfeed to
            			module: "newsfeed",
            			disabled: width>small_screen?false:true,
            see on desktop, not on phone, as expected
              Radnor
              There’s 3 (wx forecast) is forecast. Not weather AND forecast.
              No error because in forecast was disabled because of small screen.
              I copied your 2 lines (newsfeed & disabled) and get error when starting it. Complains about my config file…
              Any way of letting it load up and do a display:none in the CSS file for small screen?
                sdetweil @Radnor
                @Radnor notice my variable names (small_screen) are not the same as yours… (small_size)
                  Radnor
                  Initially, I did NOT see the different variable name.
                  Cannot get the Ternary op to work at all. I copy/paste (and change var name) your code without luck.
                  A straight “disabled: true” works.
                    sdetweil @Radnor
                    @Radnor its a (if) ? when_true : when_false
                    show me your code now
                      Radnor
                      var small_size = 800;
                      var width = 0;
                      try {
                      width=outerWidth
                      catch(error){
                      var config = …
                      		module: "newsfeed",
                      disabled: width < small_size ? true:false,
                      position: “bottom_bar”,
                      I had it WITH and WITHOUT the comma after false. I had parens around the logical test too.
                        Radnor
                        Event tried:
                        if (small_size>width) {
                        disabled: true,
                        this generates error in config with lots of red text on loading up
                          sdetweil @Radnor
                          @Radnor gotta have the comma after, cause there is more to this module definition… (, comma means more info following this line)
                          so, u want news feed ON for laptop (disabled:false), OFF for small display (disabled:true)
                          so, newsfeed has two parts… the node_helper, and the browser part (modulename.js)
                          so, we WANT the node_helper to load (disabled:false), but don’t know anything about the screen size yet, so it must be ALWAYS disable:false
                          var width = 801;   // notice 1 larger than expected size of small screen
                          try {
                              width=outerWidth        // get the actual screen width (only works in browser usage)
                          catch(error){                       // this catches the fatal error in node_helper loading
                          config info
                          		module: "newsfeed",
                                          disabled: width > small_size ?        // on startup, this will be true, so we want disabled:false
        // when the browser on laptop pulls in modulename, this will be true
        //              so disabled: false
        false:
        // when the small device is used, this will be false (800 is NOT greater than 800)
        // so we want disabled: true
        true
        ,     // more stuff coming on next line
                            Radnor
                            Thank you.
                            I’ve had it with and without the ending comma. Your changes, I’ve put in config.js only (node helper???) I did not put it in the modulename.js
                              sdetweil @Radnor
                              @Radnor said in Is it possible to have CSS for normal screens and a custom CSS for 7in screen?:
                              you do NOT put it into anything other than config.js,
                              the system (MM) will load config.js
                              once for loading node_helpers
                              once for each browser that connects to MM (including one that is included when npm start is done)
                                Radnor
                                Thats good. Did not mess that up…
                                I did a copy and paste of your code into my config file.
                                On the laptop I want the newsfeed. It just says “Loading …” (BEFORE changing width to 801)
                                On my phone, I do not want the newsfeed and it is NOT there. So that works great.
                                THANK YOU!!!
                                Changed width to 801 seems to be working now!
                                The short code works not too (without all the comments)
                                Thank you again! Be safe!
                                  sdetweil @Radnor
                                  right, the node_helper was not loaded, so the UI will just sit and wait for data that will never come
                                  if you opened the dev window, console tabe, you would see an error from the module trying to send a message to the node_helper, which is not loaded…oops…
