    read csv-data and put it in an array
    313 Posts 3 Posters 579.0k Views 4 Watching
    • PerlchampP
      Perlchamp
      ok, nothing changed and i don’t see any messages of “HAVEDATA” (changed it in both files to big letter without space). i only see the header “Geburtstage” … :-(
      node_helper.js:
      var NodeHelper = require("node_helper");
      var moment = require("moment");
      // add require of other javascripot components here
      // var xxx = require('yyy'); here
      const csv = require("csvtojson");
      var birthdaysArray = [];
      	init(){
      		console.log("init module helper perlchamp");
      	start() {
      	stop(){
      		console.log("Stopping module helper: " + this.name);
      	// handle messages from our module// each notification indicates a different messages
      	// payload is a data structure that is different per message.. up to you to design this
      	socketNotificationReceived(notification, payload) {
      		var self = this;
      		console.log("Starting module helper: " + this.name);
      		// convert the csv-file into a JSON-String
      		const csvFilePath = this.path + '/data/birthdays.csv';
      		csv()
      		.fromFile(csvFilePath)
      		.then((jsonObj)=>{
      			birthdaysArray = JSON.stringify(jsonObj);
      			// send data to [modulname].js
      			self.sendSocketNotification("HAVEDATA", jsonObj);
      		// if config message from module
      		if (notification === "CONFIG") {
      			// save payload config info
      			this.config = payload;
      			// wait 15 seconds, send a message back to module
      			setTimeout(()=> {this.sendSocketNotification("message_from_helper"," this is a test_message")}, 15000);
      		else if(notification === "????2") {
      maye change this part, cause i never need this variable birthdaysArray:
      .then((jsonObj)=>{
      perlchamp.js:
      Module.register("perlchamp", {
      	defaults: {
      		language: "de",
      		dimmEntries: true   // true: dims entries and the associated
      							//       symbol when the date has expired.
      							// false: delete entries and the associated
      	active_birthdays: {
      	init: function(){
      		Log.log(this.name + " is in init!");
      	start: function(){
      		Log.log("Starting module: " + this.name);
      		// Set locale
      		moment.locale(config.language);
      	loaded: function(callback) {
      		Log.log(this.name + " is loaded!");
      		callback();
      	// return list of other functional scripts to use, if any (like require in node_helper)
      	getScripts: function() {
      		return	["moment.js"];
      	// return list of stylesheet files to use if any
      	getStyles: function() {
      		return 	[this.data.path + "/css/perlchamp.css"];
      	// only called if the module header was configured in module config in config.js
      	getHeader: function() {
      		return this.data.header;
      	// messages received from other modules and the system (NOT from your node helper)
      	// payload is a notification dependent data structure
      		// once everybody is loaded up
      		if(notification==="ALL_MODULES_STARTED"){
      			// send our config to our node_helper
      			this.sendSocketNotification("CONFIG",this.config);
      		if (sender) {
      			Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
      		} else {
      			Log.log(this.name + " received a system notification: " + notification);
      	// messages received from from your node helper (NOT other modules or the system)
      	// payload is a notification dependent data structure, up to you to design between module and node_helper
      		if(notification === "HAVEDATE"){
      			Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
      			var now = moment();
      			for(var birthday of payload) {
      				// get 1st 5 chars of birthdate, thru month
      				// we will use this as the key in the hash
      				var birth_date = birthday.birth.substring(0,4);
      				// get the birthday as a moment in this year, for comparing
      				var birth_date_moment = moment(birth_date + now.getYear(),"DD.MMYYYY");
      				// u can add days to a moment object and then compare
      				//     if the birthdate is before that date (and after now)
      				//     so within the next xx days
      				// if the date is the same or later, don't use time of day
      				if(birth_date.startOf('day').isSame(now.startOf('day'))) {
      					// birthday is in this month
      					// check the hash if we've seen anything for today yet
      					// if we haven't see this date yet
      					if(this.active_birthdays[birth_date] == undefined){
      						//  create the holder for its info (array of
      						//		names) in the hash
      						this.active_birthdays[birth_date] = [];
      					// save the persons name on the list
      					this.active_birthdays[birth_date].push(birthday.name);
      			// tell MM to call and get our content
      			self.updateDom();
      	// system notification your module is being hidden
      	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
      	suspend: function(){
      	// system notification your module is being unhidden/shown
      	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
      	resume: function(){
      	// this is the major worker of the module, it provides the displayable content for this module
      	getDom: function() {
      		for(var birthday of Object.keys(this.active_birthdays)){
      			for(var name of this.active_birthdays[birthday]){
      				var m = document.createElement('div');
      				m.innerText = birthday + ' '+ name;
      				wrapper.appendChild(m);
      		// pass the created content back to MM to add to DOM.
      		return wrapper;
      please have an eye on the getDom-sektion.
        no… it will do the thig every time a notifcation comes in, only want it when the module sends down a message (say it is alive)
        in node_help you are sending this “HAVEDATA”
        and in module you are looking for this if(notification === “HAVEDATE”){
        add a var self = this to start of socketNotificationReceived() and getDom()
          sdetweil @Perlchamp
          @Perlchamp said in read csv-data and put it in an array:
          if(birth_date.startOf(‘day’)
          also should be
          if(birth_date_moment.startOf('day')
          comparing moments, not strings! oops
          • PerlchampP
            Perlchamp
            only the header i see, BUT now i see the terminal-message “HAVEDATA” but an error, too:
              sdetweil @Perlchamp
              @Perlchamp open the developers window, ctrl-shift-i on the mirror screen,
              select console tab,
              put perl in the filter field
              select the sources tab, navigate the left nav tree,. to modules/perlchamp/perlcmap.js
              find the socketnotificationreceived
              click the number in the left column, hit f5 (refresh) on keyboard
              code should stop at the line you clicked
              in the right pane, top there is a blue arrow (resume executing) and a top half of a globe, stop on next )instruction)
              • PerlchampP
                Perlchamp
                before looking in dev: i saw the following:
                change to DD.MM.YYYY (point between MM and YYYY) ?
                  sdetweil @Perlchamp
                  @Perlchamp no, cause we extract dd.mm from the info provided in file…
                  oh, the substring should be 0,5, not 0,4
                  var birth_date = birthday.birth.substring(0,5);
                  • PerlchampP
                    Perlchamp
                    error => now.getYear() is not a function
                      sdetweil @Perlchamp
                      @Perlchamp yeh, sorry, rememeber just off the top of my head…
                      date uses that …
                      moment its just year()
                      var birth_date_moment = moment(birth_date + now.year(),“DD.MMYYYY”);
                      • PerlchampP
                        Perlchamp
                        nothing changed. but now i see the HAVEDATA notification again. could it be, that the Dom-update (from notification) not really goes ?
                        i mean i saw in the dev, that the birthday-data are right. it was the first entry of this data-string (or jsonObj) …
                        only the header i can see …
                          sdetweil @Perlchamp
                          @Perlchamp put a stop on the statement self.updateDom()
                          hit refresh, the code should stop there, then mouse over the this.active_birthdays a few lines up,
                          the debugger will surface the values
                          • PerlchampP
                            Perlchamp
                            displays the last row of the data-string, though the data from first to last are looped. for me it seems correct there …
                              sdetweil @Perlchamp
                              @Perlchamp ok, put a stop on the 1st line of getDom()
                              it will be called before you get data, then your notification will be called
                              and then getdom() again… and u can watch it go thru the code
                              • PerlchampP
                                Perlchamp
                                yes it does … i changed innerText to innerHTML but nothing.
                                  sdetweil @Perlchamp
                                  @Perlchamp ok, inner HTML is when u are inserting html… my code inserts text…
                                  did u have a position: in config definition for module?
                                  			module: "SampleModule",
                                  			disabled: false,
                                  			position: 'middle',
                                  				days_forward:4,
                                  • PerlchampP
                                    Perlchamp
                                    yes, top, but i will post it, moment:
                                    			module: 'perlchamp',
                                    			position: 'top',
                                    			header: "Geburtstage",
                                    				language: "de"
                                      sdetweil @Perlchamp
                                      @Perlchamp i changed mine to top and all ok, did u walk thru the code in getdom? (hit next over and over)
                                      put a stop on return wrapper and look at that object…
                                      i have multiple names on the same date in my csv file
                                      and also allowed look ahead a few days… so had entries for today and tuesday 5/5
                                      • PerlchampP
                                        Perlchamp
                                        i clicked on the linenumber and the blue sign went to the last line, though i couldn’t hit line for line …
                                          sdetweil @Perlchamp
                                          @Perlchamp next to the blue arrow (to the right) is a half circle with arrow at the end and dot under… that is the “Next” instruction button
                                          • PerlchampP
                                            Perlchamp
                                            return wrapper. all entries undefined, aha.
                                            • 15
                                            • 16
                                            • 6 / 16
