    read csv-data and put it in an array
    313 Posts 3 Posters 590.5k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp put a stop on the statement self.updateDom()
      hit refresh, the code should stop there, then mouse over the this.active_birthdays a few lines up,
      the debugger will surface the values
      • PerlchampP
        Perlchamp
        displays the last row of the data-string, though the data from first to last are looped. for me it seems correct there …
          sdetweil @Perlchamp
          @Perlchamp ok, put a stop on the 1st line of getDom()
          it will be called before you get data, then your notification will be called
          and then getdom() again… and u can watch it go thru the code
          • PerlchampP
            Perlchamp
            yes it does … i changed innerText to innerHTML but nothing.
              sdetweil @Perlchamp
              @Perlchamp ok, inner HTML is when u are inserting html… my code inserts text…
              did u have a position: in config definition for module?
              			module: "SampleModule",
              			disabled: false,
              			position: 'middle',
              				days_forward:4,
              • PerlchampP
                Perlchamp
                yes, top, but i will post it, moment:
                			module: 'perlchamp',
                			position: 'top',
                			header: "Geburtstage",
                				language: "de"
                  sdetweil @Perlchamp
                  @Perlchamp i changed mine to top and all ok, did u walk thru the code in getdom? (hit next over and over)
                  put a stop on return wrapper and look at that object…
                  i have multiple names on the same date in my csv file
                  and also allowed look ahead a few days… so had entries for today and tuesday 5/5
                  • PerlchampP
                    Perlchamp
                    i clicked on the linenumber and the blue sign went to the last line, though i couldn’t hit line for line …
                      sdetweil @Perlchamp
                      @Perlchamp next to the blue arrow (to the right) is a half circle with arrow at the end and dot under… that is the “Next” instruction button
                      • PerlchampP
                        Perlchamp
                        return wrapper. all entries undefined, aha.
                          sdetweil @Perlchamp
                          @Perlchamp on entry, check that the this.active_birthdays is still good
                          • PerlchampP
                            Perlchamp
                            i cannot place the blue sign on line 118 (cklicking on that number => run to last line …)
                              sdetweil @Perlchamp
                              @Perlchamp
                              see the circle net to the blue arrow
                              i don’t know where your 118 line is…
                              but go down or up
                              • PerlchampP
                                Perlchamp
                                it loops from first entry to last. if the last entry is displayed, it loops once and than going to self.updateDom … for me the correct way …
                                  sdetweil @Perlchamp
                                  @Perlchamp in the getDom()
                                  does it do the innerText statement? then the addChild()
                                  to get any text on the screen, it has to do every statement at least once
                                  • PerlchampP
                                    Perlchamp
                                    how said:
                                    if i click on the linenumber of getDom: the blue arrow run to the last line. i can’t stop it or something else … it runs thru
                                      sdetweil @Perlchamp
                                      @Perlchamp i don’t understand
                                      in code view, scroll down to getDom, next line, click the number to the left, turns blue
                                      hit refresh
                                      • PerlchampP
                                        Perlchamp
                                        all values “undefined”
                                          sdetweil @Perlchamp
                                          @Perlchamp this.active_brithdays undefined?
                                          did u fix the names in the notification handler?
                                          		if(notification === "have data"){
                                          			var self = this
                                          			Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                                          			var now = moment();
                                          			for(var birthday of payload) {
                                          				// get 1st 5 chars of birthdate, thru month
                                          				// we will use this as the key in the hash
                                          				var birth_date = birthday.birth.substring(0,5);
                                          				// get the birthday as a moment in this year, for comparing
                                          				var birth_date_moment = moment(birth_date + now.year(),"DD.MMYYYY");
                                          				// u can add days to a moment object and then compare
                                          				//     if the birthdate is before that date (and after now)
                                          				//     so within the next xx days
                                          				// if the date is the same or later, don't use time of day
                                          				if(birth_date_moment.startOf('day').isSame(now.startOf('day'))) {
                                          					// birthday is in this month
                                          					// check the hash if we've seen anything for today yet
                                          					// if we haven't see this date yet
                                          					if(this.active_birthdays[birth_date] == undefined){
                                          						//  create the holder for its info (array of
                                          						//		names) in the hash
                                          						this.active_birthdays[birth_date] = [];
                                          					// save the persons name on the list
                                          					this.active_birthdays[birth_date].push(birthday.name);
                                          			// tell MM to call and get our content
                                          			self.updateDom();
                                          • PerlchampP
                                            Perlchamp
                                            • 15
                                            • 16
                                            • 7 / 16
