    read csv-data and put it in an array
    313 Posts 3 Posters 590.4k Views 4 Watching
    • PerlchampP
      Perlchamp
      before looking in dev: i saw the following:
      var birth_date_moment = moment(birth_date + now.getYear(),"DD.MMYYYY");
      change to DD.MM.YYYY (point between MM and YYYY) ?
        sdetweil @Perlchamp
        @Perlchamp no, cause we extract dd.mm from the info provided in file…
        oh, the substring should be 0,5, not 0,4
        var birth_date = birthday.birth.substring(0,5);
        • PerlchampP
          Perlchamp
          error => now.getYear() is not a function
            sdetweil @Perlchamp
            @Perlchamp yeh, sorry, rememeber just off the top of my head…
            date uses that …
            moment its just year()
            var birth_date_moment = moment(birth_date + now.year(),“DD.MMYYYY”);
            • PerlchampP
              Perlchamp
              nothing changed. but now i see the HAVEDATA notification again. could it be, that the Dom-update (from notification) not really goes ?
              i mean i saw in the dev, that the birthday-data are right. it was the first entry of this data-string (or jsonObj) …
              only the header i can see …
                sdetweil @Perlchamp
                @Perlchamp put a stop on the statement self.updateDom()
                hit refresh, the code should stop there, then mouse over the this.active_birthdays a few lines up,
                the debugger will surface the values
                • PerlchampP
                  Perlchamp
                  displays the last row of the data-string, though the data from first to last are looped. for me it seems correct there …
                    sdetweil @Perlchamp
                    @Perlchamp ok, put a stop on the 1st line of getDom()
                    it will be called before you get data, then your notification will be called
                    and then getdom() again… and u can watch it go thru the code
                    • PerlchampP
                      Perlchamp
                      yes it does … i changed innerText to innerHTML but nothing.
                        sdetweil @Perlchamp
                        @Perlchamp ok, inner HTML is when u are inserting html… my code inserts text…
                        did u have a position: in config definition for module?
                        			module: "SampleModule",
                        			disabled: false,
                        			position: 'middle',
                        				days_forward:4,
                        • PerlchampP
                          Perlchamp
                          yes, top, but i will post it, moment:
                          			module: 'perlchamp',
                          			position: 'top',
                          			header: "Geburtstage",
                          				language: "de"
                            sdetweil @Perlchamp
                            @Perlchamp i changed mine to top and all ok, did u walk thru the code in getdom? (hit next over and over)
                            put a stop on return wrapper and look at that object…
                            i have multiple names on the same date in my csv file
                            and also allowed look ahead a few days… so had entries for today and tuesday 5/5
                            • PerlchampP
                              Perlchamp
                              i clicked on the linenumber and the blue sign went to the last line, though i couldn’t hit line for line …
                                sdetweil @Perlchamp
                                @Perlchamp next to the blue arrow (to the right) is a half circle with arrow at the end and dot under… that is the “Next” instruction button
                                • PerlchampP
                                  Perlchamp
                                  return wrapper. all entries undefined, aha.
                                    sdetweil @Perlchamp
                                    @Perlchamp on entry, check that the this.active_birthdays is still good
                                    • PerlchampP
                                      Perlchamp
                                      i cannot place the blue sign on line 118 (cklicking on that number => run to last line …)
                                        sdetweil @Perlchamp
                                        @Perlchamp
                                        see the circle net to the blue arrow
                                        i don’t know where your 118 line is…
                                        but go down or up
                                        • PerlchampP
                                          Perlchamp
                                          it loops from first entry to last. if the last entry is displayed, it loops once and than going to self.updateDom … for me the correct way …
                                            sdetweil @Perlchamp
                                            @Perlchamp in the getDom()
                                            does it do the innerText statement? then the addChild()
                                            to get any text on the screen, it has to do every statement at least once
                                            • 15
                                            • 16
                                            • 7 / 16
