    read csv-data and put it in an array
    313 Posts 3 Posters 590.2k Views 4 Watching
    • PerlchampP
      Perlchamp
      yes, top, but i will post it, moment:
      			module: 'perlchamp',
      			position: 'top',
      			header: "Geburtstage",
      				language: "de"
        sdetweil @Perlchamp
        @Perlchamp i changed mine to top and all ok, did u walk thru the code in getdom? (hit next over and over)
        put a stop on return wrapper and look at that object…
        i have multiple names on the same date in my csv file
        and also allowed look ahead a few days… so had entries for today and tuesday 5/5
        • PerlchampP
          Perlchamp
          i clicked on the linenumber and the blue sign went to the last line, though i couldn’t hit line for line …
            sdetweil @Perlchamp
            @Perlchamp next to the blue arrow (to the right) is a half circle with arrow at the end and dot under… that is the “Next” instruction button
            • PerlchampP
              Perlchamp
              return wrapper. all entries undefined, aha.
                sdetweil @Perlchamp
                @Perlchamp on entry, check that the this.active_birthdays is still good
                • PerlchampP
                  Perlchamp
                  i cannot place the blue sign on line 118 (cklicking on that number => run to last line …)
                    sdetweil @Perlchamp
                    @Perlchamp
                    see the circle net to the blue arrow
                    i don’t know where your 118 line is…
                    but go down or up
                    • PerlchampP
                      Perlchamp
                      it loops from first entry to last. if the last entry is displayed, it loops once and than going to self.updateDom … for me the correct way …
                        sdetweil @Perlchamp
                        @Perlchamp in the getDom()
                        does it do the innerText statement? then the addChild()
                        to get any text on the screen, it has to do every statement at least once
                        • PerlchampP
                          Perlchamp
                          how said:
                          if i click on the linenumber of getDom: the blue arrow run to the last line. i can’t stop it or something else … it runs thru
                            sdetweil @Perlchamp
                            @Perlchamp i don’t understand
                            in code view, scroll down to getDom, next line, click the number to the left, turns blue
                            hit refresh
                            • PerlchampP
                              Perlchamp
                              all values “undefined”
                                sdetweil @Perlchamp
                                @Perlchamp this.active_brithdays undefined?
                                did u fix the names in the notification handler?
                                		if(notification === "have data"){
                                			var self = this
                                			Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                                			var now = moment();
                                			for(var birthday of payload) {
                                				// get 1st 5 chars of birthdate, thru month
                                				// we will use this as the key in the hash
                                				var birth_date = birthday.birth.substring(0,5);
                                				// get the birthday as a moment in this year, for comparing
                                				var birth_date_moment = moment(birth_date + now.year(),"DD.MMYYYY");
                                				// u can add days to a moment object and then compare
                                				//     if the birthdate is before that date (and after now)
                                				//     so within the next xx days
                                				// if the date is the same or later, don't use time of day
                                				if(birth_date_moment.startOf('day').isSame(now.startOf('day'))) {
                                					// birthday is in this month
                                					// check the hash if we've seen anything for today yet
                                					// if we haven't see this date yet
                                					if(this.active_birthdays[birth_date] == undefined){
                                						//  create the holder for its info (array of
                                						//		names) in the hash
                                						this.active_birthdays[birth_date] = [];
                                					// save the persons name on the list
                                					this.active_birthdays[birth_date].push(birthday.name);
                                			// tell MM to call and get our content
                                			self.updateDom();
                                • PerlchampP
                                  Perlchamp
                                    sdetweil @Perlchamp
                                    @Perlchamp click on line number 122 for a stop… birthday is not defined once you leave the for loop…
                                    • PerlchampP
                                      Perlchamp
                                      yes i did. all variables are correct
                                        sdetweil @Perlchamp
                                        @Perlchamp and getDom() will be called multiple times, once before your data arrives, maybe once more than when you data is ready
                                        and it does the innerText statement?
                                        and u look at the element, and look at the inner text and its correct?
                                        i am running out of energy for the day… been since 6am. now 11pm
                                        • PerlchampP
                                          Perlchamp
                                          122 => next => marks “return”(131) => next => marks end of 131 => next => jumped to main.js
                                            sdetweil @Perlchamp
                                            @Perlchamp mark the line for the second for(
                                            for(var birthday of Object.keys(this.active_birthdays)){
                                            			for(var name of this.active_birthdays[birthday]){              // stop on this line
                                            and remove the other stops
                                            • 15
                                            • 16
                                            • 7 / 16
