    read csv-data and put it in an array
    313 Posts 3 Posters 590.1k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp on entry, check that the this.active_birthdays is still good
      • PerlchampP
        Perlchamp
        i cannot place the blue sign on line 118 (cklicking on that number => run to last line …)
          sdetweil @Perlchamp
          @Perlchamp
          see the circle net to the blue arrow
          i don’t know where your 118 line is…
          but go down or up
          • PerlchampP
            Perlchamp
            it loops from first entry to last. if the last entry is displayed, it loops once and than going to self.updateDom … for me the correct way …
              sdetweil @Perlchamp
              @Perlchamp in the getDom()
              does it do the innerText statement? then the addChild()
              to get any text on the screen, it has to do every statement at least once
              • PerlchampP
                Perlchamp
                how said:
                if i click on the linenumber of getDom: the blue arrow run to the last line. i can’t stop it or something else … it runs thru
                  sdetweil @Perlchamp
                  @Perlchamp i don’t understand
                  in code view, scroll down to getDom, next line, click the number to the left, turns blue
                  hit refresh
                  • PerlchampP
                    Perlchamp
                    all values “undefined”
                      sdetweil @Perlchamp
                      @Perlchamp this.active_brithdays undefined?
                      did u fix the names in the notification handler?
                      		if(notification === "have data"){
                      			var self = this
                      			Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                      			var now = moment();
                      			for(var birthday of payload) {
                      				// get 1st 5 chars of birthdate, thru month
                      				// we will use this as the key in the hash
                      				var birth_date = birthday.birth.substring(0,5);
                      				// get the birthday as a moment in this year, for comparing
                      				var birth_date_moment = moment(birth_date + now.year(),"DD.MMYYYY");
                      				// u can add days to a moment object and then compare
                      				//     if the birthdate is before that date (and after now)
                      				//     so within the next xx days
                      				// if the date is the same or later, don't use time of day
                      				if(birth_date_moment.startOf('day').isSame(now.startOf('day'))) {
                      					// birthday is in this month
                      					// check the hash if we've seen anything for today yet
                      					// if we haven't see this date yet
                      					if(this.active_birthdays[birth_date] == undefined){
                      						//  create the holder for its info (array of
                      						//		names) in the hash
                      						this.active_birthdays[birth_date] = [];
                      					// save the persons name on the list
                      					this.active_birthdays[birth_date].push(birthday.name);
                      			// tell MM to call and get our content
                      			self.updateDom();
                      • PerlchampP
                        Perlchamp
                          sdetweil @Perlchamp
                          @Perlchamp click on line number 122 for a stop… birthday is not defined once you leave the for loop…
                          • PerlchampP
                            Perlchamp
                            yes i did. all variables are correct
                              sdetweil @Perlchamp
                              @Perlchamp and getDom() will be called multiple times, once before your data arrives, maybe once more than when you data is ready
                              and it does the innerText statement?
                              and u look at the element, and look at the inner text and its correct?
                              i am running out of energy for the day… been since 6am. now 11pm
                              • PerlchampP
                                Perlchamp
                                122 => next => marks “return”(131) => next => marks end of 131 => next => jumped to main.js
                                  sdetweil @Perlchamp
                                  @Perlchamp mark the line for the second for(
                                  for(var birthday of Object.keys(this.active_birthdays)){
                                  			for(var name of this.active_birthdays[birthday]){              // stop on this line
                                  and remove the other stops
                                  • PerlchampP
                                    Perlchamp
                                    the same see picture i did send to you. it’s line 122 => stop => refresh => and than like posted before
                                    no does nothing … ok never mind. coming from germany it’s now 06:00 in the morning did’t sleep …
                                      sdetweil @Perlchamp
                                      @Perlchamp tomorrow, very close
                                      • PerlchampP
                                        Perlchamp
                                        don’t worry about me and sleep well.
                                          sdetweil @Perlchamp
                                          @Perlchamp thx…
                                          in debugging
                                          put a stop on the self.updateDom() in the notiification code.
                                          no place else
                                          hit refresh
                                          when it stops there,
                                          scroll down to getdom and add a stop on the 1st for loop line
                                          hit run arrow,
                                          should stop in getdom now, with data
                                            @perl here is the updated perlchamp.js, shows date, persons name and age (no formatting)
                                            Module.register("perlchamp", {
                                            	defaults: {
                                            		language: "de",
                                            		dimmEntries: true,   // true: dims entries and the associated
                                            							//       symbol when the date has expired.
                                            							// false: delete entries and the associated
                                                             // used if look forward is desired, add to module config  in config.js
                                                             days_forward:0,
                                            	// place to save birthdays to display
                                                active_birthdays : {},
                                            	init: function(){
                                            		Log.log(this.name + " is in init!");
                                            	start: function(){
                                            		Log.log("Starting module: " + this.name);
                                            		// Set locale
                                            		moment.locale(config.language);
                                            	loaded: function(callback) {
                                            		Log.log(this.name + " is loaded!");
                                            		callback();
                                            	// return list of other functional scripts to use, if any (like require in node_helper)
                                            	getScripts: function() {
                                            		return	["moment.js"];
                                            	// return list of stylesheet files to use if any
                                            	getStyles: function() {
                                            		return 	[this.data.path + "/css/perlchamp.css"];
                                            	// return list of translation files to use, if any
                                            	getTranslations: function() {
                                            		return {
                                            			// sample of list of files to specify here, if no files, do not use this routine, , or return empty list
                                            			// en: "translations/en.json",  (folders and filenames in your module folder)
                                            			// de: "translations/de.json"
                                            	// only called if the module header was configured in module config in config.js
                                            	getHeader: function() {
                                            		return this.data.header;
                                            	// messages received from other modules and the system (NOT from your node helper)
                                            	// payload is a notification dependent data structure
                                            		// once everybody is loaded up
                                            		if(notification==="ALL_MODULES_STARTED"){
                                            			// send our config to our node_helper
                                            			this.sendSocketNotification("CONFIG",this.config);
                                            		if (sender) {
                                            			Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
                                            		} else {
                                            			Log.log(this.name + " received a system notification: " + notification);
                                            	// messages received from from your node helper (NOT other modules or the system)
                                            	// payload is a notification dependent data structure, up to you to design between module and node_helper
                                            		if(notification === "message_from_helper"){
                                            			this.config.message = payload;
                                            			// tell mirror runtime that our data has changed,
                                            			// we will be called back at GetDom() to provide the updated content
                                            			this.updateDom(1000);
                                            			var self = this
                                            			var now = moment();
                                            			// clear the old list
        this.active_birthdays={}
                                            			// only calculate in advance once
                                            			var birthday_time_window=moment().add(self.config.days_forward,'days')
                                            			// loop thru the birthdays  from the file
                                            			for( var birthday of payload) {
                                            				var birth_date=birthday.birth.substring(0,5)
                                            				var birth_date_moment = moment(birth_date+now.year(),"DD.MMYYYY")
                                            				// u can add days to a moment object and then compare if the birthdate is before that date (and after now)
                                            			   if(birth_date_moment.startOf('day').isSameOrAfter(now.startOf('day')) &&
                                            			   	  birth_date_moment.startOf('day').isSameOrBefore(birthday_time_window.startOf('day'))
                                            			      if(self.active_birthdays[birth_date] == undefined){
                                            			           //  create the holder for its info (array of info) in the hash
                                            			           self.active_birthdays[birth_date]=[]
                                            			      // save the persons name and age on the list
                                            			      self.active_birthdays[birth_date].push({'name':birthday.name, 'age': now.diff(moment(birthday.birth,'DD.MM.YYYY'), 'years') })
                                            			self.updateDom();
                                            			// filters the birthdaylist and output only the birthdays
                                            			// of the current month, sorted (ascending) by days in
                                            			// the following format:
                                            			// [{ day: "10", name: ["firstname lastname",...] }]
                                            			// set variables
                                            			var today_month = moment().format("MM");
                                            			var today_day_month = moment().format("DD.MM");
                                            			var result = Object.entries(jsonObj
                                            			.filter(({birth}) => birth.split('.')[1] === today_month)
                                            			.reduce((a, {birth, name}) => {
                                            				const day = +birth.split('.')[0];
                                            				a[day] = [...(a[day] || []), name];
                                            				return a
                                            			).map(([day, name]) => ({day, name})).sort((a, b) => +a.day - b.day);
                                            			birthdaysArray = result;
                                            			// for debugging only
                                            			//console.log("filtered and sorted: ", birthdaysArray);
                                            	// system notification your module is being hidden
                                            	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
                                            	suspend: function(){
                                            	// system notification your module is being unhidden/shown
                                            	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
                                            	resume: function(){
                                            	// this is the major worker of the module, it provides the displayable content for this module
                                            	getDom: function() {
                                            // create your table and header here
                                            			for(var person of this.active_birthdays[birthday]){
                                            				var m=document.createElement('div')
                                            // create tyour table row here
                                            				m.innerText=birthday+ ' '+ person.name+' age='+person.age
                                            				wrapper.appendChild(m)
                                            // create your table footer here
                                            		// pass the created content back to MM to add to DOM.
                                            		return wrapper;
                                            this is the birthdays.csv I was using
                                            the column names are the field names in the jsonobj
                                            birth, name
                                            12.07.1952, Sam
                                            11.09.1944, Peg
                                            02.05.1939, Frank
                                            09.04.1953, June
                                            09.04.1953, Jane
                                            30.12.1955, Joan
                                            02.05.1939, Sue
                                            05.05.1955, mary
                                            • 15
                                            • 16
                                            • 7 / 16
