    read csv-data and put it in an array
    313 Posts 3 Posters 579.0k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp in the getDom()
      does it do the innerText statement? then the addChild()
      to get any text on the screen, it has to do every statement at least once
      • PerlchampP
        Perlchamp
        how said:
        if i click on the linenumber of getDom: the blue arrow run to the last line. i can’t stop it or something else … it runs thru
          sdetweil @Perlchamp
          @Perlchamp i don’t understand
          in code view, scroll down to getDom, next line, click the number to the left, turns blue
          hit refresh
          • PerlchampP
            Perlchamp
            all values “undefined”
              sdetweil @Perlchamp
              @Perlchamp this.active_brithdays undefined?
              did u fix the names in the notification handler?
              		if(notification === "have data"){
              			var self = this
              			Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
              			var now = moment();
              			for(var birthday of payload) {
              				// get 1st 5 chars of birthdate, thru month
              				// we will use this as the key in the hash
              				var birth_date = birthday.birth.substring(0,5);
              				// get the birthday as a moment in this year, for comparing
              				var birth_date_moment = moment(birth_date + now.year(),"DD.MMYYYY");
              				// u can add days to a moment object and then compare
              				//     if the birthdate is before that date (and after now)
              				//     so within the next xx days
              				// if the date is the same or later, don't use time of day
              				if(birth_date_moment.startOf('day').isSame(now.startOf('day'))) {
              					// birthday is in this month
              					// check the hash if we've seen anything for today yet
              					// if we haven't see this date yet
              					if(this.active_birthdays[birth_date] == undefined){
              						//  create the holder for its info (array of
              						//		names) in the hash
              						this.active_birthdays[birth_date] = [];
              					// save the persons name on the list
              					this.active_birthdays[birth_date].push(birthday.name);
              			// tell MM to call and get our content
              			self.updateDom();
              • PerlchampP
                Perlchamp
                  sdetweil @Perlchamp
                  @Perlchamp click on line number 122 for a stop… birthday is not defined once you leave the for loop…
                  • PerlchampP
                    Perlchamp
                    yes i did. all variables are correct
                      sdetweil @Perlchamp
                      @Perlchamp and getDom() will be called multiple times, once before your data arrives, maybe once more than when you data is ready
                      and it does the innerText statement?
                      and u look at the element, and look at the inner text and its correct?
                      i am running out of energy for the day… been since 6am. now 11pm
                      • PerlchampP
                        Perlchamp
                        122 => next => marks “return”(131) => next => marks end of 131 => next => jumped to main.js
                          sdetweil @Perlchamp
                          @Perlchamp mark the line for the second for(
                          for(var birthday of Object.keys(this.active_birthdays)){
                          			for(var name of this.active_birthdays[birthday]){              // stop on this line
                          and remove the other stops
                          • PerlchampP
                            Perlchamp
                            the same see picture i did send to you. it’s line 122 => stop => refresh => and than like posted before
                            no does nothing … ok never mind. coming from germany it’s now 06:00 in the morning did’t sleep …
                              sdetweil @Perlchamp
                              @Perlchamp tomorrow, very close
                              • PerlchampP
                                Perlchamp
                                don’t worry about me and sleep well.
                                  sdetweil @Perlchamp
                                  @Perlchamp thx…
                                  in debugging
                                  put a stop on the self.updateDom() in the notiification code.
                                  no place else
                                  hit refresh
                                  when it stops there,
                                  scroll down to getdom and add a stop on the 1st for loop line
                                  hit run arrow,
                                  should stop in getdom now, with data
                                    @perl here is the updated perlchamp.js, shows date, persons name and age (no formatting)
                                    Module.register("perlchamp", {
                                    	defaults: {
                                    		language: "de",
                                    		dimmEntries: true,   // true: dims entries and the associated
                                    							//       symbol when the date has expired.
                                    							// false: delete entries and the associated
                                                     // used if look forward is desired, add to module config  in config.js
                                                     days_forward:0,
                                    	// place to save birthdays to display
                                        active_birthdays : {},
                                    	init: function(){
                                    		Log.log(this.name + " is in init!");
                                    	start: function(){
                                    		Log.log("Starting module: " + this.name);
                                    		// Set locale
                                    		moment.locale(config.language);
                                    	loaded: function(callback) {
                                    		Log.log(this.name + " is loaded!");
                                    		callback();
                                    	// return list of other functional scripts to use, if any (like require in node_helper)
                                    	getScripts: function() {
                                    		return	["moment.js"];
                                    	// return list of stylesheet files to use if any
                                    	getStyles: function() {
                                    		return 	[this.data.path + "/css/perlchamp.css"];
                                    	// return list of translation files to use, if any
                                    	getTranslations: function() {
                                    		return {
                                    			// sample of list of files to specify here, if no files, do not use this routine, , or return empty list
                                    			// en: "translations/en.json",  (folders and filenames in your module folder)
                                    			// de: "translations/de.json"
                                    	// only called if the module header was configured in module config in config.js
                                    	getHeader: function() {
                                    		return this.data.header;
                                    	// messages received from other modules and the system (NOT from your node helper)
                                    	// payload is a notification dependent data structure
                                    		// once everybody is loaded up
                                    		if(notification==="ALL_MODULES_STARTED"){
                                    			// send our config to our node_helper
                                    			this.sendSocketNotification("CONFIG",this.config);
                                    		if (sender) {
                                    			Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
                                    		} else {
                                    			Log.log(this.name + " received a system notification: " + notification);
                                    	// messages received from from your node helper (NOT other modules or the system)
                                    	// payload is a notification dependent data structure, up to you to design between module and node_helper
                                    		if(notification === "message_from_helper"){
                                    			this.config.message = payload;
                                    			// tell mirror runtime that our data has changed,
                                    			// we will be called back at GetDom() to provide the updated content
                                    			this.updateDom(1000);
                                    			var self = this
                                    			var now = moment();
                                    			// clear the old list
                                                            this.active_birthdays={}
                                    			// only calculate in advance once
                                    			var birthday_time_window=moment().add(self.config.days_forward,'days')
                                    			// loop thru the birthdays  from the file
                                    			for( var birthday of payload) {
                                    				var birth_date=birthday.birth.substring(0,5)
                                    				var birth_date_moment = moment(birth_date+now.year(),"DD.MMYYYY")
                                    				// u can add days to a moment object and then compare if the birthdate is before that date (and after now)
                                    			   if(birth_date_moment.startOf('day').isSameOrAfter(now.startOf('day')) &&
                                    			   	  birth_date_moment.startOf('day').isSameOrBefore(birthday_time_window.startOf('day'))
                                    			      if(self.active_birthdays[birth_date] == undefined){
                                    			           //  create the holder for its info (array of info) in the hash
                                    			           self.active_birthdays[birth_date]=[]
                                    			      // save the persons name and age on the list
                                    			      self.active_birthdays[birth_date].push({'name':birthday.name, 'age': now.diff(moment(birthday.birth,'DD.MM.YYYY'), 'years') })
                                    			self.updateDom();
                                    			// filters the birthdaylist and output only the birthdays
                                    			// of the current month, sorted (ascending) by days in
                                    			// the following format:
                                    			// [{ day: "10", name: ["firstname lastname",...] }]
                                    			// set variables
                                    			var today_month = moment().format("MM");
                                    			var today_day_month = moment().format("DD.MM");
                                    			var result = Object.entries(jsonObj
                                    			.filter(({birth}) => birth.split('.')[1] === today_month)
                                    			.reduce((a, {birth, name}) => {
                                    				const day = +birth.split('.')[0];
                                    				a[day] = [...(a[day] || []), name];
                                    				return a
                                    			).map(([day, name]) => ({day, name})).sort((a, b) => +a.day - b.day);
                                    			birthdaysArray = result;
                                    			// for debugging only
                                    			//console.log("filtered and sorted: ", birthdaysArray);
                                    	// system notification your module is being hidden
                                    	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
                                    	suspend: function(){
                                    	// system notification your module is being unhidden/shown
                                    	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
                                    	resume: function(){
                                    	// this is the major worker of the module, it provides the displayable content for this module
                                    	getDom: function() {
                                    // create your table and header here
                                    			for(var person of this.active_birthdays[birthday]){
                                    				var m=document.createElement('div')
                                    // create tyour table row here
                                    				m.innerText=birthday+ ' '+ person.name+' age='+person.age
                                    				wrapper.appendChild(m)
                                    // create your table footer here
                                    		// pass the created content back to MM to add to DOM.
                                    		return wrapper;
                                    this is the birthdays.csv I was using
                                    the column names are the field names in the jsonobj
                                    birth, name
                                    12.07.1952, Sam
                                    11.09.1944, Peg
                                    02.05.1939, Frank
                                    09.04.1953, June
                                    09.04.1953, Jane
                                    30.12.1955, Joan
                                    02.05.1939, Sue
                                    05.05.1955, mary
                                    • PerlchampP
                                      Perlchamp
                                      hi sam :-)
                                      see my module-file. why i don’t get values for the Log.log(); statements ?
                                      		var self = this;
                                      		Log.log("this.active_birthdays >>>>> ", this.active_birthdays);
                                      		for(var birthday of Object.keys(this.active_birthdays)) {
                                      			for(var name of this.active_birthdays[birthday]) {
                                      				var m = document.createElement("div");
                                      				Log.log("BIRTHDAY >> " + birthday);
                                      				Log.log("NAME >> " + name);
                                      				m.innerText = birthday + " " + name;
                                      				wrapper.appendChild(m);
                                      		return wrapper;
                                        sdetweil @Perlchamp
                                        @Perlchamp said in read csv-data and put it in an array:
                                        that means one of those two for loops didn’t execute, as the list is empty
                                        do this
                                        Log.log(JSON.stringify(this.active_birthdays))    // add this line
                                        			self.updateDom();                          // before this line in the notification code..
                                        • PerlchampP
                                          Perlchamp
                                          and where i have to place it ?
                                            sdetweil @Perlchamp
                                            @Perlchamp see my updated post above
                                            • 10
                                            • 15
                                            • 16
                                            • 8 / 16
