    read csv-data and put it in an array
    313 Posts 3 Posters 590.4k Views 4 Watching
    • PerlchampP
      Perlchamp
      122 => next => marks “return”(131) => next => marks end of 131 => next => jumped to main.js
        sdetweil @Perlchamp
        @Perlchamp mark the line for the second for(
        for(var birthday of Object.keys(this.active_birthdays)){
        			for(var name of this.active_birthdays[birthday]){              // stop on this line
        and remove the other stops
        • PerlchampP
          Perlchamp
          the same see picture i did send to you. it’s line 122 => stop => refresh => and than like posted before
          no does nothing … ok never mind. coming from germany it’s now 06:00 in the morning did’t sleep …
            sdetweil @Perlchamp
            @Perlchamp tomorrow, very close
            • PerlchampP
              Perlchamp
              don’t worry about me and sleep well.
                sdetweil @Perlchamp
                @Perlchamp thx…
                in debugging
                put a stop on the self.updateDom() in the notiification code.
                no place else
                hit refresh
                when it stops there,
                scroll down to getdom and add a stop on the 1st for loop line
                hit run arrow,
                should stop in getdom now, with data
                  @perl here is the updated perlchamp.js, shows date, persons name and age (no formatting)
                  Module.register("perlchamp", {
                  	defaults: {
                  		language: "de",
                  		dimmEntries: true,   // true: dims entries and the associated
                  							//       symbol when the date has expired.
                  							// false: delete entries and the associated
                                   // used if look forward is desired, add to module config  in config.js
                                   days_forward:0,
                  	// place to save birthdays to display
                      active_birthdays : {},
                  	init: function(){
                  		Log.log(this.name + " is in init!");
                  	start: function(){
                  		Log.log("Starting module: " + this.name);
                  		// Set locale
                  		moment.locale(config.language);
                  	loaded: function(callback) {
                  		Log.log(this.name + " is loaded!");
                  		callback();
                  	// return list of other functional scripts to use, if any (like require in node_helper)
                  	getScripts: function() {
                  		return	["moment.js"];
                  	// return list of stylesheet files to use if any
                  	getStyles: function() {
                  		return 	[this.data.path + "/css/perlchamp.css"];
                  	// return list of translation files to use, if any
                  	getTranslations: function() {
                  		return {
                  			// sample of list of files to specify here, if no files, do not use this routine, , or return empty list
                  			// en: "translations/en.json",  (folders and filenames in your module folder)
                  			// de: "translations/de.json"
                  	// only called if the module header was configured in module config in config.js
                  	getHeader: function() {
                  		return this.data.header;
                  	// messages received from other modules and the system (NOT from your node helper)
                  	// payload is a notification dependent data structure
                  		// once everybody is loaded up
                  		if(notification==="ALL_MODULES_STARTED"){
                  			// send our config to our node_helper
                  			this.sendSocketNotification("CONFIG",this.config);
                  		if (sender) {
                  			Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
                  		} else {
                  			Log.log(this.name + " received a system notification: " + notification);
                  	// messages received from from your node helper (NOT other modules or the system)
                  	// payload is a notification dependent data structure, up to you to design between module and node_helper
                  		Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                  		if(notification === "message_from_helper"){
                  			this.config.message = payload;
                  			// tell mirror runtime that our data has changed,
                  			// we will be called back at GetDom() to provide the updated content
                  			this.updateDom(1000);
                  		if(notification === "have data"){
                  			var self = this
                  			var now = moment();
                  			// clear the old list
                                          this.active_birthdays={}
                  			// only calculate in advance once
                  			var birthday_time_window=moment().add(self.config.days_forward,'days')
                  			// loop thru the birthdays  from the file
                  			for( var birthday of payload) {
                  				// get 1st 5 chars of birthdate, thru month
                  				// we will use this as the key in the hash
                  				var birth_date=birthday.birth.substring(0,5)
                  				// get the birthday as a moment in this year, for comparing
                  				var birth_date_moment = moment(birth_date+now.year(),"DD.MMYYYY")
                  				// u can add days to a moment object and then compare if the birthdate is before that date (and after now)
                  				// so within the next xx days
                  			  // if the date is the same or later, don't use time of day
                  			   if(birth_date_moment.startOf('day').isSameOrAfter(now.startOf('day')) &&
                  			   	  birth_date_moment.startOf('day').isSameOrBefore(birthday_time_window.startOf('day'))
                  			      // birthday is in this month
                  			      // check the hash if we've seen anything for today yet
                  			      // if we haven't see this date yet
                  			      if(self.active_birthdays[birth_date] == undefined){
                  			           //  create the holder for its info (array of info) in the hash
                  			           self.active_birthdays[birth_date]=[]
                  			      // save the persons name and age on the list
                  			      self.active_birthdays[birth_date].push({'name':birthday.name, 'age': now.diff(moment(birthday.birth,'DD.MM.YYYY'), 'years') })
                  			// tell MM to call and get our content
                  			self.updateDom();
                  			// filters the birthdaylist and output only the birthdays
                  			// of the current month, sorted (ascending) by days in
                  			// the following format:
                  			// [{ day: "10", name: ["firstname lastname",...] }]
                  			// set variables
                  			var today_month = moment().format("MM");
                  			var today_day_month = moment().format("DD.MM");
                  			var result = Object.entries(jsonObj
                  			.filter(({birth}) => birth.split('.')[1] === today_month)
                  			.reduce((a, {birth, name}) => {
                  				const day = +birth.split('.')[0];
                  				a[day] = [...(a[day] || []), name];
                  				return a
                  			).map(([day, name]) => ({day, name})).sort((a, b) => +a.day - b.day);
                  			birthdaysArray = result;
                  			// for debugging only
                  			//console.log("filtered and sorted: ", birthdaysArray);
                  	// system notification your module is being hidden
                  	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
                  	suspend: function(){
                  	// system notification your module is being unhidden/shown
                  	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
                  	resume: function(){
                  	// this is the major worker of the module, it provides the displayable content for this module
                  	getDom: function() {
                  // create your table and header here
                  			for(var person of this.active_birthdays[birthday]){
                  				var m=document.createElement('div')
                  // create tyour table row here
                  				m.innerText=birthday+ ' '+ person.name+' age='+person.age
                  				wrapper.appendChild(m)
                  // create your table footer here
                  		// pass the created content back to MM to add to DOM.
                  		return wrapper;
                  this is the birthdays.csv I was using
                  the column names are the field names in the jsonobj
                  birth, name
                  12.07.1952, Sam
                  11.09.1944, Peg
                  02.05.1939, Frank
                  09.04.1953, June
                  09.04.1953, Jane
                  30.12.1955, Joan
                  02.05.1939, Sue
                  05.05.1955, mary
                  • PerlchampP
                    Perlchamp
                    hi sam :-)
                    see my module-file. why i don’t get values for the Log.log(); statements ?
                    		var self = this;
                    		Log.log("this.active_birthdays >>>>> ", this.active_birthdays);
                    		for(var birthday of Object.keys(this.active_birthdays)) {
                    			for(var name of this.active_birthdays[birthday]) {
                    				var m = document.createElement("div");
                    				Log.log("BIRTHDAY >> " + birthday);
                    				Log.log("NAME >> " + name);
                    				m.innerText = birthday + " " + name;
                    				wrapper.appendChild(m);
                    		return wrapper;
                      sdetweil @Perlchamp
                      @Perlchamp said in read csv-data and put it in an array:
                      that means one of those two for loops didn’t execute, as the list is empty
                      do this
                      Log.log(JSON.stringify(this.active_birthdays))    // add this line
                      			self.updateDom();                          // before this line in the notification code..
                      • PerlchampP
                        Perlchamp
                        and where i have to place it ?
                          sdetweil @Perlchamp
                          @Perlchamp see my updated post above
                          • PerlchampP
                            Perlchamp
                            i get this for each entry (here i only posted one of them):
                            [2020-05-02 17:50:36.803] [LOG]    LOOK >>>>>>{} (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                            empty: {}
                              sdetweil @Perlchamp
                              @Perlchamp ok, so the data collection didn’t work…
                              so I would step thru that code
                              what is the 1st row of your csv file? the column headers
                              • PerlchampP
                                Perlchamp
                                before you do this. stop. i make an error. the code you posted is not in the notification section. it’s in the getDom section … so i placed it there. was this wrong ?
                                  sdetweil @Perlchamp
                                  @Perlchamp there is NOT an this. updateDom() in the getDom() section…
                                  still doesn’t change the result… there are no birthdays found that match 02/05
                                  • PerlchampP
                                    Perlchamp
                                    the columns are:
                                    birth, name
                                    and is called “birthdays.csv”
                                    the data are:
                                    23.01.1987,Thomas Roth
                                      sdetweil @Perlchamp
                                      @Perlchamp so there are no birthdays for today… we are ONLY selecting for TODAY. not every day
                                      • PerlchampP
                                        Perlchamp
                                        why for TODAY ? and not for current MONTH ?
                                        getDon:
                                        		var self = this;
                                        Log.log("LOOK >>>>>>" + JSON.stringify(this.active_birthdays))    // add this line
                                        		return wrapper;
                                          sdetweil @Perlchamp
                                          Log.log(“LOOK >>>>>>” + JSON.stringify(this.active_birthdays)) // add this line
                                          self.updateDom();
                                          not that way
                                          sorry, didn’t see the ‘month’.
                                          still doesn’t matter, that birthday is for january, so nothing to show for may
                                          change this compare to do only month
                                          hint, google get month from moment
                                          • PerlchampP
                                            Perlchamp
                                            i got this:
                                            [2020-05-02 18:10:50.465] [LOG]    {} (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                            for each entry. i have 5 birthdays in may …
                                            • 10
                                            • 15
                                            • 16
                                            • 8 / 16
