    read csv-data and put it in an array
    313 Posts 3 Posters 579.1k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp and getDom() will be called multiple times, once before your data arrives, maybe once more than when you data is ready
      and it does the innerText statement?
      and u look at the element, and look at the inner text and its correct?
      i am running out of energy for the day… been since 6am. now 11pm
      • PerlchampP
        Perlchamp
        122 => next => marks “return”(131) => next => marks end of 131 => next => jumped to main.js
          sdetweil @Perlchamp
          @Perlchamp mark the line for the second for(
          for(var birthday of Object.keys(this.active_birthdays)){
          			for(var name of this.active_birthdays[birthday]){              // stop on this line
          and remove the other stops
          • PerlchampP
            Perlchamp
            the same see picture i did send to you. it’s line 122 => stop => refresh => and than like posted before
            no does nothing … ok never mind. coming from germany it’s now 06:00 in the morning did’t sleep …
              sdetweil @Perlchamp
              @Perlchamp tomorrow, very close
              • PerlchampP
                Perlchamp
                don’t worry about me and sleep well.
                  sdetweil @Perlchamp
                  @Perlchamp thx…
                  in debugging
                  put a stop on the self.updateDom() in the notiification code.
                  no place else
                  hit refresh
                  when it stops there,
                  scroll down to getdom and add a stop on the 1st for loop line
                  hit run arrow,
                  should stop in getdom now, with data
                    @perl here is the updated perlchamp.js, shows date, persons name and age (no formatting)
                    Module.register("perlchamp", {
                    	defaults: {
                    		language: "de",
                    		dimmEntries: true,   // true: dims entries and the associated
                    							//       symbol when the date has expired.
                    							// false: delete entries and the associated
                                     // used if look forward is desired, add to module config  in config.js
                                     days_forward:0,
                    	// place to save birthdays to display
                        active_birthdays : {},
                    	init: function(){
                    		Log.log(this.name + " is in init!");
                    	start: function(){
                    		Log.log("Starting module: " + this.name);
                    		// Set locale
                    		moment.locale(config.language);
                    	loaded: function(callback) {
                    		Log.log(this.name + " is loaded!");
                    		callback();
                    	// return list of other functional scripts to use, if any (like require in node_helper)
                    	getScripts: function() {
                    		return	["moment.js"];
                    	// return list of stylesheet files to use if any
                    	getStyles: function() {
                    		return 	[this.data.path + "/css/perlchamp.css"];
                    	// return list of translation files to use, if any
                    	getTranslations: function() {
                    		return {
                    			// sample of list of files to specify here, if no files, do not use this routine, , or return empty list
                    			// en: "translations/en.json",  (folders and filenames in your module folder)
                    			// de: "translations/de.json"
                    	// only called if the module header was configured in module config in config.js
                    	getHeader: function() {
                    		return this.data.header;
                    	// messages received from other modules and the system (NOT from your node helper)
                    	// payload is a notification dependent data structure
                    		// once everybody is loaded up
                    		if(notification==="ALL_MODULES_STARTED"){
                    			// send our config to our node_helper
                    			this.sendSocketNotification("CONFIG",this.config);
                    		if (sender) {
                    			Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
                    		} else {
                    			Log.log(this.name + " received a system notification: " + notification);
                    	// messages received from from your node helper (NOT other modules or the system)
                    	// payload is a notification dependent data structure, up to you to design between module and node_helper
                    		Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                    		if(notification === "message_from_helper"){
                    			this.config.message = payload;
                    			// tell mirror runtime that our data has changed,
                    			// we will be called back at GetDom() to provide the updated content
                    			this.updateDom(1000);
                    		if(notification === "have data"){
                    			var self = this
                    			var now = moment();
                    			// clear the old list
                                            this.active_birthdays={}
                    			// only calculate in advance once
                    			var birthday_time_window=moment().add(self.config.days_forward,'days')
                    			// loop thru the birthdays  from the file
                    			for( var birthday of payload) {
                    				// get 1st 5 chars of birthdate, thru month
                    				// we will use this as the key in the hash
                    				var birth_date=birthday.birth.substring(0,5)
                    				// get the birthday as a moment in this year, for comparing
                    				var birth_date_moment = moment(birth_date+now.year(),"DD.MMYYYY")
                    				// u can add days to a moment object and then compare if the birthdate is before that date (and after now)
                    				// so within the next xx days
                    			  // if the date is the same or later, don't use time of day
                    			   if(birth_date_moment.startOf('day').isSameOrAfter(now.startOf('day')) &&
                    			   	  birth_date_moment.startOf('day').isSameOrBefore(birthday_time_window.startOf('day'))
                    			      // birthday is in this month
                    			      // check the hash if we've seen anything for today yet
                    			      // if we haven't see this date yet
                    			      if(self.active_birthdays[birth_date] == undefined){
                    			           //  create the holder for its info (array of info) in the hash
                    			           self.active_birthdays[birth_date]=[]
                    			      // save the persons name and age on the list
                    			      self.active_birthdays[birth_date].push({'name':birthday.name, 'age': now.diff(moment(birthday.birth,'DD.MM.YYYY'), 'years') })
                    			// tell MM to call and get our content
                    			self.updateDom();
                    			// filters the birthdaylist and output only the birthdays
                    			// of the current month, sorted (ascending) by days in
                    			// the following format:
                    			// [{ day: "10", name: ["firstname lastname",...] }]
                    			// set variables
                    			var today_month = moment().format("MM");
                    			var today_day_month = moment().format("DD.MM");
                    			var result = Object.entries(jsonObj
                    			.filter(({birth}) => birth.split('.')[1] === today_month)
                    			.reduce((a, {birth, name}) => {
                    				const day = +birth.split('.')[0];
                    				a[day] = [...(a[day] || []), name];
                    				return a
                    			).map(([day, name]) => ({day, name})).sort((a, b) => +a.day - b.day);
                    			birthdaysArray = result;
                    			// for debugging only
                    			//console.log("filtered and sorted: ", birthdaysArray);
                    	// system notification your module is being hidden
                    	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
                    	suspend: function(){
                    	// system notification your module is being unhidden/shown
                    	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
                    	resume: function(){
                    	// this is the major worker of the module, it provides the displayable content for this module
                    	getDom: function() {
                    // create your table and header here
                    			for(var person of this.active_birthdays[birthday]){
                    				var m=document.createElement('div')
                    // create tyour table row here
                    				m.innerText=birthday+ ' '+ person.name+' age='+person.age
                    				wrapper.appendChild(m)
                    // create your table footer here
                    		// pass the created content back to MM to add to DOM.
                    		return wrapper;
                    this is the birthdays.csv I was using
                    the column names are the field names in the jsonobj
                    birth, name
                    12.07.1952, Sam
                    11.09.1944, Peg
                    02.05.1939, Frank
                    09.04.1953, June
                    09.04.1953, Jane
                    30.12.1955, Joan
                    02.05.1939, Sue
                    05.05.1955, mary
                    • PerlchampP
                      Perlchamp
                      hi sam :-)
                      see my module-file. why i don’t get values for the Log.log(); statements ?
                      		var self = this;
                      		Log.log("this.active_birthdays >>>>> ", this.active_birthdays);
                      		for(var birthday of Object.keys(this.active_birthdays)) {
                      			for(var name of this.active_birthdays[birthday]) {
                      				var m = document.createElement("div");
                      				Log.log("BIRTHDAY >> " + birthday);
                      				Log.log("NAME >> " + name);
                      				m.innerText = birthday + " " + name;
                      				wrapper.appendChild(m);
                      		return wrapper;
                        sdetweil @Perlchamp
                        @Perlchamp said in read csv-data and put it in an array:
                        that means one of those two for loops didn’t execute, as the list is empty
                        do this
                        Log.log(JSON.stringify(this.active_birthdays))    // add this line
                        			self.updateDom();                          // before this line in the notification code..
                        • PerlchampP
                          Perlchamp
                          and where i have to place it ?
                            sdetweil @Perlchamp
                            @Perlchamp see my updated post above
                            • PerlchampP
                              Perlchamp
                              i get this for each entry (here i only posted one of them):
                              [2020-05-02 17:50:36.803] [LOG]    LOOK >>>>>>{} (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                              empty: {}
                                sdetweil @Perlchamp
                                @Perlchamp ok, so the data collection didn’t work…
                                so I would step thru that code
                                what is the 1st row of your csv file? the column headers
                                • PerlchampP
                                  Perlchamp
                                  before you do this. stop. i make an error. the code you posted is not in the notification section. it’s in the getDom section … so i placed it there. was this wrong ?
                                    sdetweil @Perlchamp
                                    @Perlchamp there is NOT an this. updateDom() in the getDom() section…
                                    still doesn’t change the result… there are no birthdays found that match 02/05
                                    • PerlchampP
                                      Perlchamp
                                      the columns are:
                                      birth, name
                                      and is called “birthdays.csv”
                                      the data are:
                                      23.01.1987,Thomas Roth
                                        sdetweil @Perlchamp
                                        @Perlchamp so there are no birthdays for today… we are ONLY selecting for TODAY. not every day
                                        • PerlchampP
                                          Perlchamp
                                          why for TODAY ? and not for current MONTH ?
                                          getDon:
                                          		var self = this;
                                          Log.log("LOOK >>>>>>" + JSON.stringify(this.active_birthdays))    // add this line
                                          		return wrapper;
                                            sdetweil @Perlchamp
                                            Log.log(“LOOK >>>>>>” + JSON.stringify(this.active_birthdays)) // add this line
                                            self.updateDom();
                                            not that way
                                            sorry, didn’t see the ‘month’.
                                            still doesn’t matter, that birthday is for january, so nothing to show for may
                                            change this compare to do only month
                                            hint, google get month from moment
                                            • 10
                                            • 15
                                            • 16
                                            • 8 / 16
