    read csv-data and put it in an array
    313 Posts 3 Posters 590.7k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp click on line number 122 for a stop… birthday is not defined once you leave the for loop…
      • PerlchampP
        Perlchamp
        yes i did. all variables are correct
          sdetweil @Perlchamp
          @Perlchamp and getDom() will be called multiple times, once before your data arrives, maybe once more than when you data is ready
          and it does the innerText statement?
          and u look at the element, and look at the inner text and its correct?
          i am running out of energy for the day… been since 6am. now 11pm
          • PerlchampP
            Perlchamp
            122 => next => marks “return”(131) => next => marks end of 131 => next => jumped to main.js
              sdetweil @Perlchamp
              @Perlchamp mark the line for the second for(
              for(var birthday of Object.keys(this.active_birthdays)){
              			for(var name of this.active_birthdays[birthday]){              // stop on this line
              and remove the other stops
              • PerlchampP
                Perlchamp
                the same see picture i did send to you. it’s line 122 => stop => refresh => and than like posted before
                no does nothing … ok never mind. coming from germany it’s now 06:00 in the morning did’t sleep …
                  sdetweil @Perlchamp
                  @Perlchamp tomorrow, very close
                  • PerlchampP
                    Perlchamp
                    don’t worry about me and sleep well.
                      sdetweil @Perlchamp
                      @Perlchamp thx…
                      in debugging
                      put a stop on the self.updateDom() in the notiification code.
                      no place else
                      hit refresh
                      when it stops there,
                      scroll down to getdom and add a stop on the 1st for loop line
                      hit run arrow,
                      should stop in getdom now, with data
                        @perl here is the updated perlchamp.js, shows date, persons name and age (no formatting)
                        Module.register("perlchamp", {
                        	defaults: {
                        		language: "de",
                        		dimmEntries: true,   // true: dims entries and the associated
                        							//       symbol when the date has expired.
                        							// false: delete entries and the associated
                                         // used if look forward is desired, add to module config  in config.js
                                         days_forward:0,
                        	// place to save birthdays to display
                            active_birthdays : {},
                        	init: function(){
                        		Log.log(this.name + " is in init!");
                        	start: function(){
                        		Log.log("Starting module: " + this.name);
                        		// Set locale
                        		moment.locale(config.language);
                        	loaded: function(callback) {
                        		Log.log(this.name + " is loaded!");
                        		callback();
                        	// return list of other functional scripts to use, if any (like require in node_helper)
                        	getScripts: function() {
                        		return	["moment.js"];
                        	// return list of stylesheet files to use if any
                        	getStyles: function() {
                        		return 	[this.data.path + "/css/perlchamp.css"];
                        	// return list of translation files to use, if any
                        	getTranslations: function() {
                        		return {
                        			// sample of list of files to specify here, if no files, do not use this routine, , or return empty list
                        			// en: "translations/en.json",  (folders and filenames in your module folder)
                        			// de: "translations/de.json"
                        	// only called if the module header was configured in module config in config.js
                        	getHeader: function() {
                        		return this.data.header;
                        	// messages received from other modules and the system (NOT from your node helper)
                        	// payload is a notification dependent data structure
                        		// once everybody is loaded up
                        		if(notification==="ALL_MODULES_STARTED"){
                        			// send our config to our node_helper
                        			this.sendSocketNotification("CONFIG",this.config);
                        		if (sender) {
                        			Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
                        		} else {
                        			Log.log(this.name + " received a system notification: " + notification);
                        	// messages received from from your node helper (NOT other modules or the system)
                        	// payload is a notification dependent data structure, up to you to design between module and node_helper
                        		Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                        		if(notification === "message_from_helper"){
                        			this.config.message = payload;
                        			// tell mirror runtime that our data has changed,
                        			// we will be called back at GetDom() to provide the updated content
                        			this.updateDom(1000);
                        		if(notification === "have data"){
                        			var self = this
                        			var now = moment();
                        			// clear the old list
                                                this.active_birthdays={}
                        			// only calculate in advance once
                        			var birthday_time_window=moment().add(self.config.days_forward,'days')
                        			// loop thru the birthdays  from the file
                        			for( var birthday of payload) {
                        				// get 1st 5 chars of birthdate, thru month
                        				// we will use this as the key in the hash
                        				var birth_date=birthday.birth.substring(0,5)
                        				// get the birthday as a moment in this year, for comparing
                        				var birth_date_moment = moment(birth_date+now.year(),"DD.MMYYYY")
                        				// u can add days to a moment object and then compare if the birthdate is before that date (and after now)
                        				// so within the next xx days
                        			  // if the date is the same or later, don't use time of day
                        			   if(birth_date_moment.startOf('day').isSameOrAfter(now.startOf('day')) &&
                        			   	  birth_date_moment.startOf('day').isSameOrBefore(birthday_time_window.startOf('day'))
                        			      // birthday is in this month
                        			      // check the hash if we've seen anything for today yet
                        			      // if we haven't see this date yet
                        			      if(self.active_birthdays[birth_date] == undefined){
                        			           //  create the holder for its info (array of info) in the hash
                        			           self.active_birthdays[birth_date]=[]
                        			      // save the persons name and age on the list
                        			      self.active_birthdays[birth_date].push({'name':birthday.name, 'age': now.diff(moment(birthday.birth,'DD.MM.YYYY'), 'years') })
                        			// tell MM to call and get our content
                        			self.updateDom();
                        			// filters the birthdaylist and output only the birthdays
                        			// of the current month, sorted (ascending) by days in
                        			// the following format:
                        			// [{ day: "10", name: ["firstname lastname",...] }]
                        			// set variables
                        			var today_month = moment().format("MM");
                        			var today_day_month = moment().format("DD.MM");
                        			var result = Object.entries(jsonObj
                        			.filter(({birth}) => birth.split('.')[1] === today_month)
                        			.reduce((a, {birth, name}) => {
                        				const day = +birth.split('.')[0];
                        				a[day] = [...(a[day] || []), name];
                        				return a
                        			).map(([day, name]) => ({day, name})).sort((a, b) => +a.day - b.day);
                        			birthdaysArray = result;
                        			// for debugging only
                        			//console.log("filtered and sorted: ", birthdaysArray);
                        	// system notification your module is being hidden
                        	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
                        	suspend: function(){
                        	// system notification your module is being unhidden/shown
                        	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
                        	resume: function(){
                        	// this is the major worker of the module, it provides the displayable content for this module
                        	getDom: function() {
                        // create your table and header here
                        			for(var person of this.active_birthdays[birthday]){
                        				var m=document.createElement('div')
                        // create tyour table row here
                        				m.innerText=birthday+ ' '+ person.name+' age='+person.age
                        				wrapper.appendChild(m)
                        // create your table footer here
                        		// pass the created content back to MM to add to DOM.
                        		return wrapper;
                        this is the birthdays.csv I was using
                        the column names are the field names in the jsonobj
                        birth, name
                        12.07.1952, Sam
                        11.09.1944, Peg
                        02.05.1939, Frank
                        09.04.1953, June
                        09.04.1953, Jane
                        30.12.1955, Joan
                        02.05.1939, Sue
                        05.05.1955, mary
                        • PerlchampP
                          Perlchamp
                          hi sam :-)
                          see my module-file. why i don’t get values for the Log.log(); statements ?
                          		var self = this;
                          		Log.log("this.active_birthdays >>>>> ", this.active_birthdays);
                          		for(var birthday of Object.keys(this.active_birthdays)) {
                          			for(var name of this.active_birthdays[birthday]) {
                          				var m = document.createElement("div");
                          				Log.log("BIRTHDAY >> " + birthday);
                          				Log.log("NAME >> " + name);
                          				m.innerText = birthday + " " + name;
                          				wrapper.appendChild(m);
                          		return wrapper;
                            sdetweil @Perlchamp
                            @Perlchamp said in read csv-data and put it in an array:
                            that means one of those two for loops didn’t execute, as the list is empty
                            do this
                            Log.log(JSON.stringify(this.active_birthdays))    // add this line
                            			self.updateDom();                          // before this line in the notification code..
                            • PerlchampP
                              Perlchamp
                              and where i have to place it ?
                                sdetweil @Perlchamp
                                @Perlchamp see my updated post above
                                • PerlchampP
                                  Perlchamp
                                  i get this for each entry (here i only posted one of them):
                                  [2020-05-02 17:50:36.803] [LOG]    LOOK >>>>>>{} (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                  empty: {}
                                    sdetweil @Perlchamp
                                    @Perlchamp ok, so the data collection didn’t work…
                                    so I would step thru that code
                                    what is the 1st row of your csv file? the column headers
                                    • PerlchampP
                                      Perlchamp
                                      before you do this. stop. i make an error. the code you posted is not in the notification section. it’s in the getDom section … so i placed it there. was this wrong ?
                                        sdetweil @Perlchamp
                                        @Perlchamp there is NOT an this. updateDom() in the getDom() section…
                                        still doesn’t change the result… there are no birthdays found that match 02/05
                                        • PerlchampP
                                          Perlchamp
                                          the columns are:
                                          birth, name
                                          and is called “birthdays.csv”
                                          the data are:
                                          23.01.1987,Thomas Roth
                                            sdetweil @Perlchamp
                                            @Perlchamp so there are no birthdays for today… we are ONLY selecting for TODAY. not every day
                                            • 10
                                            • 15
                                            • 16
                                            • 8 / 16
