    read csv-data and put it in an array
    313 Posts 3 Posters 530.3k Views 4 Watching
    • PerlchampP Offline
      Perlchamp
      how said:
      if i click on the linenumber of getDom: the blue arrow run to the last line. i can’t stop it or something else … it runs thru
        sdetweil @Perlchamp
        @Perlchamp i don’t understand
        in code view, scroll down to getDom, next line, click the number to the left, turns blue
        hit refresh
          Perlchamp
          all values “undefined”
            sdetweil @Perlchamp
            @Perlchamp this.active_brithdays undefined?
            did u fix the names in the notification handler?
            		if(notification === "have data"){
            			var self = this
            			Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
            			var now = moment();
            			for(var birthday of payload) {
            				// get 1st 5 chars of birthdate, thru month
            				// we will use this as the key in the hash
            				var birth_date = birthday.birth.substring(0,5);
            				// get the birthday as a moment in this year, for comparing
            				var birth_date_moment = moment(birth_date + now.year(),"DD.MMYYYY");
            				// u can add days to a moment object and then compare
            				//     if the birthdate is before that date (and after now)
            				//     so within the next xx days
            				// if the date is the same or later, don't use time of day
            				if(birth_date_moment.startOf('day').isSame(now.startOf('day'))) {
            					// birthday is in this month
            					// check the hash if we've seen anything for today yet
            					// if we haven't see this date yet
            					if(this.active_birthdays[birth_date] == undefined){
            						//  create the holder for its info (array of
            						//		names) in the hash
            						this.active_birthdays[birth_date] = [];
            					// save the persons name on the list
            					this.active_birthdays[birth_date].push(birthday.name);
            			// tell MM to call and get our content
            			self.updateDom();
              Perlchamp
                sdetweil @Perlchamp
                @Perlchamp click on line number 122 for a stop… birthday is not defined once you leave the for loop…
                  Perlchamp
                  yes i did. all variables are correct
                    sdetweil @Perlchamp
                    @Perlchamp and getDom() will be called multiple times, once before your data arrives, maybe once more than when you data is ready
                    and it does the innerText statement?
                    and u look at the element, and look at the inner text and its correct?
                    i am running out of energy for the day… been since 6am. now 11pm
                      Perlchamp
                      122 => next => marks “return”(131) => next => marks end of 131 => next => jumped to main.js
                        sdetweil @Perlchamp
                        @Perlchamp mark the line for the second for(
                        for(var birthday of Object.keys(this.active_birthdays)){
                        			for(var name of this.active_birthdays[birthday]){              // stop on this line
                        and remove the other stops
                          Perlchamp
                          the same see picture i did send to you. it’s line 122 => stop => refresh => and than like posted before
                          no does nothing … ok never mind. coming from germany it’s now 06:00 in the morning did’t sleep …
                            sdetweil @Perlchamp
                            @Perlchamp tomorrow, very close
                              Perlchamp
                              don’t worry about me and sleep well.
                                sdetweil @Perlchamp
                                @Perlchamp thx…
                                in debugging
                                put a stop on the self.updateDom() in the notiification code.
                                no place else
                                hit refresh
                                when it stops there,
                                scroll down to getdom and add a stop on the 1st for loop line
                                hit run arrow,
                                should stop in getdom now, with data
                                  @perl here is the updated perlchamp.js, shows date, persons name and age (no formatting)
                                  Module.register("perlchamp", {
                                  	defaults: {
                                  		language: "de",
                                  		dimmEntries: true,   // true: dims entries and the associated
                                  							//       symbol when the date has expired.
                                  							// false: delete entries and the associated
                                                   // used if look forward is desired, add to module config  in config.js
                                                   days_forward:0,
                                  	// place to save birthdays to display
                                      active_birthdays : {},
                                  	init: function(){
                                  		Log.log(this.name + " is in init!");
                                  	start: function(){
                                  		Log.log("Starting module: " + this.name);
                                  		// Set locale
                                  		moment.locale(config.language);
                                  	loaded: function(callback) {
                                  		Log.log(this.name + " is loaded!");
                                  		callback();
                                  	// return list of other functional scripts to use, if any (like require in node_helper)
                                  	getScripts: function() {
                                  		return	["moment.js"];
                                  	// return list of stylesheet files to use if any
                                  	getStyles: function() {
                                  		return 	[this.data.path + "/css/perlchamp.css"];
                                  	// return list of translation files to use, if any
                                  	getTranslations: function() {
                                  		return {
                                  			// sample of list of files to specify here, if no files, do not use this routine, , or return empty list
                                  			// en: "translations/en.json",  (folders and filenames in your module folder)
                                  			// de: "translations/de.json"
                                  	// only called if the module header was configured in module config in config.js
                                  	getHeader: function() {
                                  		return this.data.header;
                                  	// messages received from other modules and the system (NOT from your node helper)
                                  	// payload is a notification dependent data structure
                                  		// once everybody is loaded up
                                  		if(notification==="ALL_MODULES_STARTED"){
                                  			// send our config to our node_helper
                                  			this.sendSocketNotification("CONFIG",this.config);
                                  		if (sender) {
                                  			Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
                                  		} else {
                                  			Log.log(this.name + " received a system notification: " + notification);
                                  	// messages received from from your node helper (NOT other modules or the system)
                                  	// payload is a notification dependent data structure, up to you to design between module and node_helper
                                  		if(notification === "message_from_helper"){
                                  			this.config.message = payload;
                                  			// tell mirror runtime that our data has changed,
                                  			// we will be called back at GetDom() to provide the updated content
                                  			this.updateDom(1000);
                                  			var self = this
                                  			var now = moment();
                                  			// clear the old list
                                                          this.active_birthdays={}
                                  			// only calculate in advance once
                                  			var birthday_time_window=moment().add(self.config.days_forward,'days')
                                  			// loop thru the birthdays  from the file
                                  			for( var birthday of payload) {
                                  				var birth_date=birthday.birth.substring(0,5)
                                  				var birth_date_moment = moment(birth_date+now.year(),"DD.MMYYYY")
                                  				// u can add days to a moment object and then compare if the birthdate is before that date (and after now)
                                  			   if(birth_date_moment.startOf('day').isSameOrAfter(now.startOf('day')) &&
                                  			   	  birth_date_moment.startOf('day').isSameOrBefore(birthday_time_window.startOf('day'))
                                  			      if(self.active_birthdays[birth_date] == undefined){
                                  			           //  create the holder for its info (array of info) in the hash
                                  			           self.active_birthdays[birth_date]=[]
                                  			      // save the persons name and age on the list
                                  			      self.active_birthdays[birth_date].push({'name':birthday.name, 'age': now.diff(moment(birthday.birth,'DD.MM.YYYY'), 'years') })
                                  			self.updateDom();
                                  			// filters the birthdaylist and output only the birthdays
                                  			// of the current month, sorted (ascending) by days in
                                  			// the following format:
                                  			// [{ day: "10", name: ["firstname lastname",...] }]
                                  			// set variables
                                  			var today_month = moment().format("MM");
                                  			var today_day_month = moment().format("DD.MM");
                                  			var result = Object.entries(jsonObj
                                  			.filter(({birth}) => birth.split('.')[1] === today_month)
                                  			.reduce((a, {birth, name}) => {
                                  				const day = +birth.split('.')[0];
                                  				a[day] = [...(a[day] || []), name];
                                  				return a
                                  			).map(([day, name]) => ({day, name})).sort((a, b) => +a.day - b.day);
                                  			birthdaysArray = result;
                                  			// for debugging only
                                  			//console.log("filtered and sorted: ", birthdaysArray);
                                  	// system notification your module is being hidden
                                  	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
                                  	suspend: function(){
                                  	// system notification your module is being unhidden/shown
                                  	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
                                  	resume: function(){
                                  	// this is the major worker of the module, it provides the displayable content for this module
                                  	getDom: function() {
                                  // create your table and header here
                                  			for(var person of this.active_birthdays[birthday]){
                                  				var m=document.createElement('div')
                                  // create tyour table row here
                                  				m.innerText=birthday+ ' '+ person.name+' age='+person.age
                                  				wrapper.appendChild(m)
                                  // create your table footer here
                                  		// pass the created content back to MM to add to DOM.
                                  		return wrapper;
                                  this is the birthdays.csv I was using
                                  the column names are the field names in the jsonobj
                                  birth, name
                                  12.07.1952, Sam
                                  11.09.1944, Peg
                                  02.05.1939, Frank
                                  09.04.1953, June
                                  09.04.1953, Jane
                                  30.12.1955, Joan
                                  02.05.1939, Sue
                                  05.05.1955, mary
                                    Perlchamp
                                    hi sam :-)
                                    see my module-file. why i don’t get values for the Log.log(); statements ?
                                    		var self = this;
                                    		Log.log("this.active_birthdays >>>>> ", this.active_birthdays);
                                    		for(var birthday of Object.keys(this.active_birthdays)) {
                                    			for(var name of this.active_birthdays[birthday]) {
                                    				var m = document.createElement("div");
                                    				Log.log("BIRTHDAY >> " + birthday);
                                    				Log.log("NAME >> " + name);
                                    				m.innerText = birthday + " " + name;
                                    				wrapper.appendChild(m);
                                    		return wrapper;
                                      sdetweil @Perlchamp
                                      @Perlchamp said in read csv-data and put it in an array:
                                      that means one of those two for loops didn’t execute, as the list is empty
                                      do this
                                      Log.log(JSON.stringify(this.active_birthdays))    // add this line
                                      			self.updateDom();                          // before this line in the notification code..
                                        Perlchamp
                                        and where i have to place it ?
                                          sdetweil @Perlchamp
                                          @Perlchamp see my updated post above
                                            Perlchamp
                                            i get this for each entry (here i only posted one of them):
                                            [2020-05-02 17:50:36.803] [LOG]    LOOK >>>>>>{} (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                            empty: {}
                                            • 10
                                            • 15
                                            • 16
                                            • 8 / 16
