    MMM-GroveGesture dont work anoymore
    5 Posts 3 Posters 1.0k Views 3 Watching
      mrSnatz
      everything went smoothly yesterday, but today he no longer reacts in MagicMirror.
      But when I start the py file in the modules folder it shows me the gestures in the command line.
      Except for a restart of the Pis, I have not changed in the config.
      What could be the fault here?
      /* Magic Mirror green 42 Zoll
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "de",
      	timeFormat: 24,
      	units: "metric",
      			     // false, default for all  NON-armv6l devices
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      		  module: "MMM-Screencast",
      		  position: "middle_center",
      				position: "center",
      				height: "300",
      				width: "500"
      			module: "clock",
      				displayType: "digital",
      				displaySeconds: "false",
      				showWeek: "true",
      				clockBold: "true"
      			header: "Termine",
      						symbol: "calendar-check",
      						url: "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
      			module: "MMM-DarkSkyForecast",
      			header: "Wetter",
      			classes: "default everyone",
      			disabled: false,
      				apikey: "XXXXXXXXXXXXXXXXXXXXXXXXX", // Anmeldung bei darkskyforecast erforderlich
      				latitude: "XXXXXXXX", // eingabe von Standortkoordinaten
      				longitude: "XXXXXXXXX",
      				iconset: "3c",
      				concise: "true", //mehr oder weniger infos anzeigen lassen
      				forecastLayout: "tiled", // tiled or table
      				updateInterval: "10",
      				showSummary: "false",
      				label_days: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"],
      				label_timeFormat: "k[h]",
      				showWind: "false",
      				language: "de"
      			module: "MMM-pages",
      				modules:
      							["clock", "calendar", "MMM-DarkSkyForecast", "newsfeed"],
      							["MMM-Comics", "MMM-horoscope"],
      							["newsfeed"]
      				fixed: ["alert", "clock", "updatenotification", "MMM-page-indicator", "MMM-GroveGestures"],
      			module: "MMM-page-indicator",
      			position: "bottom_bar",
      				pages: 3,
      			module: "MMM-GroveGestures",
      			position: "bottom_left",
      				autoStart: true, //When Mirror starts, recognition will start.
      				verbose:true, // If set as `true`, useful messages will be logged.
      				recognitionTimeout: 1000, //Gesture sequence will be ended after this time from last recognized gesture.
      				cancelGesture: "WAVE", //If set, You can cancel gesture sequence with this gesture.
      				visible: true, //Recognized gesture sequence will be displayed on position
      				idleTimer: "0", // `0` for disable, After this time from last gesture, onIdle will be executed.
      				defaultCommandSet: "DEFAULT_MODE",
      				commandSet: {
      					"DEFAULT_MODE": {
      						"UP": {
      						  shellExec: "amixer set Speaker -- 15%+" // Erhöht die Lautsärke um 15%
      						"DOWN": {
      						  shellExec: "amixer set Speaker -- 15%-" // verringert die Lautstärke um 15%
      						"CLOCKWISE": {
      						  shellExec: "vcgencmd display_power 1" // schaltet den HDMI Port am Pi an. Monitor geht an
      						"ANTICLOCKWISE": {
      						  shellExec: "vcgencmd display_power 0" // schaltet den HDMI Port am Pi aus. Monitor geht in Standby
      						"LEFT": {
      						        notificationExec: {
      						          notification: "PAGE_DECREMENT",
      						"RIGHT": {
      						        notificationExec: {
      						          notification: "PAGE_INCREMENT",
      					"0": {
      						"UP": {
      						"DOWN": {
      						"CLOCKWISE": {
      						"ANTICLOCKWISE": {
      						"LEFT": {
      						        notificationExec: {
      						"RIGHT": {
      						        notificationExec: {
      					"1": {
      						"UP": {
      						"DOWN": {
      						"CLOCKWISE": {
      						"ANTICLOCKWISE": {
      						"LEFT": {
      						        notificationExec: {
      						"RIGHT": {
      						        notificationExec: {
      					"2": {
      						"UP": {
      						"DOWN": {
      						"CLOCKWISE": {
      						"ANTICLOCKWISE": {
      						"LEFT": {
      						        notificationExec: {
      						"RIGHT": {
      						        notificationExec: {
      				commandSetTrigger: {
      					  "DEFAULT_MODE": "DEFAULT_MODE",
      					  "PAGE_NUMBER_IS": (payload) => {return payload;}
      			module: "MMM-NotificationTrigger",
      				useWebhook: false,
      				triggers: [
      						trigger: "PAGE_DECREMENT",
      						fires: [
      								fire: "QUERY_PAGE_NUMBER",
      						trigger: "PAGE_INCREMENT",
      						fires: [
      			module: "MMM-horoscope",
      				sign: "libra",
      			module: "MMM-Comics",
      			position: "Bottom_left",
      				comics: ["dilbert", "xkcd", "garfield", "peanuts", "calvin+hobbes"],
      				updateInterval : 1000 * 60 * 30,
      				coloredImage: true,
      				maxWidth: 500,
      				maxHeight: 500,
      				timeForDaily: [6, 9],
      			module: "newsfeed",
      			position: "bottom_center",
      				feeds: [
      						title: "Tagesschau",
      						url: "http://www.tagesschau.de/xml/rss2"
      				showSourceTitle: "true",
      				showPublishDate: "true",
      				showDescription: "true",
      				lengthDescription: "400", //1-500 default is 400
      				updateInterval: "20000" //1000-60000 defalut is 10000 (10sek)
        mrSnatz
        Okay, I found the bug myself. For me, the sensor only works when all modules are loaded.
        FoziF I 2 Replies Last reply
        • FoziF
          Fozi Project Sponsor @mrSnatz
          @mrSnatz I can confirm your experience. Another bug is related to MMM-Remote. When I open MMM-Remote in a browser and change pages, MMM-GroveGesture stops and I need to reboot MM. I haven’t yet dug enough into this issue, but I will when I have some more time.
          M 1 Reply Last reply
            mrSnatz @Fozi
            @Fozi good to know. The remote function is still on my todo list
            • I
              illef @mrSnatz
              @mrsnatz can you explain what you mean with “only works when all modules are loaded”?
              Kannst du erklären, was du damit meinst?
