    read csv-data and put it in an array
    313 Posts 3 Posters 590.1k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp ok, not sure how u want to present the two people with the same date
      simplified code
      	getDom: function(){
      		var wrapper = this.createEl("div",null,null,null);
      		if(Object.keys(this.active_birthdays).length>0){
      			// create your table  here
      			var table = this.createEl("table", "birthday-table", null, wrapper );
      			// table header here, array of column names
      			var table_header=this.createTableHeader(table,null, ["date","Name","age"])
      			// create looped row section
      			var tBody = this.createEl('tbody', "birthday-t-body", "tbody", table, null);
      			var birthdays_seen= {}
      			for(var birthday of Object.keys(this.active_birthdays)) {
      			    for(var person of this.active_birthdays[birthday]) {
      					var bodyTR = this.createEl('tr', null, "TR-BODY" ,tBody, null);
      					let now = moment().format('DD.MM').valueOf();
      					let entrie=now
      				    if(this.config.dimmEntries) {
      						entrie = moment(birthday,'DD.MM').valueOf();
      					var bd = "";
      			    	if(birthdays_seen[birthday]==undefined){
      						bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
      						var imageTD = this.createEl('td', null, "TD-IMAGE_"+(entrie < now)?"DIMMED":'' , bodyTR, bd);
      					else{
      						this.createEl('span', null , null , bodyTR,bd);
      					var nameTD = this.createEl('td', null, "TD-BODY_"+(entrie < now)?"DIMMED":'' , bodyTR, person.name);
      					var spanTD = this.createEl("span", null, "TD-AGE_"+(entrie < now)?"DIMMED":'', nameTD, person.age);
      					var spacerTR = this.createEl('tr', null, null , tBody, null);
      					var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, "----");
      					spacerTD.colSpan = "2";
      					birthdays_seen[birthday] = true;
      		return wrapper;
      maybe? but why?
      we have currently two rows, 3 columns
         day       name   age
         empty  name   age
      you want ?? two columns?
         row (2 cols)
           day      name + age < br>
                       name + age
         row (3 cols)
           dayn   name   age
      • PerlchampP
        Perlchamp
        hi sam,
        right row 2 cols day name + age < br > … < br > name+age < br >
        the image below displays that:
        look at my code, it’s all implemated but not the users in one cell :
            getDom: function() {
        	var wrapper = this.createEl("div",null,null,null,null);
        	// tell MM to call and get our content
        	Log.log(JSON.stringify(this.active_birthdays));
        	if ((moment() > this.midnight) || (!this.loaded)) {
        	    var month = moment().month();
        	    var year = moment().year();
        	    var monthName = moment().format("MMMM");
        	    var monthLength = moment().daysInMonth();
        	    var now = moment();
        	    if(Object.keys(this.active_birthdays).length > 0) {
        		// create table
        		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper,null)
        		// create tableheader here
        		var table_header = this.createTableHeader(table, null, [" "," "]);
        		// create TBODY section with day names
        		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table, null);
        		var day_month_now = moment().format("DD.MM");
        		var spacer = " ";
        			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY" , tBody, null);
        			// delete leading 0 and month
        			var bd = "";
        			if(birthdays_seen[birthday] == undefined) {
        			if (this.compareDate(now,birthday,"DD.MM") === 1) {
        				var imageTD = this.createEl('td', "birthday-td-image", "TD-IMAGE_DIMMED" , bodyTR, bd);
        				var nameTD = this.createEl('td', "birthday-td-body", "TD-BODY_DIMMED" , bodyTR, person.name);
        				var spanTD = this.createEl("span", "birthday-span-body", "TD-AGE_DIMMED", nameTD, person.age);
        				var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, spacer);
        			    else {
        			else {
        			    var imageTD = this.createEl('td', "birthday-td-image", "TD-IMAGE" , bodyTR, bd);
        			    var nameTD = this.createEl('td', "birthday-td-body", "TD-BODY" , bodyTR, person.name);
        			    var spanTD = this.createEl("span", "birthday-span-body", "TD-AGE", nameTD, person.age);
        		// Create TFOOT section -- currently used for debugging only
        		if (this.config.debugging) {
        		    var table_footer = this.createTableFooter(tBody, null, [" "," "]);
        		    //footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
        		else {
        	    // pass the created content back to MM to add to DOM.
        	    return wrapper;
        	// Dom is loaded
        	this.loaded = true;
          sdetweil @Perlchamp
          @Perlchamp i missed the span instead of td for age… working on the join
          • PerlchampP
            Perlchamp
            i have the span ! look in my code !
              sdetweil @Perlchamp
              @Perlchamp
              updated
              	getDom: function(){
              					let entrie=now
              					var bd = "";
              									 this.createEl("span", null, null, nameTD, " ");						// needs class for width
              						var spanTDo = this.createEl("span", null, "TD-AGE_"+(entrie < now)?"DIMMED":'', nameTD, person.age);
              					else{
              						// add a break
              						this.createEl('br', null , null , spanTDo,null);
              						// add a span with name
              						var nameTD = this.createEl('span', null, "TD-BODY_"+(entrie < now)?"DIMMED":'' ,spanTDo, person.name);
              						// add a span with age
              						var spanTD = this.createEl("span", null, "TD-AGE_"+(entrie < now)?"DIMMED":'', spanTDo, person.age);
              					var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, " ");
              		return wrapper;
              if we see 1st time br, do date, name/span/age
              if second time add line break to old name list
              add span for name, span span for separator (need class for width), span for age
              • PerlchampP
                Perlchamp
                first i have to change my classes ? instead of TD-IMAGE TD-IMAGE_, ?
                  sdetweil @Perlchamp
                  @Perlchamp the classname is a string
                  and the front part is the same
                  so , you had duplicated code, just to change the classname…
                  I just used your if(entrie) to decide it the name needed the’DIMMED" part added
                  move the _ to the “DIMMED”, like this “_DIMMED”
                  then they will be TD-IMAGE and TD-IMAGE_DIMMED , just like you had it…
                  its the same row data and parentage, just a class change… (nice work having common names, so you could do this), got rid of that big else…
                  • PerlchampP
                    Perlchamp
                    css i don’t get to work. here’s my getDom:
                    	    var now = moment();
                    		// create table
                    		// create tableheader here, array of column names
                    		var spacer = " ";
                    			let entrie=now;
                    			var bd = "";
                    			    bd = (birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
                    			    var imageTD = this.createEl('td', null, "TD-IMAGE" + (entrie < now)?"_DIMMED":'' , bodyTR, bd);
                    			    var nameTD = this.createEl('td', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' , bodyTR, person.name);
                    			    var spanTDo = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', nameTD, person.age);
                    			else{
                    			    // add a break
                    			    var nameTD = this.createEl('span', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' ,spanTDo, person.name);
                    			    var spanTD = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', spanTDo, person.age);
                    		else {
                    	    return wrapper;
                    	// Dom is loaded
                    	this.loaded = true;
                    there should be an error i don’t see.
                      sdetweil @Perlchamp
                      @Perlchamp use the debugger, expand the elements tree, find the table and look at the classes assigned
                      • PerlchampP
                        Perlchamp
                        hi sam,
                        if i do this:
                           var imageTD = this.createEl("td", null, "TD-IMAGE", bodyTR, bd);
                        instead of this :
                        var imageTD = this.createEl("td", null, "TD-IMAGE" + (entrie < now)?"_DIMMED":'' , bodyTR, bd);
                        css are addressed. maybe something has to change in the createEl function ?
                        S 2 Replies Last reply
                          sdetweil @Perlchamp
                          @Perlchamp let me look…
                            sdetweil @Perlchamp
                            @Perlchamp
                            warning one ( was missing, fixed
                            SORRY… tested now… the + append didn’t work, had to force with concat()…
                            Its the two values, now and entrie
                            				let now = moment().format('DD.MM').valueOf();				 // this is string dd.mm
                            				let entrie=now
                            					entrie = moment(birthday,'DD.MM').format.valueOf();     // this is a moment
                            so later when compared, it doesn;t work
                            and comparing strings with < doesn’t really work…
                            I would do
                            let now=moment()
                            let entrie = moment(birthday,‘DD.MM’)
                            then in the compare
                            (entrie.isBefore(now))?..
                            	getDom: function(){
                            					let now = moment()
                            					let entrie=now
                            					var bd = "";
                            						var imageTD = this.createEl('td', null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, bd);
                            						var nameTD = this.createEl('td', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, person.name);
                            						var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), nameTD, person.age);
                            					else{
                            						// add a break
                            						var nameTD = this.createEl('span', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') ,spanTDo, person.name);
                            						var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), spanTDo, person.age);
                            		return wrapper;
                              @Perlchamp see my update above
                              • PerlchampP
                                Perlchamp
                                @sdetweil said in read csv-data and put it in an array:
                                sorry, doesn’t work. blackscreen. if i change back (my post) css is addressed. i didn’t change the jet = part. i think, something’s wrong with the cerateEl function, but you know i’m not an expert.but to control. here is my code :
                                			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY", tBody, null);
                                			let now = moment();
                                			let entrie = moment(birthday,"DD.MM");
                                			    entrie = moment(birthday,'DD.MM');
                                			var bd = "";
                                			    //var imageTD = this.createEl('td', null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, bd);
                                			    //var nameTD = this.createEl("td", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, person.name);
                                			    var nameTD = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
                                			    this.createEl("span", null, "TD-AGE", nameTD, " ");
                                			    //var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', nameTD, person.age);
                                			    var spanTDo = this.createEl("span", null, "TD-AGE", nameTD, person.age);
                                			else{
                                			    // add a break
                                			    this.createEl("br", null , null , spanTDo, null);
                                			    //var nameTD = this.createEl("span", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'',spanTDo, person.name);
                                			    var nameTD = this.createEl("span", null, "TD-BODY", spanTDo, person.name);
                                			    //var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', spanTDo, person.age);
                                			    var spanTD = this.createEl("span", null, "TD-AGE", spanTDo, person.age);
                                			var spacerTR = this.createEl("tr", null, null , tBody, null);
                                			var spacerTD = this.createEl("td", null, "SPACER", spacerTR, " ");
                                  sdetweil @Perlchamp
                                  @Perlchamp ah well. both work here… your latest and mine produce the same results
                                  your output
                                  date	Name	age
                                  12	Sam 69
                                  2	Frank 81
                                  Sue81
                                  5	mary 65
                                  10	eee EEEEE 51
                                  16	fff FFFFF 8
                                  ggg GGGGG32
                                  27	hhh HHHHH 18
                                  my output
                                  date	Name	age
                                  12	Sam 69
                                  2	Frank 81
                                  Sue81
                                  5	mary 65
                                  10	eee EEEEE 51
                                  16	fff FFFFF 8
                                  ggg GGGGG32
                                  27	hhh HHHHH 18
                                  • PerlchampP
                                    Perlchamp
                                    what does that mean? but you don’t use css, do you ? YES, but didn’t you see, that i have annotate the
                                    lines in the code, i posted ? without entrie.isBefore … css is addressed, with it’s not addressed
                                      sdetweil @Perlchamp
                                      @Perlchamp I stepped thru and watched it change from with dimmed and without
                                      • PerlchampP
                                        Perlchamp
                                        sorry for nerving, sam. i would like to understand the code. where is the part in which the name and age of people with the same birthday are collected/combined ?
                                          sdetweil @Perlchamp
                                          @Perlchamp I’ll use you last code post
                                          // loop thru all the brithdays found in the file that match this month, one at a time
                                                              // each row is a person
        // create a row
        // get timne/date of now
                                          			let now = moment();
        // we need to change the style to dimmed,. if the BD is in the past
                                          			//let entrie = moment(birthday,"DD.MM");                      // < --- problem
        // assume the birthday is NOT in the past
                                          			let entrie = now
        // if the user requested dimming
        // get the brithdate in this year 01.05.2020
        // note the value WAS the SAME as 'now'
        // set the default value for the birthdate display
                                          			var bd = "";  // assume we don't need to display it
                                             			// if we have not seen this birthdate in the loop so far, its the fiist time
        // so we need the number of the day of the month
        // if it starts with 0, get from char 1 on sop 01.05 becomes 1.05, then
        // use split to get the parts [ 1, 05]
        // if not '0', use all bd numbers 12.05, and split to [12,05]
        // and take the 1st element of array
        // 1, or 12, for the two examples
        // now we need a row of data for the the person
        // class name is either TD-IMAGE or TD-IMAGE_DIMMED
        // use the two moments to compare (the fix for the entrie= now above will fix this)
        // if the persons ds is before now, and we want dimmed, then add the tail of the class name on
        // else use this the name (concat('') - add nothing))
        // this  entrie.isBefore(now)?'_DIMMED':'' means
        // the result of the expression is entrie before now
        // if true return '_DIMMED'
        // if false return ''
        // "TD-IMAGE".concat() this means add onto the string "TD-IMAGE" whatever is inside the concat() parens, either '_DIMMED' or ''
        // so the class will be TD-IMAGE (for people with bithrdays ON or AFTER today)
        // or TD-IMAGE_DIMMED for people with birthdays BEFORE today
                                          			    var nameTDo = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
                                          			    //var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', nameTDo, person.age);
                                          			    var spanTD = this.createEl("span", null, "TD-AGE", nameTD0, person.age);
                                          			else{
        // we HAVE seen the birthday before, the row is already created, so we need to add to the END THAT ROW, ie after the span of the previous person
                                          			    // add a break (to the end of the TD for the name (has span already for age)
                                          			    this.createEl("br", null , null , nameTDo, null);
                                          			    //var nameTD = this.createEl("span", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'',nameTDo, person.name);
        //  add a span for the persons name (after the line break
                                          			    var nameTD = this.createEl("span", null, "TD-BODY", nameTDo, person.name);
                                          			    // add a span with for spacing
                                          			    var spanTD = this.createEl("span", null, "TD-AGE", nameTDo, person.age);
        // if we have another person with the same BD, new stuff will be added after this span
        // regardless of 1st or second, we have seen this birthdaty
                                            @Perlchamp my code had
                                            					let now = moment()
                                            					let entrie=now
                                            					var bd = "";
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 15 / 16
