    read csv-data and put it in an array
    313 Posts 3 Posters 552.7k Views 4 Watching
    • PerlchampP Offline
      Perlchamp
      first i have to change my classes ? instead of TD-IMAGE TD-IMAGE_, ?
        sdetweil @Perlchamp
        @Perlchamp the classname is a string
        and the front part is the same
        so , you had duplicated code, just to change the classname…
        I just used your if(entrie) to decide it the name needed the’DIMMED" part added
        move the _ to the “DIMMED”, like this “_DIMMED”
        then they will be TD-IMAGE and TD-IMAGE_DIMMED , just like you had it…
        its the same row data and parentage, just a class change… (nice work having common names, so you could do this), got rid of that big else…
          Perlchamp
          css i don’t get to work. here’s my getDom:
          getDom: function() {
          	var wrapper = this.createEl("div",null,null,null,null);
          	// tell MM to call and get our content
          	Log.log(JSON.stringify(this.active_birthdays));
          	if ((moment() > this.midnight) || (!this.loaded)) {
          	    var month = moment().month();
          	    var year = moment().year();
          	    var monthName = moment().format("MMMM");
          	    var monthLength = moment().daysInMonth();
          	    var now = moment();
          	    if(Object.keys(this.active_birthdays).length > 0) {
          		// create table
          		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper,null)
          		// create tableheader here, array of column names
          		var table_header = this.createTableHeader(table, null, [" "," "]);
          		// create TBODY section with day names
          		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table, null);
          		var birthdays_seen= {}
          		var spacer = " ";
          		for(var birthday of Object.keys(this.active_birthdays)) {
          		    for(var person of this.active_birthdays[birthday]) {
          			// create looped row section
          			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY" , tBody, null);
          			let now = moment().format('DD.MM').valueOf();
          			let entrie=now;
          			if(this.config.dimmEntries) {
          			    entrie = moment(birthday,'DD.MM').valueOf();
          			// delete leading 0 and month
          			var bd = "";
          			if(birthdays_seen[birthday] == undefined) {
          			    bd = (birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
          			    var imageTD = this.createEl('td', null, "TD-IMAGE" + (entrie < now)?"_DIMMED":'' , bodyTR, bd);
          			    var nameTD = this.createEl('td', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' , bodyTR, person.name);
          			    this.createEl("span", null, null, nameTD, " ");
          			    // needs class for width
          			    var spanTDo = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', nameTD, person.age);
          			else{
          			    // add a break
          			    this.createEl('br', null , null , spanTDo,null);
          			    // add a span with name
          			    var nameTD = this.createEl('span', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' ,spanTDo, person.name);
          			    // add a span with age
          			    var spanTD = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', spanTDo, person.age);
          			var spacerTR = this.createEl('tr', null, null , tBody, null);
          			var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, " ");
          			spacerTD.colSpan = "2";
          			birthdays_seen[birthday] = true;
          		// Create TFOOT section -- currently used for debugging only
          		if (this.config.debugging) {
          		    var table_footer = this.createTableFooter(tBody, null, [" "," "]);
          		    //footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
          		else {
          	    // pass the created content back to MM to add to DOM.
          	    return wrapper;
          	// Dom is loaded
          	this.loaded = true;
          there should be an error i don’t see.
            sdetweil @Perlchamp
            @Perlchamp use the debugger, expand the elements tree, find the table and look at the classes assigned
              Perlchamp
              hi sam,
              if i do this:
                 var imageTD = this.createEl("td", null, "TD-IMAGE", bodyTR, bd);
              instead of this :
              var imageTD = this.createEl("td", null, "TD-IMAGE" + (entrie < now)?"_DIMMED":'' , bodyTR, bd);
              css are addressed. maybe something has to change in the createEl function ?
                sdetweil @Perlchamp
                @Perlchamp let me look…
                  sdetweil @Perlchamp
                  @Perlchamp
                  warning one ( was missing, fixed
                  SORRY… tested now… the + append didn’t work, had to force with concat()…
                  Its the two values, now and entrie
                  				let now = moment().format('DD.MM').valueOf();				 // this is string dd.mm
                  				let entrie=now
                  					entrie = moment(birthday,'DD.MM').format.valueOf();     // this is a moment
                  so later when compared, it doesn;t work
                  and comparing strings with < doesn’t really work…
                  I would do
                  let now=moment()
                  let entrie = moment(birthday,‘DD.MM’)
                  then in the compare
                  (entrie.isBefore(now))?..
                  	getDom: function(){
                  		var wrapper = this.createEl("div",null,null,null);
                  		if(Object.keys(this.active_birthdays).length>0){
                  			// create your table  here
                  			var table = this.createEl("table", "birthday-table", null, wrapper );
                  			// table header here, array of column names
                  			var table_header=this.createTableHeader(table,null, ["date","Name","age"])
                  			var tBody = this.createEl('tbody', "birthday-t-body", "tbody", table, null);
                  					var bodyTR = this.createEl('tr', null, "TR-BODY" ,tBody, null);
                  					let now = moment()
                  					let entrie=now
                  					var bd = "";
                  			    	if(birthdays_seen[birthday]==undefined){
                  						bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
                  						var imageTD = this.createEl('td', null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, bd);
                  						var nameTD = this.createEl('td', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, person.name);
                  									 this.createEl("span", null, null, nameTD, " ");						// needs class for width
                  						var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), nameTD, person.age);
                  					else{
                  						// add a break
                  						var nameTD = this.createEl('span', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') ,spanTDo, person.name);
                  						var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), spanTDo, person.age);
                  		return wrapper;
                    @Perlchamp see my update above
                      Perlchamp
                      @sdetweil said in read csv-data and put it in an array:
                      sorry, doesn’t work. blackscreen. if i change back (my post) css is addressed. i didn’t change the jet = part. i think, something’s wrong with the cerateEl function, but you know i’m not an expert.but to control. here is my code :
                      			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY", tBody, null);
                      			let now = moment();
                      			let entrie = moment(birthday,"DD.MM");
                      			    entrie = moment(birthday,'DD.MM');
                      			var bd = "";
                      			    //var imageTD = this.createEl('td', null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, bd);
                      			    //var nameTD = this.createEl("td", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, person.name);
                      			    var nameTD = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
                      			    this.createEl("span", null, "TD-AGE", nameTD, " ");
                      			    //var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', nameTD, person.age);
                      			    var spanTDo = this.createEl("span", null, "TD-AGE", nameTD, person.age);
                      			else{
                      			    // add a break
                      			    this.createEl("br", null , null , spanTDo, null);
                      			    //var nameTD = this.createEl("span", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'',spanTDo, person.name);
                      			    var nameTD = this.createEl("span", null, "TD-BODY", spanTDo, person.name);
                      			    //var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', spanTDo, person.age);
                      			    var spanTD = this.createEl("span", null, "TD-AGE", spanTDo, person.age);
                      			var spacerTR = this.createEl("tr", null, null , tBody, null);
                      			var spacerTD = this.createEl("td", null, "SPACER", spacerTR, " ");
                        sdetweil @Perlchamp
                        @Perlchamp ah well. both work here… your latest and mine produce the same results
                        your output
                        date	Name	age
                        12	Sam 69
                        2	Frank 81
                        Sue81
                        5	mary 65
                        10	eee EEEEE 51
                        16	fff FFFFF 8
                        ggg GGGGG32
                        27	hhh HHHHH 18
                        my output
                        date	Name	age
                        12	Sam 69
                        2	Frank 81
                        Sue81
                        5	mary 65
                        10	eee EEEEE 51
                        16	fff FFFFF 8
                        ggg GGGGG32
                        27	hhh HHHHH 18
                          Perlchamp
                          what does that mean? but you don’t use css, do you ? YES, but didn’t you see, that i have annotate the
                          lines in the code, i posted ? without entrie.isBefore … css is addressed, with it’s not addressed
                            sdetweil @Perlchamp
                            @Perlchamp I stepped thru and watched it change from with dimmed and without
                              Perlchamp
                              sorry for nerving, sam. i would like to understand the code. where is the part in which the name and age of people with the same birthday are collected/combined ?
                                sdetweil @Perlchamp
                                @Perlchamp I’ll use you last code post
                                // loop thru all the brithdays found in the file that match this month, one at a time
                                                    // each row is a person
                                                        // create a row
                                                        // get timne/date of now
                                			let now = moment();
                                                        // we need to change the style to dimmed,. if the BD is in the past
                                			//let entrie = moment(birthday,"DD.MM");                      // < --- problem
                                                        // assume the birthday is NOT in the past
                                			let entrie = now
                                                        // if the user requested dimming
                                                            // get the brithdate in this year 01.05.2020
                                                            // note the value WAS the SAME as 'now'
                                                        // set the default value for the birthdate display
                                			var bd = "";  // assume we don't need to display it
                                   			// if we have not seen this birthdate in the loop so far, its the fiist time
                                                            // so we need the number of the day of the month
                                                           // if it starts with 0, get from char 1 on sop 01.05 becomes 1.05, then
                                                           // use split to get the parts [ 1, 05]
                                                           // if not '0', use all bd numbers 12.05, and split to [12,05]
                                                           // and take the 1st element of array
                                                           // 1, or 12, for the two examples
                                                            // now we need a row of data for the the person
                                                            // class name is either TD-IMAGE or TD-IMAGE_DIMMED
                                                            // use the two moments to compare (the fix for the entrie= now above will fix this)
                                                            // if the persons ds is before now, and we want dimmed, then add the tail of the class name on
                                                            // else use this the name (concat('') - add nothing))
                                                            // this  entrie.isBefore(now)?'_DIMMED':'' means
                                                            // the result of the expression is entrie before now
                                                            // if true return '_DIMMED'
                                                            // if false return ''
                                                            // "TD-IMAGE".concat() this means add onto the string "TD-IMAGE" whatever is inside the concat() parens, either '_DIMMED' or ''
                                                            // so the class will be TD-IMAGE (for people with bithrdays ON or AFTER today)
                                                            // or TD-IMAGE_DIMMED for people with birthdays BEFORE today
                                			    var nameTDo = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
                                			    //var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', nameTDo, person.age);
                                			    var spanTD = this.createEl("span", null, "TD-AGE", nameTD0, person.age);
                                			else{
                                                             // we HAVE seen the birthday before, the row is already created, so we need to add to the END THAT ROW, ie after the span of the previous person
                                			    // add a break (to the end of the TD for the name (has span already for age)
                                			    this.createEl("br", null , null , nameTDo, null);
                                			    //var nameTD = this.createEl("span", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'',nameTDo, person.name);
                                                            //  add a span for the persons name (after the line break
                                			    var nameTD = this.createEl("span", null, "TD-BODY", nameTDo, person.name);
                                			    // add a span with for spacing
                                			    var spanTD = this.createEl("span", null, "TD-AGE", nameTDo, person.age);
                                                            // if we have another person with the same BD, new stuff will be added after this span
                                                        // regardless of 1st or second, we have seen this birthdaty
                                  @Perlchamp my code had
                                  					let now = moment()
                                  					let entrie=now
                                  					var bd = "";
                                    Perlchamp
                                    thanks a lot. i will study this …
                                      sdetweil @Perlchamp
                                      @Perlchamp make that one fix and then my code will work too
                                        Perlchamp
                                        update !
                                        i tried, but how should i do this ?
                                        i was in the dev. didn’t helped me. it’s , how said, the part
                                        with => blackScreen
                                        without => working (formatted => css).
                                          sdetweil @Perlchamp
                                          @Perlchamp have to edit the source code, then reload the browser page, cannot edit in debugger
                                          let now = moment()
                                          					let entrie=now   // <-- this line was not included in yours..   i commented
                                            Perlchamp
                                            this code => blackScreen:
                                            	var wrapper = this.createEl("div", null, null, null, null);
                                            	    var now = moment();
                                            		var table = this.createEl("table", "birthday-table", "TABLE", wrapper, null);
                                            		var table_header = this.createTableHeader(table, "THEAD", [" "," "]);
                                            		//var table_header = this.createTableHeader(table, null, [" "," "," "]);
                                            		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY", table, null);
                                            		var birthdays_seen = {};
                                            		var spacer = " ";
                                            			var bodyTR = this.createEl("tr", "birthday-tr-body", "TR-BODY", tBody, null);
                                            			let now = moment();
                                            			var bd = "";
                                            			    bd = (birthday.startsWith("0")? birthday.substring(1): birthday).split(".")[0];
                                            			    var imageTD = this.createEl("td", null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, bd);
                                            			    //var imageTD = this.createEl("td", null, "TD-IMAGE", bodyTR, bd);
                                            			    //var nameTD = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
                                            			    //var spanTDo = this.createEl("span", null, "TD-AGE", nameTD, person.age);
                                            			else{
                                            			    // add a break
                                            			    //var nameTD = this.createEl("span", null, "TD-BODY", spanTDo, person.name);
                                            			    //var spanTD = this.createEl("span", null, "TD-AGE", spanTDo, person.age);
                                            		else {
                                            	    return wrapper;
                                            	// Dom is loaded
                                            	this.loaded = true;
                                            this code works but no css:
                                            	    var now = moment();
                                            		// create table
                                            		var spacer = " ";
                                            			let entrie=now;
                                            			var bd = "";
                                            			else{
                                            			    // add a break
                                            		else {
                                            	    return wrapper;
                                            	// Dom is loaded
                                            	this.loaded = true;
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 15 / 16
