    read csv-data and put it in an array
    313 Posts 3 Posters 590.1k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp use the debugger, expand the elements tree, find the table and look at the classes assigned
      • PerlchampP
        Perlchamp
        hi sam,
        if i do this:
           var imageTD = this.createEl("td", null, "TD-IMAGE", bodyTR, bd);
        instead of this :
        var imageTD = this.createEl("td", null, "TD-IMAGE" + (entrie < now)?"_DIMMED":'' , bodyTR, bd);
        css are addressed. maybe something has to change in the createEl function ?
        S 2 Replies Last reply
          sdetweil @Perlchamp
          @Perlchamp let me look…
            sdetweil @Perlchamp
            @Perlchamp
            warning one ( was missing, fixed
            SORRY… tested now… the + append didn’t work, had to force with concat()…
            Its the two values, now and entrie
            				let now = moment().format('DD.MM').valueOf();				 // this is string dd.mm
            				let entrie=now
            			    if(this.config.dimmEntries) {
            					entrie = moment(birthday,'DD.MM').format.valueOf();     // this is a moment
            so later when compared, it doesn;t work
            and comparing strings with < doesn’t really work…
            I would do
            let now=moment()
            let entrie = moment(birthday,‘DD.MM’)
            then in the compare
            (entrie.isBefore(now))?..
            	getDom: function(){
            		var wrapper = this.createEl("div",null,null,null);
            		if(Object.keys(this.active_birthdays).length>0){
            			// create your table  here
            			var table = this.createEl("table", "birthday-table", null, wrapper );
            			// table header here, array of column names
            			var table_header=this.createTableHeader(table,null, ["date","Name","age"])
            			// create looped row section
            			var tBody = this.createEl('tbody', "birthday-t-body", "tbody", table, null);
            			var birthdays_seen= {}
            			for(var birthday of Object.keys(this.active_birthdays)) {
            			    for(var person of this.active_birthdays[birthday]) {
            					var bodyTR = this.createEl('tr', null, "TR-BODY" ,tBody, null);
            					let now = moment()
            					let entrie=now
            					var bd = "";
            			    	if(birthdays_seen[birthday]==undefined){
            						bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
            						var imageTD = this.createEl('td', null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, bd);
            						var nameTD = this.createEl('td', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, person.name);
            									 this.createEl("span", null, null, nameTD, " ");						// needs class for width
            						var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), nameTD, person.age);
            					else{
            						// add a break
            						this.createEl('br', null , null , spanTDo,null);
            						// add a span with name
            						var nameTD = this.createEl('span', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') ,spanTDo, person.name);
            						// add a span with age
            						var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), spanTDo, person.age);
            					var spacerTR = this.createEl('tr', null, null , tBody, null);
            					var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, " ");
            					spacerTD.colSpan = "2";
            					birthdays_seen[birthday] = true;
            		return wrapper;
              @Perlchamp see my update above
              • PerlchampP
                Perlchamp
                @sdetweil said in read csv-data and put it in an array:
                sorry, doesn’t work. blackscreen. if i change back (my post) css is addressed. i didn’t change the jet = part. i think, something’s wrong with the cerateEl function, but you know i’m not an expert.but to control. here is my code :
                			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY", tBody, null);
                			let now = moment();
                			let entrie = moment(birthday,"DD.MM");
                			    entrie = moment(birthday,'DD.MM');
                			// delete leading 0 and month
                			var bd = "";
                			if(birthdays_seen[birthday] == undefined) {
                			    bd = (birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
                			    //var imageTD = this.createEl('td', null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, bd);
                			    //var nameTD = this.createEl("td", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, person.name);
                			    var nameTD = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
                			    this.createEl("span", null, "TD-AGE", nameTD, " ");
                			    //var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', nameTD, person.age);
                			    var spanTDo = this.createEl("span", null, "TD-AGE", nameTD, person.age);
                			else{
                			    // add a break
                			    this.createEl("br", null , null , spanTDo, null);
                			    //var nameTD = this.createEl("span", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'',spanTDo, person.name);
                			    var nameTD = this.createEl("span", null, "TD-BODY", spanTDo, person.name);
                			    //var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', spanTDo, person.age);
                			    var spanTD = this.createEl("span", null, "TD-AGE", spanTDo, person.age);
                			var spacerTR = this.createEl("tr", null, null , tBody, null);
                			var spacerTD = this.createEl("td", null, "SPACER", spacerTR, " ");
                  sdetweil @Perlchamp
                  @Perlchamp ah well. both work here… your latest and mine produce the same results
                  your output
                  date	Name	age
                  12	Sam 69
                  2	Frank 81
                  Sue81
                  5	mary 65
                  10	eee EEEEE 51
                  16	fff FFFFF 8
                  ggg GGGGG32
                  27	hhh HHHHH 18
                  my output
                  date	Name	age
                  12	Sam 69
                  2	Frank 81
                  Sue81
                  5	mary 65
                  10	eee EEEEE 51
                  16	fff FFFFF 8
                  ggg GGGGG32
                  27	hhh HHHHH 18
                  • PerlchampP
                    Perlchamp
                    what does that mean? but you don’t use css, do you ? YES, but didn’t you see, that i have annotate the
                    lines in the code, i posted ? without entrie.isBefore … css is addressed, with it’s not addressed
                      sdetweil @Perlchamp
                      @Perlchamp I stepped thru and watched it change from with dimmed and without
                      • PerlchampP
                        Perlchamp
                        sorry for nerving, sam. i would like to understand the code. where is the part in which the name and age of people with the same birthday are collected/combined ?
                          sdetweil @Perlchamp
                          @Perlchamp I’ll use you last code post
                          // loop thru all the brithdays found in the file that match this month, one at a time
                                              // each row is a person
                                                  // create a row
                                                  // get timne/date of now
                          			let now = moment();
                                                  // we need to change the style to dimmed,. if the BD is in the past
                          			//let entrie = moment(birthday,"DD.MM");                      // < --- problem
                                                  // assume the birthday is NOT in the past
                          			let entrie = now
                                                  // if the user requested dimming
                                                      // get the brithdate in this year 01.05.2020
                                                      // note the value WAS the SAME as 'now'
                                                  // set the default value for the birthdate display
                          			var bd = "";  // assume we don't need to display it
                             			// if we have not seen this birthdate in the loop so far, its the fiist time
                                                      // so we need the number of the day of the month
                                                     // if it starts with 0, get from char 1 on sop 01.05 becomes 1.05, then
                                                     // use split to get the parts [ 1, 05]
                                                     // if not '0', use all bd numbers 12.05, and split to [12,05]
                                                     // and take the 1st element of array
                                                     // 1, or 12, for the two examples
                                                      // now we need a row of data for the the person
                                                      // class name is either TD-IMAGE or TD-IMAGE_DIMMED
                                                      // use the two moments to compare (the fix for the entrie= now above will fix this)
                                                      // if the persons ds is before now, and we want dimmed, then add the tail of the class name on
                                                      // else use this the name (concat('') - add nothing))
                                                      // this  entrie.isBefore(now)?'_DIMMED':'' means
                                                      // the result of the expression is entrie before now
                                                      // if true return '_DIMMED'
                                                      // if false return ''
                                                      // "TD-IMAGE".concat() this means add onto the string "TD-IMAGE" whatever is inside the concat() parens, either '_DIMMED' or ''
                                                      // so the class will be TD-IMAGE (for people with bithrdays ON or AFTER today)
                                                      // or TD-IMAGE_DIMMED for people with birthdays BEFORE today
                          			    var nameTDo = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
                          			    //var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', nameTDo, person.age);
                          			    var spanTD = this.createEl("span", null, "TD-AGE", nameTD0, person.age);
                          			else{
                                                       // we HAVE seen the birthday before, the row is already created, so we need to add to the END THAT ROW, ie after the span of the previous person
                          			    // add a break (to the end of the TD for the name (has span already for age)
                          			    this.createEl("br", null , null , nameTDo, null);
                          			    //var nameTD = this.createEl("span", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'',nameTDo, person.name);
                                                      //  add a span for the persons name (after the line break
                          			    var nameTD = this.createEl("span", null, "TD-BODY", nameTDo, person.name);
                          			    // add a span with for spacing
                          			    var spanTD = this.createEl("span", null, "TD-AGE", nameTDo, person.age);
                                                      // if we have another person with the same BD, new stuff will be added after this span
                                                  // regardless of 1st or second, we have seen this birthdaty
                            @Perlchamp my code had
                            					let now = moment()
                            					let entrie=now
                            					var bd = "";
                            • PerlchampP
                              Perlchamp
                              thanks a lot. i will study this …
                                sdetweil @Perlchamp
                                @Perlchamp make that one fix and then my code will work too
                                • PerlchampP
                                  Perlchamp
                                  update !
                                  i tried, but how should i do this ?
                                  i was in the dev. didn’t helped me. it’s , how said, the part
                                  with => blackScreen
                                  without => working (formatted => css).
                                    sdetweil @Perlchamp
                                    @Perlchamp have to edit the source code, then reload the browser page, cannot edit in debugger
                                    let now = moment()
                                    					let entrie=now   // <-- this line was not included in yours..   i commented
                                    • PerlchampP
                                      Perlchamp
                                      this code => blackScreen:
                                          getDom: function() {
                                      	var wrapper = this.createEl("div", null, null, null, null);
                                      	// tell MM to call and get our content
                                      	Log.log(JSON.stringify(this.active_birthdays));
                                      	if ((moment() > this.midnight) || (!this.loaded)) {
                                      	    var month = moment().month();
                                      	    var year = moment().year();
                                      	    var monthName = moment().format("MMMM");
                                      	    var monthLength = moment().daysInMonth();
                                      	    var now = moment();
                                      	    if(Object.keys(this.active_birthdays).length > 0) {
                                      		var table = this.createEl("table", "birthday-table", "TABLE", wrapper, null);
                                      		// create tableheader here, array of column names
                                      		var table_header = this.createTableHeader(table, "THEAD", [" "," "]);
                                      		//var table_header = this.createTableHeader(table, null, [" "," "," "]);
                                      		// create TBODY section with day names
                                      		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY", table, null);
                                      		var birthdays_seen = {};
                                      		var spacer = " ";
                                      			var bodyTR = this.createEl("tr", "birthday-tr-body", "TR-BODY", tBody, null);
                                      			let now = moment();
                                      			var bd = "";
                                      			    bd = (birthday.startsWith("0")? birthday.substring(1): birthday).split(".")[0];
                                      			    var imageTD = this.createEl("td", null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, bd);
                                      			    //var imageTD = this.createEl("td", null, "TD-IMAGE", bodyTR, bd);
                                      			    //var nameTD = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
                                      			    //var spanTDo = this.createEl("span", null, "TD-AGE", nameTD, person.age);
                                      			else{
                                      			    // add a break
                                      			    //var nameTD = this.createEl("span", null, "TD-BODY", spanTDo, person.name);
                                      			    //var spanTD = this.createEl("span", null, "TD-AGE", spanTDo, person.age);
                                      		// Create TFOOT section -- currently used for debugging only
                                      		if (this.config.debugging) {
                                      		    var table_footer = this.createTableFooter(tBody, null, [" "," "]);
                                      		    //footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
                                      		else {
                                      	    // pass the created content back to MM to add to DOM.
                                      	    return wrapper;
                                      	// Dom is loaded
                                      	this.loaded = true;
                                      this code works but no css:
                                      	var wrapper = this.createEl("div",null,null,null,null);
                                      	    var now = moment();
                                      		// create table
                                      		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper,null)
                                      		var table_header = this.createTableHeader(table, null, [" "," "]);
                                      		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table, null);
                                      		var spacer = " ";
                                      			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY" , tBody, null);
                                      			let entrie=now;
                                      			    entrie = moment(birthday,'DD.MM').valueOf();
                                      			var bd = "";
                                      			    var imageTD = this.createEl('td', null, "TD-IMAGE" + (entrie < now)?"_DIMMED":'' , bodyTR, bd);
                                      			    var nameTD = this.createEl('td', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' , bodyTR, person.name);
                                      			    var spanTDo = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', nameTD, person.age);
                                      			else{
                                      			    // add a break
                                      			    var nameTD = this.createEl('span', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' ,spanTDo, person.name);
                                      			    var spanTD = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', spanTDo, person.age);
                                      		else {
                                      	    return wrapper;
                                      	// Dom is loaded
                                      	this.loaded = true;
                                        sdetweil @Perlchamp
                                        @Perlchamp you need to learn the debugger, code fixed
                                        	getDom: function(){
                                        					let now = moment()
                                        					let entrie=now
                                        					var bd = "";
                                        					else{
                                        						// add a break
                                        		return wrapper;
                                        see the last line of the console
                                        black screen means syntax error in some modulename.js, click on the line number and it will take you to that line in the code … note the concat(… is missing its right paren ‘)’
                                        • PerlchampP
                                          Perlchamp
                                          thank you very much. yes i need more expirience of debugging. it’s my second day i use it, sorry sam. AND MANY THANKS.
                                            sdetweil @Perlchamp
                                            @Perlchamp Make an error, take out a comma, or ’
                                            reload the page, f5
                                            put part of ht module name in the filter field of the console
                                            find the error message
                                            click the filename/line to the right
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 15 / 16
