    read csv-data and put it in an array
    313 Posts 3 Posters 552.7k Views 4 Watching
    • PerlchampP Offline
      Perlchamp
      what does that mean? but you don’t use css, do you ? YES, but didn’t you see, that i have annotate the
      .concat(entrie.isBefore(now)?"_DIMMED":''
      lines in the code, i posted ? without entrie.isBefore … css is addressed, with it’s not addressed
        sdetweil @Perlchamp
        @Perlchamp I stepped thru and watched it change from with dimmed and without
          Perlchamp
          sorry for nerving, sam. i would like to understand the code. where is the part in which the name and age of people with the same birthday are collected/combined ?
            sdetweil @Perlchamp
            @Perlchamp I’ll use you last code post
            // loop thru all the brithdays found in the file that match this month, one at a time
            for(var birthday of Object.keys(this.active_birthdays)) {
                                // each row is a person
            		    for(var person of this.active_birthdays[birthday]) {
            			// create looped row section
                                    // create a row
            			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY", tBody, null);
                                    // get timne/date of now
            			let now = moment();
                                    // we need to change the style to dimmed,. if the BD is in the past
            			//let entrie = moment(birthday,"DD.MM");                      // < --- problem
                                    // assume the birthday is NOT in the past
            			let entrie = now
                                    // if the user requested dimming
            			if(this.config.dimmEntries) {
                                        // get the brithdate in this year 01.05.2020
                                        // note the value WAS the SAME as 'now'
            			    entrie = moment(birthday,'DD.MM');
                                    // set the default value for the birthdate display
            			var bd = "";  // assume we don't need to display it
               			// if we have not seen this birthdate in the loop so far, its the fiist time
            			if(birthdays_seen[birthday] == undefined) {
                                        // so we need the number of the day of the month
                                       // if it starts with 0, get from char 1 on sop 01.05 becomes 1.05, then
                                       // use split to get the parts [ 1, 05]
                                       // if not '0', use all bd numbers 12.05, and split to [12,05]
                                       // and take the 1st element of array
                                       // 1, or 12, for the two examples
            			    bd = (birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
                                        // now we need a row of data for the the person
                                        // class name is either TD-IMAGE or TD-IMAGE_DIMMED
                                        // use the two moments to compare (the fix for the entrie= now above will fix this)
                                        // if the persons ds is before now, and we want dimmed, then add the tail of the class name on
                                        // else use this the name (concat('') - add nothing))
                                        // this  entrie.isBefore(now)?'_DIMMED':'' means
                                        // the result of the expression is entrie before now
                                        // if true return '_DIMMED'
                                        // if false return ''
                                        // "TD-IMAGE".concat() this means add onto the string "TD-IMAGE" whatever is inside the concat() parens, either '_DIMMED' or ''
                                        // so the class will be TD-IMAGE (for people with bithrdays ON or AFTER today)
                                        // or TD-IMAGE_DIMMED for people with birthdays BEFORE today
            			    //var imageTD = this.createEl('td', null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, bd);
            			    var imageTD = this.createEl("td", null, "TD-IMAGE", bodyTR, bd);
            			    //var nameTD = this.createEl("td", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, person.name);
            			    var nameTDo = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
            			    this.createEl("span", null, "TD-AGE", nameTD, " ");
            			    // needs class for width
            			    //var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', nameTDo, person.age);
            			    var spanTD = this.createEl("span", null, "TD-AGE", nameTD0, person.age);
            			else{
                                         // we HAVE seen the birthday before, the row is already created, so we need to add to the END THAT ROW, ie after the span of the previous person
            			    // add a break (to the end of the TD for the name (has span already for age)
            			    this.createEl("br", null , null , nameTDo, null);
            			    // add a span with name
            			    //var nameTD = this.createEl("span", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'',nameTDo, person.name);
                                        //  add a span for the persons name (after the line break
            			    var nameTD = this.createEl("span", null, "TD-BODY", nameTDo, person.name);
            			    // add a span with for spacing
                                        // add a span with age
            			    var spanTD = this.createEl("span", null, "TD-AGE", nameTDo, person.age);
                                        // if we have another person with the same BD, new stuff will be added after this span
            			var spacerTR = this.createEl("tr", null, null , tBody, null);
            			var spacerTD = this.createEl("td", null, "SPACER", spacerTR, " ");
            			spacerTD.colSpan = "2";
                                    // regardless of 1st or second, we have seen this birthdaty
            			birthdays_seen[birthday] = true;
              @Perlchamp my code had
              					let now = moment()
              					let entrie=now
              					var bd = "";
                Perlchamp
                thanks a lot. i will study this …
                  sdetweil @Perlchamp
                  @Perlchamp make that one fix and then my code will work too
                    Perlchamp
                    update !
                    i tried, but how should i do this ?
                    i was in the dev. didn’t helped me. it’s , how said, the part
                    with => blackScreen
                    without => working (formatted => css).
                      sdetweil @Perlchamp
                      @Perlchamp have to edit the source code, then reload the browser page, cannot edit in debugger
                      let now = moment()
                      					let entrie=now   // <-- this line was not included in yours..   i commented
                        Perlchamp
                        this code => blackScreen:
                            getDom: function() {
                        	var wrapper = this.createEl("div", null, null, null, null);
                        	// tell MM to call and get our content
                        	Log.log(JSON.stringify(this.active_birthdays));
                        	if ((moment() > this.midnight) || (!this.loaded)) {
                        	    var month = moment().month();
                        	    var year = moment().year();
                        	    var monthName = moment().format("MMMM");
                        	    var monthLength = moment().daysInMonth();
                        	    var now = moment();
                        	    if(Object.keys(this.active_birthdays).length > 0) {
                        		// create your table here
                        		var table = this.createEl("table", "birthday-table", "TABLE", wrapper, null);
                        		// create tableheader here, array of column names
                        		var table_header = this.createTableHeader(table, "THEAD", [" "," "]);
                        		//var table_header = this.createTableHeader(table, null, [" "," "," "]);
                        		// create TBODY section with day names
                        		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY", table, null);
                        		var birthdays_seen = {};
                        		var spacer = " ";
                        			var bodyTR = this.createEl("tr", "birthday-tr-body", "TR-BODY", tBody, null);
                        			let now = moment();
                        			// delete leading 0 and month
                        			var bd = "";
                        			    bd = (birthday.startsWith("0")? birthday.substring(1): birthday).split(".")[0];
                        			    var imageTD = this.createEl("td", null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, bd);
                        			    //var imageTD = this.createEl("td", null, "TD-IMAGE", bodyTR, bd);
                        			    //var nameTD = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
                        			    var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', nameTD, person.age);
                        			    //var spanTDo = this.createEl("span", null, "TD-AGE", nameTD, person.age);
                        			else{
                        			    // add a break
                        			    this.createEl("br", null , null , spanTDo, null);
                        			    var nameTD = this.createEl("span", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'',spanTDo, person.name);
                        			    //var nameTD = this.createEl("span", null, "TD-BODY", spanTDo, person.name);
                        			    var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', spanTDo, person.age);
                        			    //var spanTD = this.createEl("span", null, "TD-AGE", spanTDo, person.age);
                        		// Create TFOOT section -- currently used for debugging only
                        		if (this.config.debugging) {
                        		    var table_footer = this.createTableFooter(tBody, null, [" "," "]);
                        		    //footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
                        		else {
                        	    // pass the created content back to MM to add to DOM.
                        	    return wrapper;
                        	// Dom is loaded
                        	this.loaded = true;
                        this code works but no css:
                        	var wrapper = this.createEl("div",null,null,null,null);
                        	    var now = moment();
                        		// create table
                        		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper,null)
                        		var table_header = this.createTableHeader(table, null, [" "," "]);
                        		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table, null);
                        		var birthdays_seen= {}
                        		var spacer = " ";
                        			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY" , tBody, null);
                        			let now = moment().format('DD.MM').valueOf();
                        			let entrie=now;
                        			    entrie = moment(birthday,'DD.MM').valueOf();
                        			var bd = "";
                        			    var imageTD = this.createEl('td', null, "TD-IMAGE" + (entrie < now)?"_DIMMED":'' , bodyTR, bd);
                        			    var nameTD = this.createEl('td', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' , bodyTR, person.name);
                        			    this.createEl("span", null, null, nameTD, " ");
                        			    var spanTDo = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', nameTD, person.age);
                        			else{
                        			    // add a break
                        			    this.createEl('br', null , null , spanTDo,null);
                        			    var nameTD = this.createEl('span', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' ,spanTDo, person.name);
                        			    var spanTD = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', spanTDo, person.age);
                        			var spacerTR = this.createEl('tr', null, null , tBody, null);
                        			var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, " ");
                        		else {
                        	    return wrapper;
                        	// Dom is loaded
                        	this.loaded = true;
                          sdetweil @Perlchamp
                          @Perlchamp you need to learn the debugger, code fixed
                          	getDom: function(){
                          		var wrapper = this.createEl("div",null,null,null);
                          		if(Object.keys(this.active_birthdays).length>0){
                          			var table = this.createEl("table", "birthday-table", null, wrapper );
                          			// table header here, array of column names
                          			var table_header=this.createTableHeader(table,null, ["date","Name","age"])
                          			var tBody = this.createEl('tbody', "birthday-t-body", "tbody", table, null);
                          					var bodyTR = this.createEl('tr', null, "TR-BODY" ,tBody, null);
                          					let now = moment()
                          					let entrie=now
                          					var bd = "";
                          			    	if(birthdays_seen[birthday]==undefined){
                          						bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
                          						var imageTD = this.createEl('td', null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, bd);
                          						var nameTD = this.createEl('td', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, person.name);
                          									 this.createEl("span", null, null, nameTD, " ");						// needs class for width
                          						var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), nameTD, person.age);
                          					else{
                          						// add a break
                          						var nameTD = this.createEl('span', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') ,spanTDo, person.name);
                          						var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), spanTDo, person.age);
                          		return wrapper;
                          see the last line of the console
                          black screen means syntax error in some modulename.js, click on the line number and it will take you to that line in the code … note the concat(… is missing its right paren ‘)’
                            Perlchamp
                            thank you very much. yes i need more expirience of debugging. it’s my second day i use it, sorry sam. AND MANY THANKS.
                              sdetweil @Perlchamp
                              @Perlchamp Make an error, take out a comma, or ’
                              reload the page, f5
                              put part of ht module name in the filter field of the console
                              find the error message
                              click the filename/line to the right
                                Perlchamp
                                ok, will collect some experience …
                                  Perlchamp
                                  ok, the blacksreen is gone, works, but no css
                                    sdetweil @Perlchamp
                                    @Perlchamp that comes up for me
                                    Copied directly. Will send my module file.
                                      Perlchamp
                                      ok, thanks
                                        sdetweil @Perlchamp
                                        @Perlchamp see the expanded html on left
                                        file sent
                                          Perlchamp
                                          it WORKS ! now i hope to find the error :-)
                                            sdetweil @Perlchamp
                                            @Perlchamp i did not use the classes , no… didn’t care about the layout etc…
                                            I want to make sure the NAMES of the classes are right…
                                            sending file again, sorting the dates
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 16 / 16
