    read csv-data and put it in an array
    313 Posts 3 Posters 590.1k Views 4 Watching
    • PerlchampP
      Perlchamp
      thanks a lot. i will study this …
        sdetweil @Perlchamp
        @Perlchamp make that one fix and then my code will work too
        • PerlchampP
          Perlchamp
          update !
          i tried, but how should i do this ?
          i was in the dev. didn’t helped me. it’s , how said, the part
          .concat(entrie.isBefore(now)?"_DIMMED":''
          with => blackScreen
          without => working (formatted => css).
            sdetweil @Perlchamp
            @Perlchamp have to edit the source code, then reload the browser page, cannot edit in debugger
            let now = moment()
            					let entrie=now   // <-- this line was not included in yours..   i commented
            				    if(this.config.dimmEntries) {
            						entrie = moment(birthday,'DD.MM')
            • PerlchampP
              Perlchamp
              this code => blackScreen:
                  getDom: function() {
              	var wrapper = this.createEl("div", null, null, null, null);
              	// tell MM to call and get our content
              	Log.log(JSON.stringify(this.active_birthdays));
              	if ((moment() > this.midnight) || (!this.loaded)) {
              	    var month = moment().month();
              	    var year = moment().year();
              	    var monthName = moment().format("MMMM");
              	    var monthLength = moment().daysInMonth();
              	    var now = moment();
              	    if(Object.keys(this.active_birthdays).length > 0) {
              		// create your table here
              		var table = this.createEl("table", "birthday-table", "TABLE", wrapper, null);
              		// create tableheader here, array of column names
              		var table_header = this.createTableHeader(table, "THEAD", [" "," "]);
              		//var table_header = this.createTableHeader(table, null, [" "," "," "]);
              		// create TBODY section with day names
              		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY", table, null);
              		var birthdays_seen = {};
              		var spacer = " ";
              		for(var birthday of Object.keys(this.active_birthdays)) {
              		    for(var person of this.active_birthdays[birthday]) {
              			// create looped row section
              			var bodyTR = this.createEl("tr", "birthday-tr-body", "TR-BODY", tBody, null);
              			let now = moment();
              			let entrie = moment(birthday,"DD.MM");
              			// delete leading 0 and month
              			var bd = "";
              			if(birthdays_seen[birthday] == undefined) {
              			    bd = (birthday.startsWith("0")? birthday.substring(1): birthday).split(".")[0];
              			    var imageTD = this.createEl("td", null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, bd);
              			    //var imageTD = this.createEl("td", null, "TD-IMAGE", bodyTR, bd);
              			    var nameTD = this.createEl("td", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, person.name);
              			    //var nameTD = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
              			    this.createEl("span", null, "TD-AGE", nameTD, " ");
              			    // needs class for width
              			    var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', nameTD, person.age);
              			    //var spanTDo = this.createEl("span", null, "TD-AGE", nameTD, person.age);
              			else{
              			    // add a break
              			    this.createEl("br", null , null , spanTDo, null);
              			    // add a span with name
              			    var nameTD = this.createEl("span", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'',spanTDo, person.name);
              			    //var nameTD = this.createEl("span", null, "TD-BODY", spanTDo, person.name);
              			    // add a span with age
              			    var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', spanTDo, person.age);
              			    //var spanTD = this.createEl("span", null, "TD-AGE", spanTDo, person.age);
              			birthdays_seen[birthday] = true;
              		// Create TFOOT section -- currently used for debugging only
              		if (this.config.debugging) {
              		    var table_footer = this.createTableFooter(tBody, null, [" "," "]);
              		    //footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
              		else {
              	    // pass the created content back to MM to add to DOM.
              	    return wrapper;
              	// Dom is loaded
              	this.loaded = true;
              this code works but no css:
              	var wrapper = this.createEl("div",null,null,null,null);
              	    var now = moment();
              		// create table
              		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper,null)
              		var table_header = this.createTableHeader(table, null, [" "," "]);
              		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table, null);
              		var birthdays_seen= {}
              		var spacer = " ";
              			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY" , tBody, null);
              			let now = moment().format('DD.MM').valueOf();
              			let entrie=now;
              			    entrie = moment(birthday,'DD.MM').valueOf();
              			var bd = "";
              			    bd = (birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
              			    var imageTD = this.createEl('td', null, "TD-IMAGE" + (entrie < now)?"_DIMMED":'' , bodyTR, bd);
              			    var nameTD = this.createEl('td', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' , bodyTR, person.name);
              			    this.createEl("span", null, null, nameTD, " ");
              			    var spanTDo = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', nameTD, person.age);
              			else{
              			    // add a break
              			    this.createEl('br', null , null , spanTDo,null);
              			    var nameTD = this.createEl('span', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' ,spanTDo, person.name);
              			    var spanTD = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', spanTDo, person.age);
              			var spacerTR = this.createEl('tr', null, null , tBody, null);
              			var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, " ");
              			spacerTD.colSpan = "2";
              		else {
              	    return wrapper;
              	// Dom is loaded
              	this.loaded = true;
                sdetweil @Perlchamp
                @Perlchamp you need to learn the debugger, code fixed
                	getDom: function(){
                		var wrapper = this.createEl("div",null,null,null);
                		if(Object.keys(this.active_birthdays).length>0){
                			var table = this.createEl("table", "birthday-table", null, wrapper );
                			// table header here, array of column names
                			var table_header=this.createTableHeader(table,null, ["date","Name","age"])
                			var tBody = this.createEl('tbody', "birthday-t-body", "tbody", table, null);
                					var bodyTR = this.createEl('tr', null, "TR-BODY" ,tBody, null);
                					let now = moment()
                					let entrie=now
                					var bd = "";
                			    	if(birthdays_seen[birthday]==undefined){
                						bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
                						var imageTD = this.createEl('td', null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, bd);
                						var nameTD = this.createEl('td', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, person.name);
                									 this.createEl("span", null, null, nameTD, " ");						// needs class for width
                						var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), nameTD, person.age);
                					else{
                						// add a break
                						var nameTD = this.createEl('span', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') ,spanTDo, person.name);
                						var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), spanTDo, person.age);
                		return wrapper;
                see the last line of the console
                black screen means syntax error in some modulename.js, click on the line number and it will take you to that line in the code … note the concat(… is missing its right paren ‘)’
                • PerlchampP
                  Perlchamp
                  thank you very much. yes i need more expirience of debugging. it’s my second day i use it, sorry sam. AND MANY THANKS.
                    sdetweil @Perlchamp
                    @Perlchamp Make an error, take out a comma, or ’
                    reload the page, f5
                    put part of ht module name in the filter field of the console
                    find the error message
                    click the filename/line to the right
                    • PerlchampP
                      Perlchamp
                      ok, will collect some experience …
                      • PerlchampP
                        Perlchamp
                        ok, the blacksreen is gone, works, but no css
                          sdetweil @Perlchamp
                          @Perlchamp that comes up for me
                          Copied directly. Will send my module file.
                          • PerlchampP
                            Perlchamp
                            ok, thanks
                              sdetweil @Perlchamp
                              @Perlchamp see the expanded html on left
                              file sent
                              • PerlchampP
                                Perlchamp
                                it WORKS ! now i hope to find the error :-)
                                  sdetweil @Perlchamp
                                  @Perlchamp i did not use the classes , no… didn’t care about the layout etc…
                                  I want to make sure the NAMES of the classes are right…
                                  sending file again, sorting the dates
                                  • PerlchampP
                                    Perlchamp
                                    work’s, too :-) , sam
                                      dorinilut
                                      @Perlchamp , would it be possible to share the module you came up with? I am looking for the exact same thing and I was thinking I would be getting a copy.
                                      many many thanks!
                                      • 12
                                      • 13
                                      • 14
                                      • 15
                                      • 16
                                      • 16 / 16
