    read csv-data and put it in an array
    313 Posts 3 Posters 552.7k Views 4 Watching
      @Perlchamp my code had
      					let now = moment()
      					let entrie=now
      				    if(this.config.dimmEntries) {
      						entrie = moment(birthday,'DD.MM')
      					var bd = "";
      • PerlchampP Offline
        Perlchamp
        thanks a lot. i will study this …
          sdetweil @Perlchamp
          @Perlchamp make that one fix and then my code will work too
            Perlchamp
            update !
            i tried, but how should i do this ?
            i was in the dev. didn’t helped me. it’s , how said, the part
            .concat(entrie.isBefore(now)?"_DIMMED":''
            with => blackScreen
            without => working (formatted => css).
              sdetweil @Perlchamp
              @Perlchamp have to edit the source code, then reload the browser page, cannot edit in debugger
              let now = moment()
              					let entrie=now   // <-- this line was not included in yours..   i commented
                Perlchamp
                this code => blackScreen:
                    getDom: function() {
                	var wrapper = this.createEl("div", null, null, null, null);
                	// tell MM to call and get our content
                	Log.log(JSON.stringify(this.active_birthdays));
                	if ((moment() > this.midnight) || (!this.loaded)) {
                	    var month = moment().month();
                	    var year = moment().year();
                	    var monthName = moment().format("MMMM");
                	    var monthLength = moment().daysInMonth();
                	    var now = moment();
                	    if(Object.keys(this.active_birthdays).length > 0) {
                		// create your table here
                		var table = this.createEl("table", "birthday-table", "TABLE", wrapper, null);
                		// create tableheader here, array of column names
                		var table_header = this.createTableHeader(table, "THEAD", [" "," "]);
                		//var table_header = this.createTableHeader(table, null, [" "," "," "]);
                		// create TBODY section with day names
                		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY", table, null);
                		var birthdays_seen = {};
                		var spacer = " ";
                		for(var birthday of Object.keys(this.active_birthdays)) {
                		    for(var person of this.active_birthdays[birthday]) {
                			// create looped row section
                			var bodyTR = this.createEl("tr", "birthday-tr-body", "TR-BODY", tBody, null);
                			let now = moment();
                			let entrie = moment(birthday,"DD.MM");
                			// delete leading 0 and month
                			var bd = "";
                			if(birthdays_seen[birthday] == undefined) {
                			    bd = (birthday.startsWith("0")? birthday.substring(1): birthday).split(".")[0];
                			    var imageTD = this.createEl("td", null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, bd);
                			    //var imageTD = this.createEl("td", null, "TD-IMAGE", bodyTR, bd);
                			    var nameTD = this.createEl("td", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, person.name);
                			    //var nameTD = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
                			    this.createEl("span", null, "TD-AGE", nameTD, " ");
                			    // needs class for width
                			    var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', nameTD, person.age);
                			    //var spanTDo = this.createEl("span", null, "TD-AGE", nameTD, person.age);
                			else{
                			    // add a break
                			    this.createEl("br", null , null , spanTDo, null);
                			    // add a span with name
                			    var nameTD = this.createEl("span", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'',spanTDo, person.name);
                			    //var nameTD = this.createEl("span", null, "TD-BODY", spanTDo, person.name);
                			    // add a span with age
                			    var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', spanTDo, person.age);
                			    //var spanTD = this.createEl("span", null, "TD-AGE", spanTDo, person.age);
                			birthdays_seen[birthday] = true;
                		// Create TFOOT section -- currently used for debugging only
                		if (this.config.debugging) {
                		    var table_footer = this.createTableFooter(tBody, null, [" "," "]);
                		    //footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
                		else {
                	    // pass the created content back to MM to add to DOM.
                	    return wrapper;
                	// Dom is loaded
                	this.loaded = true;
                this code works but no css:
                	var wrapper = this.createEl("div",null,null,null,null);
                	    var now = moment();
                		// create table
                		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper,null)
                		var table_header = this.createTableHeader(table, null, [" "," "]);
                		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table, null);
                		var birthdays_seen= {}
                		var spacer = " ";
                			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY" , tBody, null);
                			let now = moment().format('DD.MM').valueOf();
                			let entrie=now;
                			    entrie = moment(birthday,'DD.MM').valueOf();
                			var bd = "";
                			    bd = (birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
                			    var imageTD = this.createEl('td', null, "TD-IMAGE" + (entrie < now)?"_DIMMED":'' , bodyTR, bd);
                			    var nameTD = this.createEl('td', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' , bodyTR, person.name);
                			    this.createEl("span", null, null, nameTD, " ");
                			    var spanTDo = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', nameTD, person.age);
                			else{
                			    // add a break
                			    this.createEl('br', null , null , spanTDo,null);
                			    var nameTD = this.createEl('span', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' ,spanTDo, person.name);
                			    var spanTD = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', spanTDo, person.age);
                			var spacerTR = this.createEl('tr', null, null , tBody, null);
                			var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, " ");
                			spacerTD.colSpan = "2";
                		else {
                	    return wrapper;
                	// Dom is loaded
                	this.loaded = true;
                  sdetweil @Perlchamp
                  @Perlchamp you need to learn the debugger, code fixed
                  	getDom: function(){
                  		var wrapper = this.createEl("div",null,null,null);
                  		if(Object.keys(this.active_birthdays).length>0){
                  			var table = this.createEl("table", "birthday-table", null, wrapper );
                  			// table header here, array of column names
                  			var table_header=this.createTableHeader(table,null, ["date","Name","age"])
                  			var tBody = this.createEl('tbody', "birthday-t-body", "tbody", table, null);
                  					var bodyTR = this.createEl('tr', null, "TR-BODY" ,tBody, null);
                  					let now = moment()
                  					let entrie=now
                  					var bd = "";
                  			    	if(birthdays_seen[birthday]==undefined){
                  						bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
                  						var imageTD = this.createEl('td', null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, bd);
                  						var nameTD = this.createEl('td', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, person.name);
                  									 this.createEl("span", null, null, nameTD, " ");						// needs class for width
                  						var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), nameTD, person.age);
                  					else{
                  						// add a break
                  						var nameTD = this.createEl('span', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') ,spanTDo, person.name);
                  						var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), spanTDo, person.age);
                  		return wrapper;
                  see the last line of the console
                  black screen means syntax error in some modulename.js, click on the line number and it will take you to that line in the code … note the concat(… is missing its right paren ‘)’
                    Perlchamp
                    thank you very much. yes i need more expirience of debugging. it’s my second day i use it, sorry sam. AND MANY THANKS.
                      sdetweil @Perlchamp
                      @Perlchamp Make an error, take out a comma, or ’
                      reload the page, f5
                      put part of ht module name in the filter field of the console
                      find the error message
                      click the filename/line to the right
                        Perlchamp
                        ok, will collect some experience …
                          Perlchamp
                          ok, the blacksreen is gone, works, but no css
                            sdetweil @Perlchamp
                            @Perlchamp that comes up for me
                            Copied directly. Will send my module file.
                              Perlchamp
                              ok, thanks
                                sdetweil @Perlchamp
                                @Perlchamp see the expanded html on left
                                file sent
                                  Perlchamp
                                  it WORKS ! now i hope to find the error :-)
                                    sdetweil @Perlchamp
                                    @Perlchamp i did not use the classes , no… didn’t care about the layout etc…
                                    I want to make sure the NAMES of the classes are right…
                                    sending file again, sorting the dates
                                      Perlchamp
                                      work’s, too :-) , sam
                                        dorinilut
                                        @Perlchamp , would it be possible to share the module you came up with? I am looking for the exact same thing and I was thinking I would be getting a copy.
                                        many many thanks!
                                        • 12
                                        • 13
                                        • 14
                                        • 15
                                        • 16
                                        • 16 / 16
