    read csv-data and put it in an array
    313 Posts 3 Posters 552.7k Views 4 Watching
    • PerlchampP Offline
      Perlchamp
      i’m a step foward (did write two functions for smarter code) :
         // creates a tablefooter with columns
          createTableFooter: function(parent, className, column) {
      	var footer = document.createElement("tr");
      	for(colContent of column) {
      	    this.createEl("td", null, className, footer, colContent);
      	parent.appendChild(footer);
      	return footer;
          // compares two dates, requires moment.js :
          // output "1"  : date1 > date2
          // output "-1" : date1 < date2
          // output "0"  : fault
          compareDate: function(now, entrie, format) {
      	let date_1 = moment(now,format).valueOf();
      	let date_2 = moment(entrie,format).valueOf();
      	if (date_1 > date_2) {
      	    return 1;
      	else if (date_1 < date_2) {
      	    return -1;
      	else {
      	    return 0;
      the lastone is used here:
      for(var birthday of Object.keys(this.active_birthdays)) {
      		    for(var person of this.active_birthdays[birthday]) {
      			// create looped row section
      			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY" , tBody, null);
      			// delete leading 0 and month
      			var bd = "";
      			if(birthdays_seen[birthday] == undefined) {
      			    bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
                   		    birthdays_seen[birthday] = true;
      			if (this.compareDate(now,birthday,"DD.MM") === 1) {
      			    if(this.config.dimmEntries) {
      				var imageTD = this.createEl('td', "birthday-td-image", "TD-IMAGE_DIMMED" , bodyTR, bd);
      				var nameTD = this.createEl('td', "birthday-td-body", "TD-BODY_DIMMED" , bodyTR, person.name);
      				var spanTD = this.createEl("span", "birthday-span-body", "TD-AGE_DIMMED", nameTD, person.age);
      				var spacerTR = this.createEl('tr', null, null , tBody, null);
      				var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, spacer);
      				spacerTD.colSpan = "2";
      			    else {
      			else {
      			    var imageTD = this.createEl('td', "birthday-td-image", "TD-IMAGE" , bodyTR, bd);
      			    var nameTD = this.createEl('td', "birthday-td-body", "TD-BODY" , bodyTR, person.name);
      			    var spanTD = this.createEl("span", "birthday-span-body", "TD-AGE", nameTD, person.age);
      it works fine for me :-). for the last step (people with the same birthday in one cell, separeted via < /br >) i have momently no ideas…
        sdetweil @Perlchamp
        @Perlchamp ok, not sure how u want to present the two people with the same date
        simplified code
        	getDom: function(){
        		var wrapper = this.createEl("div",null,null,null);
        		if(Object.keys(this.active_birthdays).length>0){
        			// create your table  here
        			var table = this.createEl("table", "birthday-table", null, wrapper );
        			// table header here, array of column names
        			var table_header=this.createTableHeader(table,null, ["date","Name","age"])
        			var tBody = this.createEl('tbody', "birthday-t-body", "tbody", table, null);
        			var birthdays_seen= {}
        					var bodyTR = this.createEl('tr', null, "TR-BODY" ,tBody, null);
        					let now = moment().format('DD.MM').valueOf();
        					let entrie=now
        						entrie = moment(birthday,'DD.MM').valueOf();
        					var bd = "";
        			    	if(birthdays_seen[birthday]==undefined){
        						var imageTD = this.createEl('td', null, "TD-IMAGE_"+(entrie < now)?"DIMMED":'' , bodyTR, bd);
        					else{
        						this.createEl('span', null , null , bodyTR,bd);
        					var nameTD = this.createEl('td', null, "TD-BODY_"+(entrie < now)?"DIMMED":'' , bodyTR, person.name);
        					var spanTD = this.createEl("span", null, "TD-AGE_"+(entrie < now)?"DIMMED":'', nameTD, person.age);
        					var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, "----");
        		return wrapper;
        maybe? but why?
        we have currently two rows, 3 columns
           day       name   age
           empty  name   age
        you want ?? two columns?
           row (2 cols)
             day      name + age < br>
                         name + age
           row (3 cols)
             dayn   name   age
          Perlchamp
          hi sam,
          right row 2 cols day name + age < br > … < br > name+age < br >
          the image below displays that:
          look at my code, it’s all implemated but not the users in one cell :
              getDom: function() {
          	var wrapper = this.createEl("div",null,null,null,null);
          	// tell MM to call and get our content
          	Log.log(JSON.stringify(this.active_birthdays));
          	if ((moment() > this.midnight) || (!this.loaded)) {
          	    var month = moment().month();
          	    var year = moment().year();
          	    var monthName = moment().format("MMMM");
          	    var monthLength = moment().daysInMonth();
          	    var now = moment();
          	    if(Object.keys(this.active_birthdays).length > 0) {
          		// create table
          		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper,null)
          		// create tableheader here
          		var table_header = this.createTableHeader(table, null, [" "," "]);
          		// create TBODY section with day names
          		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table, null);
          		var day_month_now = moment().format("DD.MM");
          		var spacer = " ";
          			var bd = "";
          			    else {
          			else {
          		// Create TFOOT section -- currently used for debugging only
          		if (this.config.debugging) {
          		    var table_footer = this.createTableFooter(tBody, null, [" "," "]);
          		    //footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
          		else {
          	    // pass the created content back to MM to add to DOM.
          	    return wrapper;
          	// Dom is loaded
          	this.loaded = true;
            sdetweil @Perlchamp
            @Perlchamp i missed the span instead of td for age… working on the join
              Perlchamp
              i have the span ! look in my code !
                sdetweil @Perlchamp
                @Perlchamp
                updated
                	getDom: function(){
                					let entrie=now
                					var bd = "";
                									 this.createEl("span", null, null, nameTD, " ");						// needs class for width
                						var spanTDo = this.createEl("span", null, "TD-AGE_"+(entrie < now)?"DIMMED":'', nameTD, person.age);
                					else{
                						// add a break
                						this.createEl('br', null , null , spanTDo,null);
                						// add a span with name
                						var nameTD = this.createEl('span', null, "TD-BODY_"+(entrie < now)?"DIMMED":'' ,spanTDo, person.name);
                						// add a span with age
                						var spanTD = this.createEl("span", null, "TD-AGE_"+(entrie < now)?"DIMMED":'', spanTDo, person.age);
                					var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, " ");
                		return wrapper;
                if we see 1st time br, do date, name/span/age
                if second time add line break to old name list
                add span for name, span span for separator (need class for width), span for age
                  Perlchamp
                  first i have to change my classes ? instead of TD-IMAGE TD-IMAGE_, ?
                    sdetweil @Perlchamp
                    @Perlchamp the classname is a string
                    and the front part is the same
                    so , you had duplicated code, just to change the classname…
                    I just used your if(entrie) to decide it the name needed the’DIMMED" part added
                    move the _ to the “DIMMED”, like this “_DIMMED”
                    then they will be TD-IMAGE and TD-IMAGE_DIMMED , just like you had it…
                    its the same row data and parentage, just a class change… (nice work having common names, so you could do this), got rid of that big else…
                      Perlchamp
                      css i don’t get to work. here’s my getDom:
                      	    var now = moment();
                      		// create table
                      		// create tableheader here, array of column names
                      		var spacer = " ";
                      			let entrie=now;
                      			var bd = "";
                      			    bd = (birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
                      			    var imageTD = this.createEl('td', null, "TD-IMAGE" + (entrie < now)?"_DIMMED":'' , bodyTR, bd);
                      			    var nameTD = this.createEl('td', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' , bodyTR, person.name);
                      			    var spanTDo = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', nameTD, person.age);
                      			else{
                      			    // add a break
                      			    var nameTD = this.createEl('span', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' ,spanTDo, person.name);
                      			    var spanTD = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', spanTDo, person.age);
                      		else {
                      	    return wrapper;
                      	// Dom is loaded
                      	this.loaded = true;
                      there should be an error i don’t see.
                        sdetweil @Perlchamp
                        @Perlchamp use the debugger, expand the elements tree, find the table and look at the classes assigned
                          Perlchamp
                          hi sam,
                          if i do this:
                             var imageTD = this.createEl("td", null, "TD-IMAGE", bodyTR, bd);
                          instead of this :
                          var imageTD = this.createEl("td", null, "TD-IMAGE" + (entrie < now)?"_DIMMED":'' , bodyTR, bd);
                          css are addressed. maybe something has to change in the createEl function ?
                            sdetweil @Perlchamp
                            @Perlchamp let me look…
                              sdetweil @Perlchamp
                              @Perlchamp
                              warning one ( was missing, fixed
                              SORRY… tested now… the + append didn’t work, had to force with concat()…
                              Its the two values, now and entrie
                              				let now = moment().format('DD.MM').valueOf();				 // this is string dd.mm
                              				let entrie=now
                              					entrie = moment(birthday,'DD.MM').format.valueOf();     // this is a moment
                              so later when compared, it doesn;t work
                              and comparing strings with < doesn’t really work…
                              I would do
                              let now=moment()
                              let entrie = moment(birthday,‘DD.MM’)
                              then in the compare
                              (entrie.isBefore(now))?..
                              	getDom: function(){
                              					let now = moment()
                              					let entrie=now
                              					var bd = "";
                              						var imageTD = this.createEl('td', null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, bd);
                              						var nameTD = this.createEl('td', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, person.name);
                              						var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), nameTD, person.age);
                              					else{
                              						// add a break
                              						var nameTD = this.createEl('span', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') ,spanTDo, person.name);
                              						var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), spanTDo, person.age);
                              		return wrapper;
                                @Perlchamp see my update above
                                  Perlchamp
                                  @sdetweil said in read csv-data and put it in an array:
                                  sorry, doesn’t work. blackscreen. if i change back (my post) css is addressed. i didn’t change the jet = part. i think, something’s wrong with the cerateEl function, but you know i’m not an expert.but to control. here is my code :
                                  			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY", tBody, null);
                                  			let now = moment();
                                  			let entrie = moment(birthday,"DD.MM");
                                  			    entrie = moment(birthday,'DD.MM');
                                  			var bd = "";
                                  			    //var imageTD = this.createEl('td', null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, bd);
                                  			    //var nameTD = this.createEl("td", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, person.name);
                                  			    var nameTD = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
                                  			    this.createEl("span", null, "TD-AGE", nameTD, " ");
                                  			    //var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', nameTD, person.age);
                                  			    var spanTDo = this.createEl("span", null, "TD-AGE", nameTD, person.age);
                                  			else{
                                  			    // add a break
                                  			    this.createEl("br", null , null , spanTDo, null);
                                  			    //var nameTD = this.createEl("span", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'',spanTDo, person.name);
                                  			    var nameTD = this.createEl("span", null, "TD-BODY", spanTDo, person.name);
                                  			    //var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', spanTDo, person.age);
                                  			    var spanTD = this.createEl("span", null, "TD-AGE", spanTDo, person.age);
                                  			var spacerTR = this.createEl("tr", null, null , tBody, null);
                                  			var spacerTD = this.createEl("td", null, "SPACER", spacerTR, " ");
                                    sdetweil @Perlchamp
                                    @Perlchamp ah well. both work here… your latest and mine produce the same results
                                    your output
                                    date	Name	age
                                    12	Sam 69
                                    2	Frank 81
                                    Sue81
                                    5	mary 65
                                    10	eee EEEEE 51
                                    16	fff FFFFF 8
                                    ggg GGGGG32
                                    27	hhh HHHHH 18
                                    my output
                                    date	Name	age
                                    12	Sam 69
                                    2	Frank 81
                                    Sue81
                                    5	mary 65
                                    10	eee EEEEE 51
                                    16	fff FFFFF 8
                                    ggg GGGGG32
                                    27	hhh HHHHH 18
                                      Perlchamp
                                      what does that mean? but you don’t use css, do you ? YES, but didn’t you see, that i have annotate the
                                      lines in the code, i posted ? without entrie.isBefore … css is addressed, with it’s not addressed
                                        sdetweil @Perlchamp
                                        @Perlchamp I stepped thru and watched it change from with dimmed and without
                                          Perlchamp
                                          sorry for nerving, sam. i would like to understand the code. where is the part in which the name and age of people with the same birthday are collected/combined ?
                                            sdetweil @Perlchamp
                                            @Perlchamp I’ll use you last code post
                                            // loop thru all the brithdays found in the file that match this month, one at a time
        // each row is a person
        // create a row
        // get timne/date of now
                                            			let now = moment();
        // we need to change the style to dimmed,. if the BD is in the past
                                            			//let entrie = moment(birthday,"DD.MM");                      // < --- problem
        // assume the birthday is NOT in the past
                                            			let entrie = now
        // if the user requested dimming
        // get the brithdate in this year 01.05.2020
        // note the value WAS the SAME as 'now'
        // set the default value for the birthdate display
                                            			var bd = "";  // assume we don't need to display it
                                               			// if we have not seen this birthdate in the loop so far, its the fiist time
        // so we need the number of the day of the month
        // if it starts with 0, get from char 1 on sop 01.05 becomes 1.05, then
        // use split to get the parts [ 1, 05]
        // if not '0', use all bd numbers 12.05, and split to [12,05]
        // and take the 1st element of array
        // 1, or 12, for the two examples
        // now we need a row of data for the the person
        // class name is either TD-IMAGE or TD-IMAGE_DIMMED
        // use the two moments to compare (the fix for the entrie= now above will fix this)
        // if the persons ds is before now, and we want dimmed, then add the tail of the class name on
        // else use this the name (concat('') - add nothing))
        // this  entrie.isBefore(now)?'_DIMMED':'' means
        // the result of the expression is entrie before now
        // if true return '_DIMMED'
        // if false return ''
        // "TD-IMAGE".concat() this means add onto the string "TD-IMAGE" whatever is inside the concat() parens, either '_DIMMED' or ''
        // so the class will be TD-IMAGE (for people with bithrdays ON or AFTER today)
        // or TD-IMAGE_DIMMED for people with birthdays BEFORE today
                                            			    var nameTDo = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
                                            			    //var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', nameTDo, person.age);
                                            			    var spanTD = this.createEl("span", null, "TD-AGE", nameTD0, person.age);
                                            			else{
        // we HAVE seen the birthday before, the row is already created, so we need to add to the END THAT ROW, ie after the span of the previous person
                                            			    // add a break (to the end of the TD for the name (has span already for age)
                                            			    this.createEl("br", null , null , nameTDo, null);
                                            			    //var nameTD = this.createEl("span", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'',nameTDo, person.name);
        //  add a span for the persons name (after the line break
                                            			    var nameTD = this.createEl("span", null, "TD-BODY", nameTDo, person.name);
                                            			    // add a span with for spacing
                                            			    var spanTD = this.createEl("span", null, "TD-AGE", nameTDo, person.age);
        // if we have another person with the same BD, new stuff will be added after this span
        // regardless of 1st or second, we have seen this birthdaty
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 15 / 16
