    resolved.. MMM-NetworkScanner
    20 Posts 6 Posters 7.5k Views 7 Watching
      bhepler Module Developer @sonicgoose
      @sonicgoose - I’m curious: why do you have commas inside the names of some of your devices? It looks like every Apple device is labeled “Apple,” with the comma inside. Same for the Google devices.
      Also, could you expand on “doesn’t work properly”? What is it doing that you do not want? What is it not doing that you do want?
        sonicgoose @bhepler
        @bhepler The commas inside the quotes are a find and replace issue, easily fixed. The main problem is that this module says it offers different displays: list, columns, or columns with new lines—but all I get is the list. What I want is the columns with new lines, as shown on the module’s GitHub page (see link in first post.)
          DarrenHill
          Double-check in the MMM-NetworkScanner.js file if you can find any comments with "sjj: " in them. If not then you have the original (ianperrin) version of the module, which doesn’t have the modifications in it such as the column mode.
          Only the slametps fork has them, and that’s the version with the column view in it.
          I hit this issue over the weekend and found that was the problem. Still not sure how I ended up with the wrong version, but I grabbed the correct script from the GitHub repo page and now it’s working fine (except it doesn’t work with my Apple devices as they don’t respond to pings).
            sonicgoose @DarrenHill
            @DarrenHill
            git remote -v
            shows
            origin	https://github.com/spitzlbergerj/MMM-NetworkScanner.git (fetch)
            origin	https://github.com/spitzlbergerj/MMM-NetworkScanner.git (push)
            but as you suggested I did find “sjj:” in some comments. Do you have a link to the fork that works for you? slametps doesn’t come up with anything on GitHub.
              sdetweil @sonicgoose
              @sonicgoose its HIS fork and HIS special branch … so you have to clone HIS repo, then switch to the special branch that has the code
                sonicgoose @sdetweil
                @sdetweil Thanks. Github is to me about as intuitive as theoretical physics. How exactly do I go about that?
                  that means the USER slametps has a copy (fork) of the original repo, and this fork has the changes
                  SO…
                  go to github and find the user slametps, (there is a search box) or google search ‘slametps github’, find his list of repos (push the repositories link), and scroll til you find it, or put ‘network’ (some part of the repo name) in the ‘find a repository’ field and hit enter
                  click on the repo name, click on clone or download, click on the clipboard (to copy the url to use in clone)
                  go to your system ~/MagicMirror/modules folder (in a terminal window)
                  rename your old MMM-NetworkScanner folder out of the way (to some other name, ANY other name)
                  then
                  git clone (paste the link from the clipboard)
                  cd MMM-NetworkScanner
                  it has a package.json, that means u need to do
                  npm install
                  then restart your MM, and read the readme for the slametps copy of the repo for new features
                    @sdetweil said in resolved.. MMM-NetworkScanner:
                    slametps
                    I’ve removed the version I had and installed the repo found here, which has outdated instructions telling me to install the ianperrin version. (I didn’t.) After restarting MM on my RPi, I know get just a list of mac addresses as I entered them in the config where I was getting at least a list of device names and icons. I’m getting really frustrated with this. Maybe time to take a break from it…
                      @sonicgoose i looked at his code, and it doesn’t look different…
                      I don’t know anything about the module
                        @sdetweil Thanks. I appreciate the help and that you took the time to look at the code. I wish I knew more about how this stuff works. I’m learning, but I’m also getting frustrated. I’ll revisit this another time.
                          DarrenHill
                          This one, from the repo linked above:
                          https://github.com/spitzlbergerj/MMM-NetworkScanner/blob/master/MMM-NetworkScanner.js
                          Personally I hate GitHub too, finding it about as straightforward as spaghetti. So I just copied that file and overwrote the one I had installed with it. Then it worked fine.
                          You can see where it’s been updated based around the comments starting “// sjj” that I mentioned before.
                          It sounds like the one you already have though. But that version is working for me with multiple rows and columns. This is the relevant part from my config.js (it works equally well with macAddress, I just prefer IP ones):
                          			module: "MMM-NetworkScanner",
                          			position: "bottom_right",
                                                          sort: false,
                                                          showUnknown: false,
                                                          showDeviceColums: true,
                                                          coloredState: true,
                          				devices: [
                          					{ ipAddress: "192.168.0.1", name: "Router", icon: "wifi", colorStateOnline: "green", colorStateOffline: "red" },
                          					{ ipAddress: "192.168.0.2", name: "Repeater", icon: "wifi", colorStateOnline: "green", colorStateOffline: "red" },
                          					{ ipAddress: "192.168.0.3", name: "NAS1", icon: "server", colorStateOnline: "green", colorStateOffline: "red" },
                          					{ ipAddress: "192.168.0.4", name: "NAS2", icon: "server", colorStateOnline: "green", colorStateOffline: "red" },
                          					{ ipAddress: "192.168.0.5", name: "LoungePi", icon: "tv", colorStateOnline: "green", colorStateOffline: "red", showInNewRow: true },
                          					{ ipAddress: "192.168.0.6", name: "BedroomPi", icon: "tv", colorStateOnline: "green", colorStateOffline: "red" },
                          					{ ipAddress: "192.168.0.7", name: "RadioPi", icon: "music", colorStateOnline: "green", colorStateOffline: "red" },
                          					{ ipAddress: "192.168.0.8", name: "DockerPi", icon: "cubes", colorStateOnline: "green", colorStateOffline: "red" },
                          					{ ipAddress: "192.168.0.9", name: "Printer", icon: "print", colorStateOnline: "green", colorStateOffline: "red", showInNewRow: true },
                          					{ ipAddress: "192.168.0.10", name: "VPNPi", icon: "lock", colorStateOnline: "green", colorStateOffline: "red" },
                          					{ ipAddress: "192.168.0.11", name: "PiHole", icon: "filter", colorStateOnline: "green", colorStateOffline: "red" },
                          					{ ipAddress: "192.168.0.12", name: "Hive Hub", icon: "plug", colorStateOnline: "green", colorStateOffline: "red" },
                          					{ ipAddress: "192.168.0.13", name: "ButtonPi", icon: "keyboard", colorStateOnline: "green", colorStateOffline: "red", showInNewRow: true },
                          					{ ipAddress: "192.168.0.14", name: "Fingbox", icon: "hockey-puck", colorStateOnline: "green", colorStateOffline: "red" },
                          					{ ipAddress: "192.168.0.15", name: "Connect", icon: "broadcast-tower", colorStateOnline: "green", colorStateOffline: "red" },
                          					{ ipAddress: "192.168.0.16", name: "Quatro", icon: "broadcast-tower", colorStateOnline: "green", colorStateOffline: "red" }
                            sonicgoose
                            I’ve done a complete reinstall of MagicMirror, all the modules I had, from scratch, and this one still produces only a list, not nice columns and rows of icons. I’ve officially given up.
                              @sonicgoose that source file documents a new config parm
                              showDeviceColums
                              which is false by default
                              add and set to true
                                DarrenHill
                                @sonicgoose - Note the (mis)spelling of the config parameter for columns - the config entry is “showDeviceColums”, not “showDeviceColumns”. It is missing an n, and needs it removed to work (or the script corrected for it).
                                See my config example above, which works. Yours is wrong as (ironically) it’s spelt correctly!
                                S S 2 Replies Last reply Reply Quote 1
                                  sdetweil @DarrenHill
                                  @DarrenHill yeh, I cut/pasted the name from the code, didn’t check it…
                                  code fix, allow both!
                                    @DarrenHill Are you #&%*ing kidding me?!? An n? That’s what’s been driving me nuts? Aaaaaarrrrrrgggghhhhhhhhh!
                                    It works now.
                                    Thank you all very much for your help. Even when I gave up, you guys didn’t, and I appreciate that.
                                      DarrenHill
                                      You’re welcome - glad it’s finally working for you :)
