    Black screen after i added assistant and hotword to config
    2 Posts 2 Posters 163 Views 2 Watching
    • O Offline
      Obakemono
      Can anyone help ? im new to coding so help would be appreciated
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	zoom: 1,
      	address: "", // Address to listen on, can be:
      	port: 8080,
      	ipWhitelist: [], // Set [] to allow all IP addresses
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			     // false, default for all  NON-armv6l devices
                     module: "MMM-Hotword",
                     position: "centre_top",
      		chimeOnFinish: null,
      		mic: {
      			recordProgram: "arecord",
      			device: "plughw:1"
      		models: [
      				hotwords    : "smart_mirror",
      				file        : "smart_mirror.umdl",
      				sensitivity : "0.5",
      		commands: {
      			"smart_mirror": {
      				notificationExec: {
      					notification: "ASSISTANT_ACTIVATE",
      					payload: (detected, afterRecord) => {
      						return {profile:"default"}
      				restart:false,
      				afterRecordLimit:0
      	module: "MMM-AssistantMk2",
      		deviceLocation: {
      			coordinates: {
      				latitude: 57.182937, // -90.0 - +90.0
      				longitude: 2.201246, // -180.0 - +180.0
      		record: {
      			recordProgram : "arecord",
      			device        : "plughw:1",
      		notifications: {
      			ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
      			ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
      		useWelcomeMessage: "brief today",
      		profiles: {
      			"default" : {
      				lang: "en-US"
      			module: "alert",
                              module: "compliments",
                              position: "lower_third"
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "UK Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"					}
      			module: "currentweather",
      				locationID: "2657832",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "b577b21d7aa76d1c63a88af2513126d2"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "BBC News",
      						url: "http://feeds.bbci.co.uk/news/rss.xml"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
        A Former User
        hi, i think it’s better for you reading offical wiki in each module on github website
