    "weather" module hangs at "Loading..."
    7 Posts 2 Posters 1.9k Views 2 Watching
    • G Offline
      goobertek
      Regardless of the which provider I chose the “weather” module stops at “Loading…” the other modules are loading fine. here is my code:
          module: "weather",
               weatherProvider: "weathergov",
               units: "config.units",
               tempUnits: "config.units",
               windUnits: "config.units",
               roundTemp: "true",
               updateInterval: "1000",
               api: "https://api.weather.gov/points/",
               weatherEndpoint: "/forcast",
               lat: "38.9536",
               lon: "-94.7336",
               type: "current"
        sdetweil @goobertek
        @goobertek don’t post twice…
        I deleted the duplicate
          sdetweil @goobertek
          @goobertek read the readme…
          you’ve got a typo
          weatherEndpoint	The weather.gov API endPoint.
          Possible values: /forecast for forecast and /forecast/hourly for current.
          This value is REQUIRED
          • G Offline
            goobertek
            Thanks for the support but I am still getting “Loading…” The only thing I changed was:
            weatherEndPoint: “/forecast”,
            • G Offline
              goobertek
              I think there is something more fundamentally wrong with my config file because I can’t get the default weather config to work. Here is my config file:
                                      module: "weather",
                                              type: 'current'
              It just sits at “Loading” while all those before and after work fine. How long should this take to load?
                sdetweil @goobertek
                @goobertek the doc says there is a whole bunch of options
                https://docs.magicmirror.builders/modules/weather.html#configuration-options
                that go inside the
                section
                • G Offline
                  goobertek
                  Thanks!
                  I was thinking about that but the documentation indicates where something is required. I had all of the options added but that didn’t work either. I am running the Mirror Server. Would that make a difference?
