    MMM-Strava
    Scheduled Pinned Locked Moved Health
    activity trackerhealthstrava
    138 Posts 34 Posters 254.5k Views 35 Watching
    • I Offline
      ianperrin @ianperrin
      An updated version of the module is now available which includes the option to display your last weeks activity in a more graphical format (similar to how it is displayed on your Strava profile).
      Chart mode
      To enable this feature on your mirror,
      • The MMM-Strava module should be installed (or updated)
      • The mode: "chart" option should be added to your config.js file
      Note if the new mode option is not included (or set if it is not set to chart) the classic table layout will be used.
      "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
      G 1 Reply Last reply Reply Quote 2
      • iMAGiCI Offline
        iMAGiC @ianperrin
        @ianperrin Hi, I add Strava rotate like below, but only this module stopped(blank) after 7 hours running. all modules still running well, but Strava, please suggest a hint to solve this issue, thank you very much.
        iMAGiCJAKE
        		        module: 'MMM-Strava',
        			position: 'top_right',
        			header: 'STRAVA ACTIVITY',
                    			strava_id: 'xxxxxxx',
                    			access_token: 'xxxxxxxxxx',
        				auto_rotate: true
        Choice * Judgment * Values
        • I Offline
          ianperrin @iMAGiC
          @iMAGiC are you able to share the contents of your log at the time the module stopped refreshing?
          iMAGiCI 2 Replies Last reply Reply Quote 0
          • iMAGiCI Offline
            iMAGiC @ianperrin
            @ianperrin sorry for late reply, it was quite busy this week, I will try it again in this week.
            btw, could this module run and show two people record? for ex. one for me, one for my wife.
            • I Offline
              ianperrin @iMAGiC
              @iMAGiC said in Strava:
              The module doesn’t currently support multiple people. However you could try adding the module twice to your config.js file.
              • iMAGiCI Offline
                iMAGiC @ianperrin
                @ianperrin
                I tried that(add twice), both aren’t show any record.
                • iMAGiCI Offline
                  iMAGiC @ianperrin
                  @ianperrin add twice will cause 2 modules won’t work. and after I tested in an all new Raspbian Jessie installation, it still happen abnormal flashing in rotate mode or stop showing anything after 10 mins or more, but every time happened.
                  in pm2 log won’t show anything error on this module. I will turn it to no rotate mode anyway.
                  • iMAGiCI Offline
                    iMAGiC @ianperrin
                    @ianperrin I made a video for saying abnormal flashing in table rotate mode, if like like to see it.
                    https://goo.gl/KNdkk7
                    • karsten13K Offline
                      karsten13 @iMAGiC
                      @iMAGiC Found this thread today, can reproduce your problems:
                      a) more than 1strava-module don’t work
                      b) flashing problem
                      I already opened an issue here
                      • brandongomezB Offline
                        brandongomez
                        Great module! I tried to implement but my module is stuck at “Loading…”
                        Guessing it has something to do with the API creation. I have my athlete ID that I see when I look at my Strava profile.
                        I ended up with a Client ID, Client Secret and Access Token when I created the API. Guessing I should be using only the Access Token?
                        Also, when I created the API, I had to put in a website and authorization callback domain. Not sure if these have an affect but I used the internal IP for the raspberry pi for both. Is that right? Thanks!
                        • 13
                        • 14
                        • 1 / 14
