    MMM-Strava
    Scheduled Pinned Locked Moved Health
    activity trackerhealthstrava
    138 Posts 34 Posters 257.1k Views 35 Watching
    • I Offline
      ianperrin @iMAGiC
      @iMAGiC are you able to share the contents of your log at the time the module stopped refreshing?
      "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
      iMAGiCI 2 Replies Last reply Reply Quote 0
      • iMAGiCI Offline
        iMAGiC @ianperrin
        @ianperrin sorry for late reply, it was quite busy this week, I will try it again in this week.
        btw, could this module run and show two people record? for ex. one for me, one for my wife.
        Choice * Judgment * Values
        • I Offline
          ianperrin @iMAGiC
          @iMAGiC said in Strava:
          The module doesn’t currently support multiple people. However you could try adding the module twice to your config.js file.
          • iMAGiCI Offline
            iMAGiC @ianperrin
            @ianperrin
            I tried that(add twice), both aren’t show any record.
            • iMAGiCI Offline
              iMAGiC @ianperrin
              @ianperrin add twice will cause 2 modules won’t work. and after I tested in an all new Raspbian Jessie installation, it still happen abnormal flashing in rotate mode or stop showing anything after 10 mins or more, but every time happened.
              in pm2 log won’t show anything error on this module. I will turn it to no rotate mode anyway.
              • iMAGiCI Offline
                iMAGiC @ianperrin
                @ianperrin I made a video for saying abnormal flashing in table rotate mode, if like like to see it.
                https://goo.gl/KNdkk7
                • karsten13K Online
                  karsten13 @iMAGiC
                  @iMAGiC Found this thread today, can reproduce your problems:
                  a) more than 1strava-module don’t work
                  b) flashing problem
                  I already opened an issue here
                  • brandongomezB Offline
                    brandongomez
                    Great module! I tried to implement but my module is stuck at “Loading…”
                    Guessing it has something to do with the API creation. I have my athlete ID that I see when I look at my Strava profile.
                    I ended up with a Client ID, Client Secret and Access Token when I created the API. Guessing I should be using only the Access Token?
                    Also, when I created the API, I had to put in a website and authorization callback domain. Not sure if these have an affect but I used the internal IP for the raspberry pi for both. Is that right? Thanks!
                    • G Offline
                      GMD @brandongomez
                      Hi
                      Did you get a resolution to your issue as I seem to have similar issue with module stuck at Loading…
                      When I look at the terminal window I am getting error:
                      Error performing request: Unauthorized. Access Token will be reset.
                      Error while fetching new athlete stats.
                      Look at code this is a 401 error.
                      I am getting confused as I thought the Strava API key was public but from this error it looks as though it wants to authorise API Key.
                      As this is an old post I will create a new post this evening with some more detail.
                      • G Offline
                        GMD @ianperrin
                        @ianperrin
                        Hi Ian
                        Can you help as I think I am getting confused.
                        I carried out the following steps:
                        1. Imported MMM-Strava into my modules folder.
                        2. Logged into my Strava account and navigated ->Settings->My API Application
                        3. Created an application icon
                        4. Completed fields, Application Name = MyData, Category = Other, Website = https://Strava.com, Authorization Callback Domain = 127.0.0.1
                        5. Click update button
                        6. Copied Client ID and Your Access Token (?) (permissions: public)
                        7. Update MagicMirror config.js with Client ID and Your Access Token
                        8. Restarted MagicMirror
                        When MagicMirror displays the Strava modules says Loading… and looking at the terminal window I can see errors:
                        Which looks to be a 401 error from code that, access token has not been authorised.
                        Can anybody point me to what I am doing wrong.
                        • 13
                        • 14
                        • 1 / 14
