    white screen flash on startup
    4 Posts 3 Posters 999 Views 4 Watching
      Re: White flash when electron boots up
      this is happening again, and I’;m following a issue on the electron site,
      a workaround that should help us
      add
      electronOptions: { backgroundColor: “#00000001”}, to your config.js, before the address:
      like this
      var config = {
      	electronOptions:{backgroundColor:'#00000001'}, // width:800, height:1024, fullscreen:false },  // add this line
      	address: "0.0.0.0",
      I see a marked improvement
      BKeyportB 1 Reply Last reply Reply Quote 1
      • BKeyportB Online
        @sdetweil Does nothing in my case.
          sdetweil @BKeyport
          @BKeyport bummer
            robertalexa
            @sdetweil said in white screen flash on startup:
            electronOptions:{backgroundColor:‘#00000001’},
            Not working for me either :) But thank you for trying. Hopefully we will see a solution, my mirror is only on between certain times (with a Google Home routine and Sonoff switch) and the white bg is super annoying.
