    MMM-WunderGround not updating after a few hours
    5 Posts 3 Posters 4.0k Views 5 Watching
    • L Offline
      lsfourwheeler
      I have installed the MMM-Wunderground module an have been running it for a couple week but cannot solve an issue with it continually ceasing to update until MM is restarted. It does this after about 8-12 hours. I have checked the PM2 logs and they do not show any related errors. When I use the NPM start dev command an watch the console I have found an error that says:
      "The ‘Access-Control-Allow-Origin’ header has a value ‘http://www.wunderground.com’ that is not equal to the supplied origin. Origin ‘http://localhost:8080’ is therfore not allowed access.
      This is followed by a message that says “MMM-WunderGround:* Could not load weather.” I have seen other people with this issue but no publicly posted solution. Does anyone have a suggestion? Thanks.
      • L Offline
        lsfourwheeler
        It’s still updating after this error but I will monitor more and see if another error occurs before it stops updating entirely.
        • RedNaxR Offline
          RedNax Module Developer
          Changed around some things in the way information is retrieved from weatherunderground. It’s on github, please test.
          • O Offline
            ostfilinchen @RedNax
            @RedNax now i get the error, that the key does not exist. But it does. The next updating the weather, it works again.
            • L Offline
              lsfourwheeler @lsfourwheeler
              I will update and check the functionality. Thanks.
              @RedNax said in MMM-WunderGround not updating after a few hours:
