    Black screen for copy of hellowold module
    4 Posts 2 Posters 2.4k Views 2 Watching
    • T
      titusece
      I have tried to create a new module in MM, for that I have copied helloworld module from “modules/defauls/helloworld” to “modules/Titus”,
      I just renamed to ‘Titus’ as a module.
      Then I changed the config.js file for a new Titus module.
      I am getting black screen now for the Titus module, but just work fine for helloworld.
      Why ?, any dependencies ?
      Can any one please help me on this ?
      I’m very new to this (MMM)
      //Worked
      module: 'helloworld',
      position: 'middle_center',
      header: 'helloworld module',
      text: 'I'm helloworld module'
      } // closes config
      }, // closes module helloworld
      //Not worked
      module: 'Titus',
      header: 'Titus module',
      text: 'I'm Titus module'
      Regards,
      Titus S.
      • Y
        yawns Moderator
        So you created a copy of the helloworld module and moved it to modules/Titus?
        Then you renamed helloworld.js to Titus.js?
        Did you modify Titus.js and changed this line
        javascript Module.register("helloworld",{
        to
        javascript Module.register("Titus",{
        to tell MagicMirror there is a new module called Titus?
        Reply Quote 2
        • T
          titusece
          Yes, I did like that only.
          Changed to like below.
          javascript Module.register(“Titus”,{
          Anything I want to do ?
          • T
            titusece
            I found the problem.
            Initially I named module as “Titus” and have javscript as “titus.js”.
            I renamed like below and it worked.
            “titus.js” to “Titus.js”
                                module: 'Titus',
                                        text: 'Glory to God, Jesus and Holyspirit, all the time'
            Thank you.
            Regards,
            Titus S.
