    mmm assistant mk2
    112 Posts 12 Posters 57.6k Views 11 Watching
      dvbit @Guest
      @Bugsounet said in mmm assistant mk2:
      ~/MagicMirror/node_modules/electron/dist $ ls -la
      pi@MagicMirror:~/MagicMirror $ ~/MagicMirror/node_modules/electron/dist $ ls -la
      bash: /home/pi/MagicMirror/node_modules/electron/dist: Is a directory
      pi@MagicMirror:~/MagicMirror $ cd ~/MagicMirror/node_modules/electron/dist
      pi@MagicMirror:~/MagicMirror/node_modules/electron/dist $ ls -la
      total 107496
      drwxr-xr-x 4 pi pi     4096 May 30 12:38 .
      drwxr-xr-x 4 pi pi     4096 May 30 12:38 ..
      -rw-r--r-- 1 pi pi   145945 May 30 12:38 chrome_100_percent.pak
      -rw-r--r-- 1 pi pi   209147 May 30 12:38 chrome_200_percent.pak
      -rwxr-xr-x 1 pi pi  4202140 May 30 12:38 chrome-sandbox
      -rwxr-xr-x 1 pi pi 74664904 May 30 12:38 electron
      -rw-r--r-- 1 pi pi 10410272 May 30 12:38 icudtl.dat
      -rwxr-xr-x 1 pi pi   157372 May 30 12:38 libEGL.so
      -rwxr-xr-x 1 pi pi  1949660 May 30 12:38 libffmpeg.so
      -rwxr-xr-x 1 pi pi  4883208 May 30 12:38 libGLESv2.so
      -rw-r--r-- 1 pi pi     1060 May 30 12:38 LICENSE
      -rw-r--r-- 1 pi pi  3961766 May 30 12:38 LICENSES.chromium.html
      drwxr-xr-x 2 pi pi     4096 May 30 12:38 locales
      -rw-r--r-- 1 pi pi    83237 May 30 12:38 natives_blob.bin
      drwxr-xr-x 2 pi pi     4096 May 30 12:38 resources
      -rw-r--r-- 1 pi pi  8471329 May 30 12:38 resources.pak
      -rw-r--r-- 1 pi pi   275792 May 30 12:38 snapshot_blob.bin
      -rw-r--r-- 1 pi pi   608820 May 30 12:38 v8_context_snapshot.bin
      -rw-r--r-- 1 pi pi        5 May 30 12:38 version
      Please look also post above: I realize my asoundrc file may be screwed since I did not complete on second install the sound output wizard successfully
        sdetweil @dvbit
        @dvbit run
        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixsandbox)"
          A Former User
          sam : you have right
          permission is not set
          After 6 month … maybe it will be solved !
            dvbit @sdetweil
            done
            here the output
            pi@MagicMirror:~/MagicMirror/node_modules/electron/dist $ bash -c $(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixsandbox)
            total 107496
            I mean I did run the bash
            No output. here is the detail listing of the folder.
            I do not see any timestamps changed…
              sdetweil @Guest
              @Bugsounet don’t count on it!!
                A Former User
                not fixed
                  sdetweil @dvbit
                  @dvbit have to do from the MagicMirror folder… sorry, will fix for future
                    A Former User
                    sudo chown root node_modules/electron/dist/chrome-sandbox
                    sudo chmod 4755 node_modules/electron/dist/chrome-sandbox
                      dvbit @sdetweil
                      done it from MagicMirror folder.
                      Can I see any file being changed somewhere?
                      I did a ls -la in
                      and there seems to be no change there
                        A Former User
                        result must be:
                        -rwsr-xr-x 1 root pi  4204060 mai   20 15:23 chrome-sandbox
                        S D 2 Replies Last reply Reply Quote 0
                          sdetweil @Guest
                          @Bugsounet maybe he doesn’t have sudo rights…
                          must do change to root first
                            sdetweil @dvbit
                            @dvbit it NEEDS the quotes
                            I see I had a typo, try again
                              dvbit @sdetweil
                              @sdetweil Thanks I removed the final quote as I was ending up with a prompt
                              will try again now with
                                dvbit @Guest
                                @Bugsounet and it is
                                -rwsr-xr-x 1 root pi 4202140 May 30 12:38 chrome-sandbox
                                  A Former User
                                  result:
                                  fixing sandbox permissions
                                    A Former User
                                    cool ;)
                                    let retry now MAgicMirror
                                    edit: Fingers crossed
                                      A Former User
                                      With lost @dvbit in MagicMirror and GoogleAssistant ! :crazy_face:
                                        dvbit
                                        S*t I was sent away from the leaving room where I have the mirror by the cleaning lady :-)
                                        Cannot interact with it for a couple of hours.
                                        Still hanging after query.
                                        I am uploading a video to Google drive of an interaction.
                                        It is as if the plugin was not receiving the feedback of response given.
                                        Keeps spinning
                                          dvbit @Guest
                                          @Bugsounet :-D
                                            dvbit
                                            @Bugsounet I will ask your advice on a simple js helper plugin for the C kinect gesture proggie I wrote. It would be nice to integrate it in a2d plugin
                                            • 4 / 6
