    mmm assistant mk2
    112 Posts 12 Posters 76.4k Views 11 Watching
      dvbit @dvbit
      @dvbit said in mmm assistant mk2:
      Update: I reinstalled from scratch (again for a2d I had to do a npm rebuild, you may want to take note)
      Still the same issue of assistant hanging after query:
      I do the query, hotword recognized, query recognized, answer fetched, answer saved in temp and displayed on screen bottom but no audio feedback and gogle spin icon going.
      After refreshing the screen goes again in “steady state”
      Now I am sure I have a sound output issue.
      Meaning that I can play sounds on the mirror via vlc but somehow the plugin cannot.
      I guess that somehow the plugin does not receive a feedback of “play ended” from the output.
      What I also noticed is that if I refresh the browser by vnc the mirror will go again in a waiting status.
      Will continue checking
      could it be this: https://github.com/raspberrypi/firmware/issues/1243
      Edit: Nope - vlc outputs sound
      IMPORTANT:
      The Install script for the audio output was succesfull just the first time.
      on second install I skipped the output part as I could not get through indeed.
      However the input was working just fine. recorded my voice and could hear it.
      Posting here my asoundrc file
      pcm.!default {
        type asym
        playback.pcm {
          type plug
          slave.pcm "output"
        capture.pcm {
          type plug
          slave.pcm "input"
      pcm.output {
        type hw
        card 0
      ctl.!default {
        type hw
        card 0
      Input is : kinect microphones
      Output : TV speakers (directly through TV speakers)
        sdetweil @Guest
        @Bugsounet it also has sandbox…
        we just moved up to V6 from V3 on 2.10, some things newer don’t work on pi…
          A Former User @Guest
          @Bugsounet said in mmm assistant mk2:
          pi@Raspberry:~/MagicMirror/node_modules/electron/dist $ ls -la
          total 107516
          drwxr-xr-x 4 pi   pi     4096 mai   20 15:23 .
          drwxr-xr-x 3 pi   pi     4096 juin   1 13:37 ..
          -rw-r--r-- 1 pi   pi   145945 mai   20 15:23 chrome_100_percent.pak
          -rw-r--r-- 1 pi   pi   209147 mai   20 15:23 chrome_200_percent.pak
          -rwsr-xr-x 1 root pi  4204060 mai   20 15:23 chrome-sandbox
          @dvbit: can you give me your result please ?
            dvbit @Guest
            pi@MagicMirror:~/MagicMirror $ ~/MagicMirror/node_modules/electron/dist $ ls -la
            bash: /home/pi/MagicMirror/node_modules/electron/dist: Is a directory
            pi@MagicMirror:~/MagicMirror $ cd ~/MagicMirror/node_modules/electron/dist
            pi@MagicMirror:~/MagicMirror/node_modules/electron/dist $ ls -la
            total 107496
            drwxr-xr-x 4 pi pi     4096 May 30 12:38 .
            drwxr-xr-x 4 pi pi     4096 May 30 12:38 ..
            -rw-r--r-- 1 pi pi   145945 May 30 12:38 chrome_100_percent.pak
            -rw-r--r-- 1 pi pi   209147 May 30 12:38 chrome_200_percent.pak
            -rwxr-xr-x 1 pi pi  4202140 May 30 12:38 chrome-sandbox
            -rwxr-xr-x 1 pi pi 74664904 May 30 12:38 electron
            -rw-r--r-- 1 pi pi 10410272 May 30 12:38 icudtl.dat
            -rwxr-xr-x 1 pi pi   157372 May 30 12:38 libEGL.so
            -rwxr-xr-x 1 pi pi  1949660 May 30 12:38 libffmpeg.so
            -rwxr-xr-x 1 pi pi  4883208 May 30 12:38 libGLESv2.so
            -rw-r--r-- 1 pi pi     1060 May 30 12:38 LICENSE
            -rw-r--r-- 1 pi pi  3961766 May 30 12:38 LICENSES.chromium.html
            drwxr-xr-x 2 pi pi     4096 May 30 12:38 locales
            -rw-r--r-- 1 pi pi    83237 May 30 12:38 natives_blob.bin
            drwxr-xr-x 2 pi pi     4096 May 30 12:38 resources
            -rw-r--r-- 1 pi pi  8471329 May 30 12:38 resources.pak
            -rw-r--r-- 1 pi pi   275792 May 30 12:38 snapshot_blob.bin
            -rw-r--r-- 1 pi pi   608820 May 30 12:38 v8_context_snapshot.bin
            -rw-r--r-- 1 pi pi        5 May 30 12:38 version
            Please look also post above: I realize my asoundrc file may be screwed since I did not complete on second install the sound output wizard successfully
              sdetweil @dvbit
              @dvbit run
              bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixsandbox)"
                A Former User
                sam : you have right
                permission is not set
                After 6 month … maybe it will be solved !
                  dvbit @sdetweil
                  done
                  here the output
                  pi@MagicMirror:~/MagicMirror/node_modules/electron/dist $ bash -c $(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixsandbox)
                  total 107496
                  I mean I did run the bash
                  No output. here is the detail listing of the folder.
                  I do not see any timestamps changed…
                    sdetweil @Guest
                    @Bugsounet don’t count on it!!
                      A Former User
                      not fixed
                        sdetweil @dvbit
                        @dvbit have to do from the MagicMirror folder… sorry, will fix for future
                          A Former User
                          sudo chown root node_modules/electron/dist/chrome-sandbox
                          sudo chmod 4755 node_modules/electron/dist/chrome-sandbox
                            dvbit @sdetweil
                            done it from MagicMirror folder.
                            Can I see any file being changed somewhere?
                            I did a ls -la in
                            and there seems to be no change there
                              A Former User
                              result must be:
                              S D 2 Replies Last reply Reply Quote 0
                                sdetweil @Guest
                                @Bugsounet maybe he doesn’t have sudo rights…
                                must do change to root first
                                  sdetweil @dvbit
                                  @dvbit it NEEDS the quotes
                                  I see I had a typo, try again
                                    dvbit @sdetweil
                                    @sdetweil Thanks I removed the final quote as I was ending up with a prompt
                                    will try again now with
                                      dvbit @Guest
                                      @Bugsounet and it is
                                      -rwsr-xr-x 1 root pi 4202140 May 30 12:38 chrome-sandbox
                                        A Former User
                                        result:
                                        fixing sandbox permissions
                                          A Former User
                                          cool ;)
                                          let retry now MAgicMirror
                                          edit: Fingers crossed
                                            A Former User
                                            With lost @dvbit in MagicMirror and GoogleAssistant ! :crazy_face:
                                            • 4 / 6
